33. ROS2-Robot Arm Course
33.1 Robotic Arm Installation and Wiring
The installation tutorial video for the PuppyPi robotic arm can be referred to in the same directory under Robotic Arm Installation. Below is a schematic diagram for the installation of the PuppyPi robotic arm:
Use four M4*6 round head machine screw to secure the robotic arm to the PuppyPi. Due to the replacement of old and new versions of PuppyPi sheet metal parts, some sheet metal parts can only be installed with two M4*6 round head machine screws. Please refer to the actual PuppyPi sheet metal parts for specifics.
M4*6 round head screw
Connect the servos ID9, ID10, and ID11 on the robotic arm to the PWM servo interfaces 9, 10, and 11 on the Raspberry Pi expansion board as pictured:
33.2 Power-on Inspection
33.2.1 Robot Power-on
Do not start PuppyPi on rough or uneven surfaces.
Do not forcibly move the servos after powering on to avoid damaging them.
Power-on Positioning
(1) Before powering on, to avoid servo damage from sudden movement, place PuppyPi in a lying position on a flat surface. The robotic arm should be positioned facing forward, as shown in the diagram below:
Before powering on, the robotic arm must be positioned facing straight forward. Do not position it hanging downwards to prevent damage to the robotic arm when the servos are powered on.
(2) Then, push the switch on the expansion board from OFF to ON. After powering on, the digital display at the tail of the robot dog will show the current battery level (it lights up at 8V as pictured). When the battery level is below 6.8V, the battery needs to be charged as soon as possible. LED1 and LED2 will emit a faint blue light. After a short wait, LED1 will stay on continuously, and LED2 will blink every two seconds, indicating that the network configuration is ready. Finally, wait for a beep from the buzzer, indicating that the ROS configuration is complete and the device has successfully started.
(3) The device defaults to AP direct connection mode out of the factory. After successful boot-up, it will generate a hotspot starting with HW.
33.2.2 Inspection
(2) Click the icon
in the top-left corner of the desktop to open the system terminal.
(3) Run the following command to execute the robotic arm test script:
ros2 launch puppy_control puppy_arm_test.launch.py
During the test, the robotic arm gripper will first open and close, then perform a complete grasping motion. Once the sequence is complete, servos 9 and 10, as well as servos 10 and 11, should form a 90-degree angle with the tabletop or other flat surface, as illustrated below:
If there is any noticeable deviation after the test, please proceed to the next section, 33.3 Robotic Arm Deviation Adjustment, for calibration instructions.
33.3.1 Determine Whether Offset Adjustment is Required
Offset adjustment is not necessary if the PuppyPi robotic arm meets the following initial posture conditions after powering on:
(1) The arm remains vertically aligned with the main body
(2) The two connecting rods form a 90-degree right angle
(3) The gripper is properly closed
If the robotic arm appears misaligned, as shown in the reference image, offset calibration is required.
33.3.2 Causes of Offset
Offset may occur under the following conditions:
(1) Incorrect horn installation: If the servo horn is installed while the shaft is not in its neutral (midpoint) position, it can cause an angular deviation. (Note: Servos are factory-calibrated to their midpoint by default.)
(2) Slight mounting misalignment: Even if the horn is installed correctly, small deviations in how the servo is mounted to the bracket can result in minor offsets.
① Offsets within ±100 units (approximately ±30°) are considered within the normal adjustment range and can be corrected through software.
② Offsets exceeding ±100 units require manual adjustment by removing the horn, repositioning it, and reinstalling it correctly.
33.3.3 Offset Adjustment Steps
Ensure the Reset Servo operation has been performed before proceeding.
(2) Click on
to launch the Terminator ROS2.
(3) Run the following command to launch the PC software.
python3 software/puppypi_control/PuppyPi.py
(4) Once the software is open, check the Arm option under Normal Mode to display the servo control panel.
(5) Servos with ID 9, 10, and 11 correspond to the robotic arm’s joints.
(6) Click the Reset Servo button to bring PuppyPi into its default position.
(7) In Normal Mode, observe the servo positions. If Servo ID10 is misaligned, proceed with adjustment.
(8) The software will automatically read the current offset value. Use the slider below ID10 to adjust its position until the two connecting rods are perpendicular. You can click the slider or use the mouse scroll wheel to fine-tune the value.
(9) After adjustment, click Save Deviation, then OK to store the offset in the control board.
33.4 Center of Gravity Calibration
33.4.1 Center of Gravity Explanation
The robotic dog’s center of gravity is positioned at the center of its body to ensure balanced weight distribution from front to back and side to side. During movement, the system continuously makes dynamic adjustments to the posture of each component to maintain a stable center of gravity—similar to how a person adjusts their balance when walking with or without carrying a load.
By default, the robot is configured without a robotic arm, and its center of gravity is pre-calibrated at the factory, so no further adjustment is required. However, when a robotic arm is installed, the shift in weight alters the center of gravity. In such cases, users must follow the instructions in this section to manually recalibrate the balance. This helps prevent issues such as body tilting or instability during operation.
33.4.2 Program Configuration Guide
The source code for the ROS2 program is located inside the Docker container at:
/home/ubuntu/ros2_ws/src/driver/puppy_control/puppy_control/puppy.py
As shown in the figure above, the x_shift parameter in the program defines the distance (in centimeters) by which all four legs of the quadruped robot move along the X-axis in the same direction. This parameter determines the robot’s gait balance point and can be adjusted within a range of -10 to 10.
When with_arm = 0 (i.e., the robot does not have a robotic arm installed), the default value of x_shift is -0.5, which corresponds to the standard center of gravity for the base model.
When adjusting this parameter:
A smaller value shifts the balance point forward, causing the robot to lean slightly forward.
A larger value shifts the balance point backward, causing it to lean slightly toward the rear.
Tuning the x_shift parameter is essential for maintaining walking stability, especially after hardware modifications such as mounting a robotic arm.
33.4.3 Center of Gravity Instructions
Commands are case-sensitive. You may use the Tab key for auto-completion.
(2) Click the icon at the top-left corner
of the desktop to open the ROS2 terminal.
(3) Enter the following command to navigate to the control script directory:
cd /home/ubuntu/ros2_ws/src/driver/puppy_control/puppy_control
(4) Open the script using the following command:
vim puppy.py
(5) Press the “i” key to enter insert mode for editing.
(6) Change with_arm=0 to with_arm=1, which sets the offset value to 0.1. As a result, the value of x_shift becomes -0.5 + 0.1 = -0.4.
(It is recommended to adjust the parameter value incrementally by ±0.01 each time for more precise tuning.)
(7) After editing, press the Esc key, then type and enter the following command to save and exit:
(8) Click on
to open the ROS2 command-line terminal. Then run the following command:
ros2 launch puppy_control puppy_control.launch.py
(9) Reopen the terminal, enter the command, and press Enter to view the effect of the adjustment. PuppyPi will continue moving forward during the demonstration.
ros2 topic pub /puppy_control/velocity puppy_control_msgs/msg/Velocity "x: 5.0
y: 0.0
yaw_rate: 0.0" --once
(10) To verify that the center of gravity adjustment is successful, allow PuppyPi to walk for 5 seconds. If it moves steadily during this time, the adjustment is considered complete.
Use the following command to stop its movement:
ros2 topic pub /puppy_control/velocity puppy_control_msgs/msg/Velocity "x: 0.0
y: 0.0
(11) If the walking motion remains unstable due to an imbalanced center of gravity, please repeat steps (2) to (11) as needed for further fine-tuning.
33.5 Robotic Arm Debugging
This document outlines troubleshooting solutions for common issues encountered during PuppyPi’s robotic arm extension activities, such as inaccurate gripping or failure to detect the target object.
While the adjustment procedures for the robotic arm are the same in both ROS2 and ROS2 environments, the steps for launching the activities differ. Please follow the instructions specific to your version.
33.5.1 Adjusting Color Thresholds Using LAB_TOOL
Open the LAB_TOOL software on the Raspberry Pi desktop and verify whether the three sponge blocks used in the activity are correctly detected. If any color is not fully recognized, adjust the corresponding color threshold accordingly.
(In the example image, the object to be detected appears white on the left side, while the background appears black, indicating successful color recognition.)
Acceptance Criteria: All three sponge blocks are accurately and fully detected.
33.5.2 Color Recognition and Grasping Debugging
Before debugging this game, please complete the color threshold adjustments for the three sponge blocks as described in 33.5.1 Adjusting Color Thresholds with LAB_TOOL.
(2) Open the Terminator terminal by clicking the system desktop icon
(3) Stop the auto-start service by entering the following command and pressing Enter:
(4) Launch the robotic arm gameplay by entering the command below and pressing Enter:
ros2 launch example color_detect_with_arm.launch.py
(5) A real-time video window will appear. The yellow rectangular area at the bottom is the recognition zone for the sponge blocks. Place the blue and green sponge blocks inside this zone, ensuring the bottom of each block aligns with the bottom edge of the yellow box (see image reference).
(6) If no recognition box appears around the sponge blocks, the color is not being detected. This may be due to an incorrect minimum color area threshold in the program. To stop the program, press Ctrl+C in the terminal.
(7) Navigate to the program directory by entering:
cd ros2_ws/src/example/example/puppy_with_arm
(8) Open the gameplay script with:
gedit color_detect_with_arm.py
(9) Scroll to line 127 and check the value of max_area, which defines the minimum recognized area for a single color block. The recommended value is 4000, based on extensive testing.
If the program fails to detect the blocks, try decreasing this value slightly.
Save the file and rerun the program to verify recognition.
Repeat adjustments until all sponge blocks are reliably recognized.
(10) After successful recognition, proceed to test grasping. Place the red sponge block in the recognition zone as described in step (5).
If the robot does not grasp securely or misses the block, check the gripper servo offsets.
Confirm the gripper is fully closed when no grasp command is issued.
Adjust the servo offset as needed.
(11) Once stable grasping is achieved, verify the grasping position. If it is too high, fine-tune the grasp position by adjusting the grab.d6a motion group.
(12) Acceptance Criteria: The game must reliably recognize all three sponge blocks by color and grasp them accurately without dropping during operation.
33.5.3 Line-Following Grasping Debugging
(2) Open the LTX terminal
at the top-left corner of the desktop, enter the following command to stop the button service, and press Enter:
sudo systemctl stop button_scan.service
(3) Click the system desktop’s top-left icon
to open the Terminator terminal.
(4) Enter the command below to stop auto-start game services, then press Enter:
(5) Start the line-following grasping gameplay by entering the command and pressing Enter:
ros2 launch example visual_patrol_with_arm.launch.py
(6) Press the Key1 button on the expansion board to start the game. If the robot fails to grasp the sponge block properly (e.g., grasping too early or too late), stop the program by pressing Ctrl+C in the terminal.
(7) Enter the following command to navigate to the course program directory:
(8) Open the game script by entering:
gedit visual_patrol_with_arm.py
(9) Locate line 355 and adjust the corresponding value:
If Puppypi grasps too late (with the gripper behind the sponge block), increase this value to initiate earlier grasping.
Adjust in increments of about 10 for each modification.
If the robot fails to grasp after increasing the value, it means the value is too high—revert to the previous value and fine-tune in increments of 1.
Test repeatedly until the robot can successfully grasp 3 times consecutively at a given value.
(10) Acceptance Criteria: The game runs successfully and the robot grasps the sponge block correctly 3 times in a row without failure.
33.5.4 Auto Recognition Grasping Debugging
(4) Enter the command below to stop auto-start gameplay services, then press Enter:
ros2 launch example color_grab.launch.py
(5) Press the Key1 button on the Raspberry Pi expansion board to start the program.
If the robot fails to grasp the sponge block correctly (grasping too early or too late), this indicates that the parameter range controlling the grasp action is improperly set.
(6) In the terminal, enter the following command to navigate to the course program directory:
(7) Open the corresponding gameplay script by running:
gedit color_grab.py
(8) Within the script:
Lines 102 and 117 define the lower limit for
block_center_point[1](e.g., the value 355 in the diagram), which determines when Puppypi moves forward. These two values must be kept consistent—any change to one must be reflected in the other.Lines 102 and 120 define the upper limit for
block_center_point[1](e.g., the value 370), which determines when Puppypi moves backward. This value is typically not changed, but if adjusted, both lines must be updated accordingly.After making any changes, save the file and rerun the gameplay to test the grasping action. The robot should be able to successfully grasp the sponge block three consecutive times.
(9) Acceptance Criteria: The robot consistently grasps the sponge block three times in a row during game.
33.5.5 Follow-up Procedure
After completing the above steps, carefully organize the robotic arm’s servo cables and secure them with cable ties. Make sure to power off the system before handling the cables. Acceptance Criteria: Move each servo of the robotic arm to its full range of motion repeatedly, and check that none of the servo cables become loose or disconnected. Once the cable management is confirmed secure, the robotic arm can be safely removed. This completes the entire debugging process.
33.6 Color Recognition Gripping
33.6.1 Program Logic
First, subscribe to the topic messages published by the camera node to obtain real-time image data. Then, convert the RGB color space to grayscale and read the camera’s intrinsic parameters.
Next, perform thresholding, erosion, and dilation on the image to obtain the largest contour of the target color within the image, and outline the detected color.
Finally, control the PuppyPi to perform feedback actions. When red is detected, control the robot to perform the grasping action.
33.6.2 Operation Steps
Command input must strictly differentiate between uppercase and lowercase letters as well as spaces.
(2) Click the icon
on the upper left corner to open the Terminator terminal.
(3) Input the following command and press Enter to close auto-start program.
(4) Input color recognition command and press Enter to start the program.
(5) To close this program, press Ctrl+C in the LX terminal interface. If closing fails, try pressing multiple times.
33.6.3 Program Outcome
After starting the game, please ensure that there are no other objects with the recognized color within the field of view of the camera, to avoid affecting the implementation effect of the game.
After starting the game, place the color block in front of PuppyPi. When the color block is recognized, it will be identified with a circle in the corresponding color, and the color name will be printed in the center of the window. The program can recognize color blocks of red, blue, and green, but only performs grasping operation on red color blocks.
If the color recognition is inaccurate, please refer to 23.1 Color Threshold Adjustment for adjustment.
33.6.4 Program Analysis
Before making any program modifications, it is essential to backup the original factory program. Avoid directly modifying the source code files to prevent accidentally changing parameters in the wrong way, leading to robot malfunctions that cannot be repaired!
According to the game effect, here is the logical process of this game as pictured:
Launch File Analysis
During the execution of the functionality, the launch file of the current package will be started (color_detect_with_arm.launch) as pictured:
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 | from launch import LaunchDescription from launch_ros.actions import Node from launch.launch_description_sources import PythonLaunchDescriptionSource from launch.actions import IncludeLaunchDescription import os def generate_launch_description(): # Define paths to external launch files ros_robot_controller_launch_path = '/home/ubuntu/ros2_ws/src/driver/ros_robot_controller/launch/ros_robot_controller.launch.py' usb_cam_launch_path = '/home/ubuntu/ros2_ws/src/peripherals/launch/usb_cam.launch.py' puppy_control_launch_path = '/home/ubuntu/ros2_ws/src/driver/puppy_control/launch/puppy_control.launch.py' return LaunchDescription([ # Define the color detect with arm node Node( package='example', executable='color_detect_with_arm', name='color_detect_with_arm_node', output='screen' ), # Include ros_robot_controller launch IncludeLaunchDescription( PythonLaunchDescriptionSource(ros_robot_controller_launch_path) ), # Include usb_cam launch IncludeLaunchDescription( PythonLaunchDescriptionSource(usb_cam_launch_path) ), # Include puppy_control launch IncludeLaunchDescription( PythonLaunchDescriptionSource(puppy_control_launch_path) ), ]) |
From the above diagram, it can be seen that the node name for this game functionality is color_detect_with_arm, and this node is located in the package puppy_with_arm. The node displays the processed information through the terminal.
Finally, the color recognition and gripping function is executed by calling the source code file color_detect_with_arm.py.
Source Code Program Analysis
The source code of this program is stored at: ros2_ws/src/example/example/puppy_with_arm/color_detect_with_arm.py
Imported Libraries
Several Python libraries are imported, including:
3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 | import sys import yaml import os from cv_bridge import CvBridge import cv2 import numpy as np import math import rclpy import time from threading import Timer from rclpy.node import Node from ros_robot_controller_msgs.msg import BuzzerState from sensor_msgs.msg import Image from puppy_control_msgs.srv import SetRunActionName from sdk import Misc |
① yaml for YAML file parsing.
② cv2 (OpenCV library) for image processing.
③ numpy and math for numerical computations.
④ ROS 2-related libraries include:
⑤ rclpy for ROS 2 client library.
⑥ sensor_msgs and ros_robot_controller_msgs for message handling.
⑦ The cv_bridge library is used for image data conversion between ROS and OpenCV.
Node Initialization
① class ColorDetectWithArm(Node): Defines a class that inherits from Node, representing a ROS 2 node.
② def __init__(self): The constructor initializes the node with the name color_detect_with_arm.
③ self.bridge = CvBridge(): Instantiates a CvBridge object to facilitate conversions between ROS image messages and OpenCV image formats.
YAML Configuration File Storage Path
yaml_file_path = '/home/ubuntu/software/lab_tool/lab_config.yaml': Define the YAML color threshold configuration
(1) Creating Publishers and Subscribers
① The program subscribes to the /image_raw topic to receive image messages, which are then processed via the image_callback function.
② It also initializes a motion control service proxy and a buzzer publisher. Upon execution, the system performs an initial movement and enters a loop, continuously waiting for image data.
③ In the event of an exception, a log message — Shutting down — is printed to indicate termination.
45 46 47 | # 创建发布者和服务客户端 self.buzzer_pub = self.create_publisher(BuzzerState, '/ros_robot_controller/set_buzzer', 1) self.runActionGroup_srv = self.create_client(SetRunActionName, '/puppy_control/runActionGroup') |
(2) A subscription is created using the create_subscription method to handle camera information.
49 50 | # 创建图像订阅 self.create_subscription(Image, '/image_raw', self.image_callback, 10) |
① The first parameter, /image_raw, specifies the topic name for receiving image data.
② The second parameter, Image, defines the message type.
③ The third parameter assigns the image_callback function to process the received image data.
(2) Creating a Publisher for the Buzzer: A publisher named buzzer_pub is created using the create_publisher method to control the buzzer.
45 46 | # 创建发布者和服务客户端 self.buzzer_pub = self.create_publisher(BuzzerState, '/ros_robot_controller/set_buzzer', 1) |
① The first parameter, /ros_robot_controller/set_buzzer, specifies the topic name for buzzer control.
② The second parameter, BuzzerState, defines the message type.
③ The third parameter, queue_size=1, sets the size of the message queue.
image_callback Callback Function
Below is a code snippet from the image_callback function:
149 150 151 152 153 154 155 156 157 | def image_callback(self, ros_image): try: cv2_img = self.bridge.imgmsg_to_cv2(ros_image, "bgr8") cv2_img = cv2.flip(cv2_img, 1) frame_result = self.run(cv2_img) cv2.imshow('Frame', frame_result) cv2.waitKey(1) except Exception as e: self.get_logger().error(f"Failed to process image: {e}") |
The image_callback function is defined to process incoming ROS image messages.
It converts the ROS image messages into OpenCV format, performs image flipping, and displays the processed result.
Run Image Processing Function
Below is a code snippet from the run function:
97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 | def run(self, img): size = (320, 240) img_copy = img.copy() img_h, img_w = img.shape[:2] frame_resize = cv2.resize(img_copy, size, interpolation=cv2.INTER_NEAREST) frame_gb = cv2.GaussianBlur(frame_resize, (3, 3), 3) frame_lab = cv2.cvtColor(frame_gb, cv2.COLOR_BGR2LAB) max_area = 0 color_area_max = None areaMaxContour_max = 0 if self.action_finish: for i in self.color_range_list: if i in ['red', 'green', 'blue']: frame_mask = cv2.inRange(frame_lab, np.array(self.color_range_list[i]['min']), np.array(self.color_range_list[i]['max'])) eroded = cv2.erode(frame_mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) dilated[0:120, :] = 0 dilated[:, 0:80] = 0 dilated[:, 240:320] = 0 contours = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE)[-2] areaMaxContour, area_max = self.get_area_max_contour(contours) if areaMaxContour is not None and area_max > max_area: max_area = area_max color_area_max = i areaMaxContour_max = areaMaxContour if max_area > 4000: ((centerX, centerY), radius) = cv2.minEnclosingCircle(areaMaxContour_max) centerX = int(Misc.map(centerX, 0, size[0], 0, img_w)) centerY = int(Misc.map(centerY, 0, size[1], 0, img_h)) radius = int(Misc.map(radius, 0, size[0], 0, img_w)) cv2.circle(img, (centerX, centerY), radius, self.draw_color, 2) print(f"Detected Color: {color_area_max}, Center: ({centerX}, {centerY}), Radius: {radius}") self.detect_color = color_area_max self.draw_color = (0, 0, 255) if color_area_max == 'red' else (0, 255, 0) else: print("No valid color detected") cv2.rectangle(img, (190, 270), (450, 480), (0, 255, 255), 2) if self.detect_color == self.target_color: cv2.putText(img, "Target Color", (225, 250), cv2.FONT_HERSHEY_SIMPLEX, 1, self.draw_color, 2) else: cv2.putText(img, "Not Target Color", (200, 250), cv2.FONT_HERSHEY_SIMPLEX, 1, self.draw_color, 2) cv2.putText(img, "Color: " + self.detect_color, (225, 210), cv2.FONT_HERSHEY_SIMPLEX, 1, self.draw_color, 2) return img |
The function first preprocesses the image, including resizing and applying Gaussian blur.
Then, based on predefined color ranges, it identifies color regions in the image and marks them using the minimum enclosing circle.
Next, the function compares the detected color regions with the target color, and displays corresponding text on the image based on the match.
The overall logic involves using image processing and color matching to detect and mark the target color regions, then displaying the results.
(1) Image Preprocessing:
The image is preprocessed by resizing, applying Gaussian blur, and converting RGB colors to the LAB color space.
99 100 101 102 103 104 | img_copy = img.copy() img_h, img_w = img.shape[:2] frame_resize = cv2.resize(img_copy, size, interpolation=cv2.INTER_NEAREST) frame_gb = cv2.GaussianBlur(frame_resize, (3, 3), 3) frame_lab = cv2.cvtColor(frame_gb, cv2.COLOR_BGR2LAB) |
(2) Color Range Masking:
Iterates through the color_range_list (containing red, green, and blue ranges).
Performs masking on the image based on the specified color ranges.
110 111 112 113 114 115 | if self.action_finish: for i in self.color_range_list: if i in ['red', 'green', 'blue']: frame_mask = cv2.inRange(frame_lab, np.array(self.color_range_list[i]['min']), np.array(self.color_range_list[i]['max'])) eroded = cv2.erode(frame_mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) |
(3) Contour Detection
After masking, the image undergoes erosion and dilation operations.
The image is cropped, and the getAreaMaxContour() function is called to detect contours.
Identifies the largest contour and its associated color.
112 113 114 115 116 117 118 119 120 | if i in ['red', 'green', 'blue']: frame_mask = cv2.inRange(frame_lab, np.array(self.color_range_list[i]['min']), np.array(self.color_range_list[i]['max'])) eroded = cv2.erode(frame_mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) dilated[0:120, :] = 0 dilated[:, 0:80] = 0 dilated[:, 240:320] = 0 contours = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE)[-2] areaMaxContour, area_max = self.get_area_max_contour(contours) |
(4) Filtering and Circle Drawing:
Calculates the pixel area of the contour, filtering out areas smaller than 8500 to ensure only target color blocks are identified.
Uses the cv2.minEnclosingCircle() function to find the smallest enclosing circle for the largest contour, obtaining its center (centerX, centerY) and radius.
Draws the circle on the image using cv2.circle() with the corresponding color.
127 128 129 130 131 132 133 134 135 136 137 138 | if max_area > 4000: ((centerX, centerY), radius) = cv2.minEnclosingCircle(areaMaxContour_max) centerX = int(Misc.map(centerX, 0, size[0], 0, img_w)) centerY = int(Misc.map(centerY, 0, size[1], 0, img_h)) radius = int(Misc.map(radius, 0, size[0], 0, img_w)) cv2.circle(img, (centerX, centerY), radius, self.draw_color, 2) print(f"Detected Color: {color_area_max}, Center: ({centerX}, {centerY}), Radius: {radius}") self.detect_color = color_area_max self.draw_color = (0, 0, 255) if color_area_max == 'red' else (0, 255, 0) else: print("No valid color detected") |
(5) Displaying Detected Color:
Compares the detected color (detect_color) with the target color (target_color).
Displays text on the image using cv2.putText() in the format "Color: " + detect_color.
Text is placed at (225, 210), with font cv2.FONT_HERSHEY_SIMPLEX, size 1, color draw_color, and thickness 2.
Returns the processed image.
140 141 142 143 144 145 146 147 | cv2.rectangle(img, (190, 270), (450, 480), (0, 255, 255), 2) if self.detect_color == self.target_color: cv2.putText(img, "Target Color", (225, 250), cv2.FONT_HERSHEY_SIMPLEX, 1, self.draw_color, 2) else: cv2.putText(img, "Not Target Color", (200, 250), cv2.FONT_HERSHEY_SIMPLEX, 1, self.draw_color, 2) cv2.putText(img, "Color: " + self.detect_color, (225, 210), cv2.FONT_HERSHEY_SIMPLEX, 1, self.draw_color, 2) return img |
move Function Execution
Below is a code snippet of the move function:
68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 | def move(self): if self.detect_color == self.target_color: msg = BuzzerState() msg.freq = 1900 msg.on_time = 0.1 msg.off_time = 0.9 msg.repeat = 1 self.buzzer_pub.publish(msg) self.action_finish = False time.sleep(0.8) req = SetRunActionName.Request() req.name = 'grab.d6a' self.runActionGroup_srv.call_async(req) time.sleep(0.5) self.set_servo_pulse(9, 1200, 300) time.sleep(0.3) self.set_servo_pulse(9, 1500, 300) req.name = 'look_down.d6a' self.runActionGroup_srv.call_async(req) time.sleep(0.8) self.detect_color = 'None' self.draw_color = (255, 255, 0) self.action_finish = True |
Based on the match between the detected color and the target color, the robot performs the corresponding actions.
If the color matches (e.g., red), a 0.1-second buzzer signal is sent using buzzer_pub.publish(0.1).
The robot then executes a series of actions (e.g., grasping and placing).
Afterward, the detected color is reset to None.
If the color does not match, the action sequence is not executed.
getAreaMaxContour Function
Below is a code snippet from the getAreaMaxContour function:
159 160 161 162 163 164 165 166 167 168 | def get_area_max_contour(self, contours): contour_area_max = 0 area_max_contour = None for c in contours: contour_area_temp = math.fabs(cv2.contourArea(c)) if contour_area_temp > contour_area_max: contour_area_max = contour_area_temp if contour_area_temp > 50: area_max_contour = c return area_max_contour, contour_area_max |
The function finds the largest contour from a set of contours.
It iterates through all the contours, calculates their areas, and retains the one with the largest area.
During area calculation, a condition is added to only consider contours with an area greater than or equal to 50, filtering out smaller, irrelevant contours.
Finally, the function returns the largest contour and its corresponding area.
33.6.5 Function Extension
When recognizing red, PuppyPi executes action of gripping and placing color block. To change to color to be detected, such as the green color block, follow these steps:
(1) Open a new command-line terminal
, the input the following command to navigate to the directory containing the programs.
cd /home/ubuntu/ros2_ws/src/example/example/puppy_with_arm
(2) Input the following command to edit color recognition gripping program. Then press Enter.
vim color_detect_with_arm.py
(3) Find the code as pictured:
After entering the code position number on the keyboard, press the Shift+Gkeys to directly navigate to the corresponding position. The code position number shown in the illustration is for reference only, please refer to the actual position.
(4) Press “i” to go to the editing mode. And change red to green.
(5) After modification, press Esc and input :wq. Then press Enter to save and exit.
(6) Refer to 33.6.2 Operation Steps to restart the program to check the modified game effects.
33.7 Auto Recognition Gripping
33.7.1 Program Logic
Then, control the PuppyPi to perform feedback actions. When red is detected, control the robot to perform the grasping action.
Finally, PuppyPi moves forward and then turns left to search for the red placement point. When red is detected, control the robot to perform the placement action, placing the color block at the red placement point.
33.7.2 Operation Steps
Instructions must be entered with strict attention to case sensitivity and spacing.
(2) Open the LX terminal
from the top-left corner of the desktop, enter the command below to stop the button service, and press Enter:
(3) Switch back to the ROS2 terminal and enter the following command to start the game:
(4) Press Key1 on the Raspberry Pi expansion board to start autonomous color detection and grasping. Press Key2 to pause the game.
(5) To exit the game, press Ctrl+C in the LX terminal. If the process does not terminate immediately, press the keys multiple times.
(6) After closing the game, re-enable the button service by entering the following command in the LX terminal
and pressing Enter:
sudo systemctl restart button_scan.service
33.7.3 Program Outcome
Once the game begins, detected red color blocks will be highlighted with bounding boxes in the video feed. PuppyPi will approach the red block and perform the grasping action. After successfully grasping the block, PuppyPi moves forward a short distance, then turns left to start searching for the placement area. In this implementation, a red square is designated as the placement target (this can be customized based on your requirements). Upon locating the red square, PuppyPi places the block inside it.
If the grasping position is inaccurate, you can fine-tune the block_center_point[1] parameter in the program. Increasing this value shifts the end-effector position backward, while decreasing it moves the position forward.
33.7.4 Program Analysis
The source code for this program is located in the Docker container at: ros2_ws/src/example/example/puppy_with_arm/color_grab.launch
Source Code Analysis
The source code of the program is located in the Docker container at: /home/ubuntu/ros2_ws/src/example/example/puppy_with_arm/color_grab.py
Import Related Application Library
4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 | import sys import cv2 import time import math import threading import numpy as np from enum import Enum import rclpy from rclpy.node import Node from sensor_msgs.msg import Image from cv_bridge import CvBridge from std_msgs.msg import String import gpiod import yaml import os |
① sys is used for handling command-line arguments and exiting the program.
② cv2 is used for OpenCV image processing.
③ math is used for mathematical calculations.
④ time is used for timing and delays.
⑤ threading is used for implementing parallel processing.
⑥ ArmIK is imported from sdk.ArmMoveIK for inverse kinematics control.
⑦ The Raspberry Pi GPIO library is imported for GPIO control.
20 21 22 23 24 25 | sys.path.append('/home/ubuntu/software/puppypi_control/') from servo_controller import setServoPulse from action_group_control import runActionGroup, stopActionGroup from puppy_kinematics import HiwonderPuppy, PWMServoParams from sdk.ArmMoveIK import ArmIK from sdk import Misc |
The setServoPulse function is imported from the ServoCmd module. This indicates that the ServoCmd module contains a function named setServoPulse, which is used to control the pulse signal of the servo motor.
The runActionGroup and stopActionGroup functions are imported from the ActionGroupControl module. These functions can be used directly in the current code without needing to call them with the full module name.
The HiwonderPuppy class and the PWMServoParams class are imported from the HiwonderPuppy module. Instances of HiwonderPuppy and PWMServoParams are created in the current code, and their methods and properties are used.
Main Program
Initialize the stance and gait configurations by calling the stance_config and gait_config methods on the puppy object. Start the robot dog with puppy.start(). Set the Debug mode to determine whether the robot dog should move. Open the camera to capture images. In the main loop, continuously capture images and call the run() function for image processing. The overall logic is to complete the program environment initialization, image acquisition and display, and state machine control running loop. Use the Debug mode to decide whether to enable the robot for line following and object grasping tasks.
215 216 217 218 219 220 221 222 223 224 225 226 227 | def move(self): # 移动控制线程 global puppyStatus, puppyStatusLast, block_center_point, block_color while rclpy.ok(): if puppyStatus == PuppyStatus.START: # 启动阶段:初始化姿态 puppy.move_stop(servo_run_time=500) PuppyPose = Bend.copy() puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']), PuppyPose['pitch'], PuppyPose['roll']) time.sleep(0.5) puppyStatus = PuppyStatus.NORMAL |
(1) Use puppy.stance_config to configure the stance of the robot dog’s four legs in a stationary state.
224 225 226 227 | puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']), PuppyPose['pitch'], PuppyPose['roll']) time.sleep(0.5) |
① The first parameter PuppyPose['stance_x'] indicates the additional separation distance of the four legs on the X-axis, in centimeters.
② The second parameter PuppyPose['stance_y'] indicates the additional separation distance of the four legs on the Y-axis, in centimeters.
③ The third parameter PuppyPose['height'] indicates the height of the dog, which is the vertical distance from the tips of the feet to the leg pivot axis, in centimeters.
④ The fourth parameter PuppyPose['x_shift'] represents the distance that all legs move in the same direction along the X-axis. The smaller the value, the more the dog leans forward while walking; the larger the value, the more it leans backward.
⑤ The fifth parameter PuppyPose['pitch'] represents the pitch angle of the robot dog’s body, in radians.
⑥ The sixth parameter PuppyPose['roll'] represents the roll angle of the robot dog’s body, in radians.
(2) Use puppy.gait_config to configure the parameters for the gait motion of the robot fog.
113 114 115 116 117 118 | puppy.gait_config( overlap_time=GaitConfig['overlap_time'], swing_time=GaitConfig['swing_time'], clearance_time=GaitConfig['clearance_time'], z_clearance=GaitConfig['z_clearance']) puppy.start() |
① The first parameter overlap_time represents the time during which all four legs are simultaneously in contact with the ground.
② The second parameter swing_time represents the time duration for a single leg to swing off the ground.
③ The third parameter clearace_time represents the time interval between the front and rear legs.
④ The fourth parameter z_clearance represents the height of the feet off the ground during the gait process.
(3) Start the robot dog, set its initial posture, and trigger the buzzer to sound.
118 119 120 121 122 | puppy.start() puppy.move_stop(servo_run_time=500) AK.setPitchRangeMoving((8.51, 0, 3.3), 500) setServoPulse(9, 1500, 500) time.sleep(0.5) |
(4) Set the Debug variable to toggle between Running modes. If Debug is True, it’s a non-real-time mode where only image processing is performed while the robot dog remains stationary. If Debug is False, it’s a real-time mode where both image processing and robot dog line following and object grasping tasks are performed simultaneously.
178 179 180 181 182 183 184 185 186 187 | if Debug: self.get_logger().info(f"block_center_x: {block_center_point[0]}, block_center_y: {block_center_point[1]}") cv2.circle(img, (centerX, centerY), int(radius), (0, 255, 255), 2) color_map = {'red': 1, 'green': 2, 'blue': 3} color_list.append(color_map.get(color_area_max, 0)) if len(color_list) == 3: color = int(round(np.mean(np.array(color_list)))) color_list = [] block_color = {1: 'red', 2: 'green', 3: 'blue', 0: 'None'}.get(color, 'None') |
(5) Enter the real-time image processing loop. Capture images from the camera, run processing functions on the images, and display the processed images. Additionally, detect the states of two buttons to set the robot dog’s state to start or stop. Continue looping until the user presses Ctrl+C to exit. Finally, close the camera and release resources.
193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 | def image_callback(self, msg): # 图像处理回调 global puppyStatus try: cv_image = self.bridge.imgmsg_to_cv2(msg, "bgr8") processed_img = self.process_image(cv_image) cv2.imshow('Frame', processed_img) cv2.waitKey(1) except Exception as e: self.get_logger().error(f"图像处理错误: {str(e)}") # 检查按键 if key1.get_value() == 0: time.sleep(0.05) if key1.get_value() == 0: puppyStatus = PuppyStatus.START if key2.get_value() == 0: time.sleep(0.05) if key2.get_value() == 0: puppyStatus = PuppyStatus.STOP stopActionGroup() |
Stance Function
124 125 126 127 128 129 130 | def stance(self, x=0.0, y=0.0, z=-11.0, x_shift=2.0): # 姿态配置函数 return np.array([ [x + x_shift, x + x_shift, -x + x_shift, -x + x_shift], [y, y, y, y], [z, z, z, z], ]) |
By changing the parameters within the function, describe the spatial relationship between the four limbs of the robot dog in various postures. The returned coordinate array serves as a reference for subsequent posture control and motion calculation modules.
getAreaMaxContour Contour Processing Function
By comparing the area of contours and filtering out those with an area less than 50, return the contour object along with its corresponding area value.
132 133 134 135 136 137 138 139 140 141 142 | def get_area_max_contour(self, contours): # 找出面积最大的轮廓 contour_area_max = 0 area_max_contour = None for c in contours: contour_area_temp = math.fabs(cv2.contourArea(c)) if contour_area_temp > contour_area_max: contour_area_max = contour_area_temp if contour_area_temp >= 5: area_max_contour = c return area_max_contour, contour_area_max |
144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 | def process_image(self, img): # 图像处理:识别目标颜色 global block_color, block_center_point, color_list img_copy = img.copy() img_h, img_w = img.shape[:2] frame_resize = cv2.resize(img_copy, size, interpolation=cv2.INTER_NEAREST) frame_gb = cv2.GaussianBlur(frame_resize, (3, 3), 3) frame_lab = cv2.cvtColor(frame_gb, cv2.COLOR_BGR2LAB) max_area = 0 color_area_max = None area_max_contour = None for color in ['red', 'green', 'blue']: if color in self.lab_data: frame_mask = cv2.inRange( frame_lab, tuple(self.lab_data[color]['min']), tuple(self.lab_data[color]['max'])) eroded = cv2.erode(frame_mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) contours, _ = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE) contour, area = self.get_area_max_contour(contours) if contour is not None and area > max_area: max_area = area color_area_max = color area_max_contour = contour |
Firstly, preprocess the image by resizing and applying Gaussian blur. Then, identify lines in different ROI regions based on predefined color ranges, calculate the center point positions of the line contours, compute the parameters of the circumscribed circles of the largest area color blocks in the image, determine the recognition status, output different recognition results, and display them in the image. The overall logic involves color recognition and contour extraction from the image, calculating key points of lines, and controlling robot dog movement based on recognition results.
(1) Preprocess the image, including resizing and applying Gaussian blur.
149 150 | frame_resize = cv2.resize(img_copy, size, interpolation=cv2.INTER_NEAREST) frame_gb = cv2.GaussianBlur(frame_resize, (3, 3), 3) |
(2) Segment the preprocessed image ROI into three regions: upper, middle, and lower. Convert the RGB color of the image blocks in these three regions to the LAB color space, and perform bitwise operations with the mask.
157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 | for color in ['red', 'green', 'blue']: if color in self.lab_data: frame_mask = cv2.inRange( frame_lab, tuple(self.lab_data[color]['min']), tuple(self.lab_data[color]['max'])) eroded = cv2.erode(frame_mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) contours, _ = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE) contour, area = self.get_area_max_contour(contours) if contour is not None and area > max_area: max_area = area color_area_max = color area_max_contour = contour |
(3) Find the contours of color blocks in the image and filter out those with a maximum contour area less than 200 to improve recognition accuracy. Finally, use the cv2.circle() function to draw the minimum enclosing circle on the image with a yellow color.
163 164 165 166 167 168 169 170 | eroded = cv2.erode(frame_mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) contours, _ = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE) contour, area = self.get_area_max_contour(contours) if contour is not None and area > max_area: max_area = area color_area_max = color area_max_contour = contour |
(4) Differentiate the largest color block based on color, marking them as 1 (red), 2 (green), or 3 (blue), and assign the result to block_color. Then, check if weight_sum is not equal to 0. If it is, draw the center point of the image based on the calculated center point coordinates. Finally, return the processed image based on the values of block_center_point and line_centerx.
182 183 184 185 186 187 188 189 | color_map = {'red': 1, 'green': 2, 'blue': 3} color_list.append(color_map.get(color_area_max, 0)) if len(color_list) == 3: color = int(round(np.mean(np.array(color_list)))) color_list = [] block_color = {1: 'red', 2: 'green', 3: 'blue', 0: 'None'}.get(color, 'None') else: block_color = 'None' |
Move Execution Action Function
During the startup phase (PuppyStatus.START), the robot dog stops moving and initializes its posture. In the normal forward phase (PuppyStatus.NORMAL), the robot dog’s movement direction and speed are controlled based on the position relationship between the image center point and the color block center point. If a red color block is detected (PuppyStatus.FOUND_TARGET), execute the grasping action, and then turn the robot dog to the left for a certain distance. During the placing phase (PuppyStatus.PLACE), start searching for red placing points. If a red placing point is found, execute the placing action.
215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 | def move(self): # 移动控制线程 global puppyStatus, puppyStatusLast, block_center_point, block_color while rclpy.ok(): if puppyStatus == PuppyStatus.START: # 启动阶段:初始化姿态 puppy.move_stop(servo_run_time=500) PuppyPose = Bend.copy() puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']), PuppyPose['pitch'], PuppyPose['roll']) time.sleep(0.5) puppyStatus = PuppyStatus.NORMAL elif puppyStatus == PuppyStatus.NORMAL: # 正常前进:寻找目标颜色物块 if (block_center_point[1] > 355 and block_center_point[1] < 370 and block_color == self.target_color and abs(block_center_point[0] - img_centerx) < 50): puppyStatus = PuppyStatus.FOUND_TARGET puppy.move_stop(servo_run_time=500) time.sleep(0.5) else: value = block_center_point[0] - img_centerx if block_center_point[1] <= 300: PuppyMove['x'] = 10.0 PuppyMove['yaw_rate'] = math.radians(0.0) elif abs(value) > 80: PuppyMove['x'] = 5 PuppyMove['yaw_rate'] = math.radians(-11.0 * np.sign(value)) elif abs(value) > 50: PuppyMove['x'] = 5.0 PuppyMove['yaw_rate'] = math.radians(-5.0 * np.sign(value)) elif block_center_point[1] <= 355: PuppyMove['x'] = 8.0 PuppyMove['yaw_rate'] = math.radians(0.0) elif block_center_point[1] >= 370: PuppyMove['x'] = -5.0 PuppyMove['yaw_rate'] = math.radians(0.0) puppy.move(x=PuppyMove['x'], y=PuppyMove['y'], yaw_rate=PuppyMove['yaw_rate']) elif puppyStatus == PuppyStatus.FOUND_TARGET: # 发现目标:执行夹取 runActionGroup('grab.d6a', True) PuppyPose = Stand.copy() puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']+1), PuppyPose['pitch'], PuppyPose['roll']) time.sleep(0.5) PuppyMove['x'] = 10.0 PuppyMove['yaw_rate'] = math.radians(0.0) puppy.move(x=PuppyMove['x'], y=PuppyMove['y'], yaw_rate=PuppyMove['yaw_rate']) time.sleep(1) PuppyMove['x'] = 5 PuppyMove['yaw_rate'] = math.radians(20.0) puppy.move(x=PuppyMove['x'], y=PuppyMove['y'], yaw_rate=PuppyMove['yaw_rate']) time.sleep(3) puppy.move_stop(servo_run_time=500) time.sleep(0.5) PuppyPose = Bend.copy() puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']), PuppyPose['pitch'], PuppyPose['roll']) time.sleep(0.5) puppyStatus = PuppyStatus.PLACE |
33.7.5 Function Extension
(1) Open a terminal by clicking the icon
. Then run the following command to navigate to the directory containing the programs.
vim color_grab.py
(6) Refer to 33.7.2 Operation Steps to restart the program to check the modified game effects.
33.8 Line Following Gripping
33.8.1 Program Logic
First, it’s necessary to recognize the line colors. Here, we’re using the Lab color space for processing. We’ll convert the image color space from RGB to Lab.
Next, perform operations such as binarization, erosion, and dilation on the image to obtain contours containing only the target color, and mark them with rectangles.
After completing color recognition, calculate based on the feedback of line positions in the image, and control the PuppyPi robot dog to move along the lines, thus achieving autonomous line-following walking.
During line following, if color blocks of the target color are detected, the robot will call action groups to grasp and transport the color blocks. After the transport is completed, it will return to the task of autonomous line following.
33.8.2 Operation Steps
(2) Open the LTX terminal from the top-left corner of the desktop
, enter the command to disable the button service, and press Enter.
(3) Click the icon
to start the Terminator ROS2 terminal, then execute the following command.
Press the Key1 button on the expansion board to start the operation.
(4) To stop the operation, press Ctrl+C in the LX terminal window. If it fails to stop, press it multiple times.
(5) Finally, enter the following command and press Enter to start the button detection service:
33.8.3 Program Outcome
After starting the game, please ensure that there are no other objects containing the recognized colors within the field of view of the camera, to avoid affecting the implementation of the game.
After placing the PuppyPi robot dog on a black line, starting the gameplay will prompt the robot dog to move along the black line. If a color block is detected blocking the line ahead, the robot will perform a transport action. It will pick up red color blocks and place them on the left side of the line, and pick up green or blue color blocks and place them on the right side of the line. After completing the pick-up action, it will continue with the line-following task.
If the color recognition is inaccurate, you can refer to 23.1 Color Threshold Adjustment to adjust.
If there are instances of inaccurate gripping positions, you can modify the parameter block_center_point[1] in the program. A larger value will position the gripper further back, while a smaller value will position it further forward.
33.8.4 Program Analysis
Before modifying the program, it is essential to back up the original factory program. Avoid making direct modifications in the source code files to prevent unintentional changes to parameters that could lead to robot malfunctions and be irreparable!
Based on the camera feed, obtain real-time visual information and use color thresholding algorithms to extract the color lines required for line following. Calculate the robot’s required movement speed and heading angle based on the offset of the lines in the image, correcting its position to keep the lines centered in the frame in real-time. If a target color block is detected in front of the line-following position, execute a grasping action to place the color block aside and continue with the line-following task.
The source code of this program is stored at: /home/ubuntu/ros2_ws/src/example/example/puppy_with_arm/visual_patrol_with_arm.py
① sys is used for handling command-line arguments and exiting the program;
② cv2 is used for OpenCV image processing;
③ math is used for mathematical calculations;
④ time is used for timing and delays;
⑤ threading is used for implementing parallel processing;
⑥ numpy is used for scientific computing.
⑦ enum is used to define program running states.
⑧ ArmMoveIK is used to control robotic arm movement.
⑨ pigpio is used for GPIO control, facilitating communication with peripheral hardware.
⑩ Import functions from servoCmd for setting servo pulse width.
⑪ Import action groups from ActionGroupControl.
Main Program
Initialize the posture and gait settings by calling the stance_config and gait_config of the puppy object. Then, start the robot using puppy.start(). After that, activate the camera to capture images, and retrieve images continuously within the main loop.
125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 | def init_puppy(self): # 初始化机器人姿态和步态 puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']), PuppyPose['pitch'], PuppyPose['roll']) puppy.gait_config( overlap_time=GaitConfig['overlap_time'], swing_time=GaitConfig['swing_time'], clearance_time=GaitConfig['clearance_time'], z_clearance=GaitConfig['z_clearance']) puppy.start() puppy.move_stop(servo_run_time=500) AK.setPitchRangeMoving((8.51, 0, 3.3), 500) setServoPulse(9, 1500, 500) time.sleep(0.5) |
127 128 129 | puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']), PuppyPose['pitch'], PuppyPose['roll'])# paste source code here. |
131 132 133 134 135 136 | puppy.gait_config( overlap_time=GaitConfig['overlap_time'], swing_time=GaitConfig['swing_time'], clearance_time=GaitConfig['clearance_time'], z_clearance=GaitConfig['z_clearance']) puppy.start() |
(3) Set the Debug variable to toggle between Running modes. If Debug is True, it’s a non-real-time mode where only image processing is performed while the robot dog remains stationary. If Debug is False, it’s a real-time mode where both image processing and robot dog line following and object grasping tasks are performed simultaneously.
211 212 213 214 | if Debug: self.get_logger().info(f"line_centerx: {line_centerx}") else: line_centerx = -1 |
Stance Function
The following is a screenshot of the code inside the stance function:
142 143 144 145 146 147 148 | def stance(self, x=0.0, y=0.0, z=-11.0, x_shift=2.0): # 姿态配置函数,单位cm return np.array([ [x + x_shift, x + x_shift, -x + x_shift, -x + x_shift], [y, y, y, y], [z, z, z, z], ]) |
By altering the parameters within the function, describe the spatial relationship of the robot dog’s four limbs in various postures. The returned coordinate array provides reference for subsequent posture control and motion calculation modules.
The following is a screenshot of the code inside the process_image function:
162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 | def process_image(self, img): # 图像处理:巡线和颜色识别 global line_centerx, block_color, block_center_point, color_list img_copy = img.copy() img_h, img_w = img.shape[:2] frame_resize = cv2.resize(img_copy, size, interpolation=cv2.INTER_NEAREST) frame_gb = cv2.GaussianBlur(frame_resize, (3, 3), 3) centroid_x_sum = 0 weight_sum = 0 n = 0 center_x_3 = [None] * 3 # 巡线处理 for r in roi: roi_h = roi_h_list[n] n += 1 blobs = frame_gb[r[0]:r[1], r[2]:r[3]] frame_lab = cv2.cvtColor(blobs, cv2.COLOR_BGR2LAB) if self.line_color in self.lab_data: frame_mask = cv2.inRange( frame_lab, tuple(self.lab_data[self.line_color]['min']), tuple(self.lab_data[self.line_color]['max'])) opened = cv2.morphologyEx(frame_mask, cv2.MORPH_OPEN, np.ones((6, 6), np.uint8)) closed = cv2.morphologyEx(opened, cv2.MORPH_CLOSE, np.ones((6, 6), np.uint8)) cnts = cv2.findContours(closed, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_TC89_L1)[-2] cnt_large = self.get_area_max_contour(cnts)[0] |
First, preprocess the image, including resizing and applying Gaussian blur. Then, identify lines in different ROI regions based on predefined color ranges, calculate the center point positions of the line contours, and compute the parameters of the minimum enclosing circle for the largest area color block detected in the image. Based on the judgment of recognition status, output different recognition results such as line center points and color block types, and display them in the image. The overall logic involves color recognition and contour extraction from the image, calculating key points of lines, and outputting recognition results for motion control.
166 167 | frame_resize = cv2.resize(img_copy, size, interpolation=cv2.INTER_NEAREST) frame_gb = cv2.GaussianBlur(frame_resize, (3, 3), 3) |
170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 | centroid_x_sum = 0 weight_sum = 0 n = 0 center_x_3 = [None] * 3 # 巡线处理 for r in roi: roi_h = roi_h_list[n] n += 1 blobs = frame_gb[r[0]:r[1], r[2]:r[3]] frame_lab = cv2.cvtColor(blobs, cv2.COLOR_BGR2LAB) if self.line_color in self.lab_data: frame_mask = cv2.inRange( frame_lab, tuple(self.lab_data[self.line_color]['min']), tuple(self.lab_data[self.line_color]['max'])) opened = cv2.morphologyEx(frame_mask, cv2.MORPH_OPEN, np.ones((6, 6), np.uint8)) closed = cv2.morphologyEx(opened, cv2.MORPH_CLOSE, np.ones((6, 6), np.uint8)) cnts = cv2.findContours(closed, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_TC89_L1)[-2] cnt_large = self.get_area_max_contour(cnts)[0] |
(3) After the mask operation, perform opening and closing operations on the image using mathematical morphology. Extract the outer contours of the targets using the cv2.findContours() function, and call the getAreaMaxContour() function to detect contours, filtering out those with smaller areas.
186 187 188 189 | opened = cv2.morphologyEx(frame_mask, cv2.MORPH_OPEN, np.ones((6, 6), np.uint8)) closed = cv2.morphologyEx(opened, cv2.MORPH_CLOSE, np.ones((6, 6), np.uint8)) cnts = cv2.findContours(closed, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_TC89_L1)[-2] cnt_large = self.get_area_max_contour(cnts)[0] |
(4) By checking if cnt_large is not empty, it indicates the detection of the target color. Using the cv2.minAreaRect() function, calculate the minimum bounding rectangle of cnt_large and assign the processed result to rect. Then, use the cv2.boxPoints() function to obtain the four vertices of the minimum bounding rectangle and draw this rectangle and its center point on the image. Additionally, add the X-coordinate of the rectangle’s center point to centroid_x_sum based on the weight value for subsequent calculations.
191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 | if cnt_large is not None: rect = cv2.minAreaRect(cnt_large) box = np.int0(cv2.boxPoints(rect)) for i in range(4): box[i, 1] = box[i, 1] + (n - 1) * roi_h + roi[0][0] box[i, 1] = int(Misc.map(box[i, 1], 0, size[1], 0, img_h)) box[i, 0] = int(Misc.map(box[i, 0], 0, size[0], 0, img_w)) cv2.drawContours(img, [box], -1, (0, 0, 255), 2) pt1_x, pt1_y = box[0, 0], box[0, 1] pt3_x, pt3_y = box[2, 0], box[2, 1] center_x, center_y = (pt1_x + pt3_x) / 2, (pt1_y + pt3_y) / 2 cv2.circle(img, (int(center_x), int(center_y)), 5, (0, 0, 255), -1) center_x_3[n-1] = center_x centroid_x_sum += center_x * r[4] weight_sum += r[4] if weight_sum != 0: line_centerx = int(centroid_x_sum / weight_sum) cv2.circle(img, (line_centerx, int(center_y)), 10, (0, 255, 255), -1) if Debug: self.get_logger().info(f"line_centerx: {line_centerx}") else: line_centerx = -1 |
(5) By checking the value of puppyStatus, it indicates that the robot is currently performing the line-following and object grasping task. Then, the image is converted to the LAB color space. Based on the color threshold ranges defined in lab_data, bitwise operations, erosion, and dilation operations are performed on the image to find color block contours. Contours with a maximum area less than 200 are filtered out to improve recognition accuracy. Finally, the cv2.circle() function is used to draw the minimum enclosing circle on the image with the color corresponding to the color block.
217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 | # 颜色识别 if puppyStatus == PuppyStatus.NORMAL: frame_lab_all = cv2.cvtColor(frame_gb, cv2.COLOR_BGR2LAB) max_area = 0 color_area_max = None area_max_contour = None for color in self.target_colors: if color in self.lab_data: frame_mask = cv2.inRange( frame_lab_all, tuple(self.lab_data[color]['min']), tuple(self.lab_data[color]['max'])) eroded = cv2.erode(frame_mask, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) dilated = cv2.dilate(eroded, cv2.getStructuringElement(cv2.MORPH_RECT, (3, 3))) contours, _ = cv2.findContours(dilated, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE) contour, area = self.get_area_max_contour(contours) if contour is not None and area > max_area: max_area = area color_area_max = color area_max_contour = contour if max_area > 200: ((centerX, centerY), radius) = cv2.minEnclosingCircle(area_max_contour) centerX = int(Misc.map(centerX, 0, size[0], 0, img_w)) centerY = int(Misc.map(centerY, 0, size[1], 0, img_h)) block_center_point = (centerX, centerY) self.get_logger().info(f"检测到物块: 颜色={color_area_max}, 中心=({centerX}, {centerY}), 面积={max_area}") cv2.circle(img, (centerX, centerY), int(radius), (0, 255, 255), 2) |
(6) Differentiate the largest color block based on color, marking them as 1 (red), 2 (green), or 3 (blue), and assign the result to block_color. Then, check if weight_sum is not equal to 0. If it is, draw the center point of the image based on the calculated center point coordinates. Finally, return the processed image based on the values of block_center_point and line_centerx.
247 248 249 250 251 252 253 254 255 256 257 | color_map = {'red': 1, 'green': 2, 'blue': 3} color_list.append(color_map.get(color_area_max, 0)) if len(color_list) == 3: color = int(round(np.mean(np.array(color_list)))) color_list = [] block_color = {1: 'red', 2: 'green', 3: 'blue', 0: 'None'}.get(color, 'None') self.get_logger().info(f"确认物块颜色: {block_color}") else: block_color = 'None' else: block_center_point = (0, 0) |
The following is a screenshot of the code portion inside the move function:
339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 | def move(self): # 移动控制线程 global puppyStatus, puppyStatusLast, block_center_point, block_color, line_centerx while rclpy.ok(): if puppyStatus == PuppyStatus.START: # 启动阶段:初始化姿态 puppy.move_stop(servo_run_time=500) PuppyPose = Bend.copy() puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']), PuppyPose['pitch'], PuppyPose['roll']) time.sleep(0.5) puppyStatus = PuppyStatus.NORMAL elif puppyStatus == PuppyStatus.NORMAL: # 正常巡线:寻找目标颜色物块 if block_center_point[1] > 350 and block_color in self.target_colors and abs(block_center_point[0] - line_centerx) < 80: puppyStatus = PuppyStatus.FOUND_TARGET puppy.move_stop(servo_run_time=500) time.sleep(0.5) elif line_centerx != -1: value = line_centerx - img_centerx if abs(value) <= 50: PuppyMove['x'] = 10 PuppyMove['yaw_rate'] = math.radians(0) elif abs(value) > 80: PuppyMove['x'] = 8 PuppyMove['yaw_rate'] = math.radians(-11.0) elif abs(value) > 50: PuppyMove['x'] = 8 PuppyMove['yaw_rate'] = math.radians(-18.0) puppy.move(x=PuppyMove['x'], y=PuppyMove['y'], yaw_rate=PuppyMove['yaw_rate']) elif puppyStatus == PuppyStatus.FOUND_TARGET: # 发现目标:执行夹取和放置 if block_color in self.target_colors: try: runActionGroup('grab.d6a', True) PuppyPose = Stand.copy() puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']+1), PuppyPose['pitch'], PuppyPose['roll']) time.sleep(0.5) # 执行放置 if self.place_block(block_color): # 恢复巡线姿态 PuppyPose = Bend.copy() puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']), PuppyPose['pitch'], PuppyPose['roll']) time.sleep(0.5) puppyStatus = PuppyStatus.NORMAL else: self.get_logger().error("放置失败,恢复巡线状态") puppyStatus = PuppyStatus.NORMAL except Exception as e: self.get_logger().error(f"夹取动作失败: {str(e)}") puppyStatus = PuppyStatus.NORMAL else: self.get_logger().warn(f"物块颜色{block_color}无效,跳过夹取") puppyStatus = PuppyStatus.NORMAL elif puppyStatus == PuppyStatus.STOP: # 停止状态 puppy.move_stop(servo_run_time=500) PuppyPose = Stand.copy() puppy.stance_config( self.stance(PuppyPose['stance_x'], PuppyPose['stance_y'], PuppyPose['height'], PuppyPose['x_shift']), PuppyPose['pitch'], PuppyPose['roll']) time.sleep(0.5) if puppyStatusLast != puppyStatus: self.get_logger().info(f'当前状态: {puppyStatus}') status_msg = String() status_msg.data = str(puppyStatus) self.status_pub.publish(status_msg) puppyStatusLast = puppyStatus time.sleep(0.02) |
During the startup phase (PuppyStatus.START), the robot dog stops moving and initializes its posture. During normal line-following phase (PuppyStatus.NORMAL), the robot dog’s movement direction and speed are controlled based on the position relationship between the image center point and the block center point. If a color block is detected (PuppyStatus.FOUND_TARGET), the corresponding action group is executed based on the color of the block. If the block is red, the robot first performs the grasping action, then moves to the left side of the line, and finally executes the placing action. If the block is green or blue, the robot first performs the grasping action, then moves to the right side of the line, and finally executes the placing action.
33.8.5 Function Extension
When the game default recognizes red, the robot dog executes the grasping action group and places the red color block on the left side of the line. When the game default recognizes green, the robot dog executes the grasping action group and places the green color block on the right side of the line. If you need to change the placement position, for example, swapping the positions of the red and green color blocks, you can follow these steps:
(1) Open a new command-line terminal by clicking
. Then execute the following command to navigate to the directory containing the programs.
(2) Enter the command to open the color recognition and grasping program for editing, then press Enter.
vim visual_patrol_with_arm.py
(3) Find the following code:
(4) Press “i” to go to the editing mode. And swap the positions of the red and green.
Refer to 33.8.2 Operation Steps to restart the program to check the modified game effects.
33.9 Gesture Control Robotic Arm
33.9.1 Program Logic
Next, use the Mediapipe library to connect the recognized keypoints of the hand. Normalize the coordinates of the keypoints of the thumb and index finger, then convert them to pixel coordinates in the image. Calculate the distance between these two points.
Finally, the robotic gripper performs opening and closing movements based on the calculated distance.
33.9.2 Operation Steps
(2) Click the icon
on the upper left corner to open the Terminator ROS2 terminal. Then execute the following command to start the game.
ros2 launch example hand_control_with_arm.launch.py
To minimize memory usage and ensure smooth operation, the camera feed is not displayed by default. If you wish to enable the camera feed, follow the steps below:
Before starting the camera feed, ensure the gesture control feature is running properly. Otherwise, the camera feed may fail to start.
After the feature is activated, the camera feed will not be visible in VNC. To view the camera feed, you can enable the web_video_server service and access it through a browser.
(3) Use any web browser and enter the address 192.168.149.1:8080.
(4) Select the corresponding node’s image to view.
(5) Enter the camera feedback interface for gesture-controlled robotic arm game as pictured:
(6) If you need to close this game, you can press Ctrl+C in the LX terminal interface. If closing fails, you can try pressing multiple times.
33.9.3 Program Outcome
After the game starts, when hand features are recognized, they will be connected by dots and lines. A yellow line connects the thumb and index finger, and the distance between them is calculated and displayed in the lower-left corner. The mechanical gripper of Puppypi will follow the changes in distance between the thumb and index finger.
33.9.4 Program Analysis
Based on the game’s effects, the process logic for this gameplay is summarized as shown in the following diagram:
The source code of this program is saved in the Docker container: ros2_ws/src/example/example/puppy_with_arm/hand_control_with_arm.launch
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 | from launch import LaunchDescription from launch_ros.actions import Node from launch.launch_description_sources import PythonLaunchDescriptionSource from launch.actions import IncludeLaunchDescription from launch.substitutions import PathJoinSubstitution from launch_ros.substitutions import FindPackageShare def generate_launch_description(): return LaunchDescription([ Node( package='example', executable='hand_control_with_arm', name='hand_control_with_arm_node', output='screen', ), IncludeLaunchDescription( PythonLaunchDescriptionSource( ['/home/ubuntu/ros2_ws/src/driver/ros_robot_controller/launch/ros_robot_controller.launch.py'] ), ), IncludeLaunchDescription( PythonLaunchDescriptionSource( ['/home/ubuntu/ros2_ws/src/peripherals/launch/web_video_server.launch.py'] ), ), IncludeLaunchDescription( PythonLaunchDescriptionSource( ['/home/ubuntu/ros2_ws/src/peripherals/launch/usb_cam.launch.py'] ), ), IncludeLaunchDescription( PythonLaunchDescriptionSource( ['/home/ubuntu/ros2_ws/src/driver/puppy_control/launch/puppy_control.launch.py'] ), ), ]) |
(1) Node: Launches an arm control node named hand_control_with_arm, responsible for managing the robot’s arm control logic.
(2) IncludeLaunchDescription: Includes multiple other launch files for modular management of robot control, video stream processing, and USB camera handling.
ros2_ws/src/example/example/puppy_with_arm/hand_control_with_arm.py
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 | import cv2 import sys import os import enum import math import time import queue import rclpy import threading import numpy as np import faulthandler import mediapipe as mp from rclpy.node import Node from cv_bridge import CvBridge from sensor_msgs.msg import Image from sdk.common import vector_2d_angle, distance from sdk.ArmMoveIK import ArmIK from collections import deque sys.path.append('/home/ubuntu/software/puppypi_control/') from servo_controller import setServoPulse |
④ rospy is used for ROS communication;
⑤ time is used for timing and delays;
⑥ mediapipe is used for gesture recognition
⑦ threading is used for implementing parallel processing.
⑧ Misc, PID are used for PID control of robotic arm movement;
⑨ Import service type from std_srvs.srv.
⑩ Import ROS image message module from sensor_msgs.msg for handling image messages;
⑪ Import ArmIK from arm_kinematics.ArmMoveIK for inverse kinematics control;
⑫ Import all service types from the std_srvs.srv package.
21 22 | sys.path.append('/home/ubuntu/software/puppypi_control/') from servo_controller import setServoPulse |
A variable named HomePath is defined to represent the main directory path as /home/pi. Then, /home/pi/PuppyPi_PC_Software is added to Python’s module search path using sys.path.append.
The function setServoPulse is imported from the module ServoCmd. This indicates that the ServoCmd module contains a function named setServoPulse, which is used to control the pulse signal of servo motors.
Distance Calculation Between Two Points
26 27 28 29 30 | def distance(point_1, point_2): """ 计算两个点间的距离(calculate the distance between two points) """ return math.sqrt((point_1[0] - point_2[0]) ** 2 + (point_1[1] - point_2[1]) ** 2) |
Using the Python math library, the Euclidean distance between two points is calculated. It computes the distance between two points (point_1[0], point_1[1]) and (point_2[0], point_2[1]) on a two-dimensional plane.
(point_1[0] - point_2[0]) ** 2 and (point_1[1] - point_2[1]) ** 2: These calculate the squares of the differences in the x and y directions, respectively. Then, these squares are added together to obtain the square of the Euclidean distance.
math.sqrt: Calculate the square root of the sum to obtain the final Euclidean distance.
Coordinates Conversion
32 33 34 35 36 37 38 | def get_hand_landmarks(img, landmarks): """ 将landmarks从medipipe的归一化输出转为像素坐标 """ h, w, _ = img.shape landmarks = [(lm.x * w, lm.y * h) for lm in landmarks] return np.array(landmarks) |
landmarks = [(lm.x * w, lm.y * h) for lm in landmarks]: Using list comprehension, multiply each key point’s x and y coordinates by the width and height of the image, respectively, to obtain the actual coordinates. Here, lm represents the object containing key points.
return np.array(landmarks): Convert the mapped key point coordinates to a NumPy array and return it as the function’s result.
Convert the OpenCV Image to the Image Message of the ROS
40 41 42 43 44 45 46 47 48 | def cv2_image2ros(image, frame_id='', node=None): """ 将opencv的图片转换为ROS2 Image消息 """ bridge = CvBridge() ros_image = bridge.cv2_to_imgmsg(image, encoding="rgb8") ros_image.header.stamp = node.get_clock().now().to_msg() ros_image.header.frame_id = frame_id return ros_image |
The function cv2_image2ros converts an image in OpenCV format to the ROS image message format. It first converts the image channels from BGR to RGB, then creates a ROS image message, setting its header information, dimensions, encoding, and data. Finally, it returns the converted ROS image message.
HandControlWithArmNode Class Initialization
50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 | class HandControlWithArmNode(Node): def __init__(self, name): super().__init__(name) # ROS2 中的节点初始化 self.mpHands = mp.solutions.hands self.hands = self.mpHands.Hands(static_image_mode=False, max_num_hands=1, min_detection_confidence=0.7, min_tracking_confidence=0.7) self.mpDraw = mp.solutions.drawing_utils self.ak = ArmIK() self.last_time = time.time() self.last_out = 0 self.frames = 0 self.window_size = 5 # 定义滑动窗口大小(滤波窗口大小) self.distance_measurements = deque(maxlen=self.window_size) # 创建一个队列用于存储最近的距离测量数据 self.filtered_distance = 0 self.image = None # 定时器用于定期处理图像和发布数据 self.timer = self.create_timer(0.05, self.timer_callback) # 每50ms执行一次 self.image_subscriber = self.create_subscription( Image, '/image_raw', self.image_callback, 10 # 缓存队列大小 ) self.result_publisher = self.create_publisher(Image, '~/image_result', 10) # 图像处理结果发布 # 启动线程用于伺服电机控制 self.th = threading.Thread(target=self.move, daemon=True) self.th.start() |
① rospy.init_node(name): Initialize a ROS node. The node name is name.
② self.mpHands = mp.solutions.hands: Import hands module of the mp library.
③ self.hands = self.mpHands.Hands(...): Create a hand detection object configured with parameters such as whether to use static image mode, maximum number of hands, minimum confidence for detection and tracking.
④ self.mpDraw = mp.solutions.drawing_utils: Import the drawing tool module.
⑤ self.ak = ArmIK(): Create a ArmIK object, used for inverse kinematics computation.
⑥ self.last_time = time.time(): Record current time.
⑦ self.last_out = 0: Initialize a variable.
⑧ self.frames = 0: Initialize a frame counter.
⑨ self.window_size = 5: Define the size of the sliding window as 5.
self.distance_measurements = deque(maxlen=self.window_size): Create a double-ended queue to store the most recent distance measurement data, with a maximum capacity of 5 data points.
⑩ self.filtered_distance = 0: Initialize a filtered distance variable.
⑪ self.th = threading.Thread(target=self.move,daemon=True): Create a new thread to execute the move method and set it as a daemon thread.
⑫ self.th.start(): Start new thread.
⑬ self.name = name: Assign the passed name value to self.name.
⑭ self.image = None: Initialize a image variable to None.
⑮ rospy.Subscriber('/usb_cam/image_raw', Image, self.image_callback): Subscribe to the ROS topic named /usb_cam/image_raw with the message type Image. When a message is received, call the self.image_callback callback function.
⑯ self.result_publisher = rospy.Publisher('~image_result', Image, queue_size=1): Create a publisher that publishes on the ROS topic named ~image_result, with the message type Image and a queue size of 1.
Image Callback Function
86 87 88 89 90 91 92 93 94 95 96 97 98 99 | def image_callback(self, ros_image): """ 图像订阅回调,接收ROS图像消息并强制转换为RGB8格式的OpenCV图像 """ bridge = CvBridge() try: # 强制转换成 RGB8 格式 cv_image = bridge.imgmsg_to_cv2(ros_image, desired_encoding='bgr8') # 将图像保存在 self.image 变量中 self.image = cv_image except Exception as e: self.get_logger().info(f"Error converting image: {e}") |
A callback function named image_callback is defined to handle ROS image messages. It uses NumPy to create an array, converts ROS image data to RGB format, and stores it in the object’s image attribute.
Set the Initial State of Robotic Arm
102 103 104 105 106 107 108 109 | def init_arm(self): """ 初始化机械臂位置 """ setServoPulse(9, 1500, 300) setServoPulse(10, 800, 300) setServoPulse(11, 850, 300) time.sleep(0.3) |
Use setServoPulse function to control servo. Take setServoPulse(9,1500,300) as example here:
The first parameter 9 is servo ID; the second parameter 1500 is servo pulse-width; the third parameter 300 is the servo running time in ms.
Claw Movement Function
111 112 113 114 115 116 117 118 119 120 | def move(self): """ 伺服电机控制线程,根据手指之间的距离移动机械臂 """ while rclpy.ok(): if self.filtered_distance > 0 and self.filtered_distance < 100: out = np.interp(self.filtered_distance, [15, 90], [1500, 900]) setServoPulse(9, int(out), 0) else: time.sleep(0.01) |
Within the loop, the code checks if the value of self.filtered_distance is between 0 and 100. If it is, some operations are performed:
The Misc.map function is used to map self.filtered_distance to a new range, specifically mapping [15, 90] to [1500, 900]. This mapping is used to scale the measured distance between the two fingers into the range of control signals.
The setServoPulse function is called, passing the mapped value as a parameter to the servo motor. The function takes three parameters: the servo ID, the pulse width, and the time. Setting the time to 0 indicates that the servo will execute a single movement to the target position. This function is used to adjust the position of the claw servo motor.
If the value of self.filtered_distance is not between 0 and 100, the code sleeps for 0.001 seconds using rospy.sleep(0.001).
Main Function
130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 | bgr_image = cv2.cvtColor(image_re, cv2.COLOR_RGB2BGR) try: results = self.hands.process(image_re) if results.multi_hand_landmarks: for hand_landmarks in results.multi_hand_landmarks: # 绘制手部关键点连线 self.mpDraw.draw_landmarks(bgr_image, hand_landmarks, self.mpHands.HAND_CONNECTIONS) landmarks = get_hand_landmarks(image_re, hand_landmarks.landmark) # 计算拇指和食指尖之间的距离 cv2.line(bgr_image, (int(landmarks[4][0]), int(landmarks[4][1])), (int(landmarks[8][0]), int(landmarks[8][1])), (0, 255, 255), 2) cv2.circle(bgr_image, (int(landmarks[8][0]), int(landmarks[8][1])), 4, (0, 255, 255), -1) cv2.circle(bgr_image, (int(landmarks[4][0]), int(landmarks[4][1])), 4, (0, 255, 255), -1) # 计算手指尖的距离 distanceSum = distance(landmarks[8], landmarks[4]) distanceSum = max(15, min(distanceSum, 90)) self.distance_measurements.append(distanceSum) self.filtered_distance = np.mean(self.distance_measurements) self.filtered_distance = round(self.filtered_distance, 2) cv2.putText(bgr_image, 'DST: ' + str(self.filtered_distance), (5, 220), cv2.FONT_HERSHEY_PLAIN, 2, (255, 0, 255), 2) self.frames += 1 delta_time = time.time() - self.last_time cur_fps = np.around(self.frames / delta_time, 1) cv2.putText(bgr_image, 'FPS: ' + str(cur_fps), (5, 30), cv2.FONT_HERSHEY_PLAIN, 2, (255, 0, 255), 2) except Exception as e: self.get_logger().info(f"Error: {e}") # 发布处理后的图像 self.result_publisher.publish(cv2_image2ros(cv2.resize(bgr_image, (640, 480)), self.get_name(), self)) |
self.init(): The init method is called to perform some parameter settings and initialize ROS-related components.
The main loop while not rospy.is_shutdown() executes the loop as long as the ROS node is not shut down.
if self.image is not None: Check if there is image data available. If there is image data, perform the following operations:
① Image processing: First, flip the image horizontally. Resize the image to (320, 240). Clear the original image. Finally, convert the RGB format image to BGR format.
② Hand pose detection:
Perform hand pose detection using MediaPipe to obtain the coordinates of hand keypoints, then draw the hand keypoints and connecting lines on the image.
Calculate the distance between fingers, update the distance measurement list self.distance_measurements, compute the mean distance, update self.filtered_distance, and display the distance information on the image.
③ Compute the frame rate information: Record the frame count and calculate the frame rate, then display the frame rate information on the image.
④ Publish result image: self.result_publisher.publish(cv2_image2ros(cv2.resize(bgr_image, (640, 480)), self.name)): Publish the processed image via ROS.
33.11 Inverse Kinematics Analysis of Robotic Arm
33.11.1 Inverse Kinematics Introduction
Brief Introduction of Inverse Kinematics
Inverse kinematics is the process of determining the parameters of the joint movable object to be set to achieve the required posture.
The inverse kinematics of the robotic arm is an important foundation for its trajectory planning and control. Whether the inverse kinematics solution is fast and accurate will directly affect the accuracy of the robotic arm’s trajectory planning and control. So it is important to design a fast and accurate inverse kinematics solution method for a six-degree-of-freedom robotic arm.
Brief Analysis of Inverse Kinematics
For the robotic arm, the position and orientation of the gripper are given to obtain the rotation angle of each joint. The three-dimensional motion of the robotic arm is complicated. In order to simplify the model, we remove the rotation joint of the pan-tilt so that the kinematics analysis can be performed on a two-dimensional plane.
We simplify the model of the robotic arm by removing the XOY plane, leaving us with the main body of the arm. From the diagram, we can see that the coordinates of the end effector P of the gripper are (X, Y, Z). Since the robotic arm has no rotation, the coordinates of P can be written as (X, Z). In this case, theta and beta in the diagram represent the rotation angles of the robotic arm that we need to solve for. Based on this, we can formulate the following equations:
33.11.2 Inverse Kinematics Analysis of Robotic Arm
According to the structure design of the robot dog, we can determine that the length of l1 is 4.21 centimeters, the length of l2 is 3.3 centimeters, and the length of l3 is 12.7 centimeters. Therefore, the length of PA is √(l2² + l3²).
The source code of this program is stored at: /home/ubuntu/ros2_ws/src/driver/sdk/sdk/InverseKinematics.py
5 6 7 8 9 10 11 12 13 14 15 16 | from math import * class IK: #从下往上,最下面为第一个舵机(from bottom to top, the bottommost servo is considered the first servo) l1 = 4.21 #机械臂第一个舵机中心轴到第二个舵机中心轴的距离4.21cm,(the distance from the center axis of the first servo to the center axis of the second servo on the robotic arm is 4.21 cm) l2 = 3.3 #第二个舵机中心轴到爪子末端所在平面的距离3.3cm(the distance from the center axis of the second servo to the plane where the end of the gripper is located is 3.3 cm) l3 = 12.7 #第二个舵机中心轴垂直于爪子末端所在平面的交点到爪子末端的距离12.7cm(the distance from the intersection of the center axis of the second servo perpendicular to the plane where the end of the gripper is located to the end of the gripper is 12.7 cm) def __init__(self): # 舵机从下往上数(count the servos from bottom to top) l1 = 4.21 #机械臂第一个舵机中心轴到第二个舵机中心轴的距离4.21cm,(count the servos from bottom to top) l2 = 3.3 #第二个舵机中心轴到爪子末端所在平面的距离3.3cm(the distance from the center axis of the second servo to the plane where the end of the gripper is located is 3.3 cm) l3 = 12.7 #第二个舵机中心轴垂直于爪子末端所在平面的交点到爪子末端的距离12.7cm(the distance from the intersection of the center axis of the second servo perpendicular to the plane where the end of the gripper is located to the end of the gripper is 12.7 cm) |
33.11.3 Inverse Kinematics Solution and Program Implementation
(2) Click the icon
(3) Input the following command and press Enter to switch to the directory containing the inverse kinematics program file.
cd ros2_ws/src/driver/sdk/sdk
(4) Input the below command and press Enter to open the inverse kinematics program file.
vim InverseKinematics.py
(5) Here is a screenshot of the code for the InverseKinematics.py function.
The Calculation of the Pitch Angle beta
(1) According to the cosine theorem, calculate the value, then round it to four decimal places.
71 72 | cos_OAP = (pow(self.l1,2)+pow(PA,2)-pow(PO,2))/(2*self.l1*PA)#根据余弦定理(according to the law of cosines) cos_OAP = round(cos_OAP,4) #取四位小数点(take four decimal places) |
(2) Because the range of the cosine value is [-1, 1], check if the absolute value is greater than 1. If it is greater than 1, it means that the given end coordinates cannot form a linkage structure.
73 74 75 | if abs(cos_OAP) > 1: print('ERROR:不能构成连杆结构, abs(cos_OAP)为%s > 1' %(abs(cos_OAP)) ) return False# paste source code here. |
(3) Next, calculate the cos∠PAC value, and then round it to four decimal places.
77 78 | cos_PAC = (pow(self.l2,2)+pow(PA,2)-pow(self.l3,2))/(2*self.l2*PA)#根据余弦定理(according to the law of cosines) cos_PAC = round(cos_PAC,4) #取四位小数点(take four decimal places) |
(4) Check again whether the absolute value exceeds 1.
79 80 81 | if abs(cos_PAC) > 1: print('ERROR:不能构成连杆结构, abs(cos_PAC)为%s > 1' %(abs(cos_PAC))) return False |
(5) Next, use the inverse cosine function to find the angle in radians for both ∠OAP and ∠PAC, then add them together to get the angle for ∠OAC.
83 84 85 | OAP = acos(cos_OAP) PAC = acos(cos_PAC) OAC = OAP + PAC |
(6) Finally, convert the angle value of ∠OAC from radians to degrees, and subtract 90 degrees (initial pitch joint angle of the arm) to obtain the pitch joint angle beta rotation.
89 | beta = degrees(OAC) - 90 |
The Calculation of the Base Joint Angle theta
96 97 | cos_AOP = (pow(self.l1,2)+pow(PO,2)-pow(PA,2))/(2*self.l1*PO)#根据余弦定理(according to the law of cosines) cos_AOP = round(cos_AOP,4) #取四位小数点(take four decimal places) |
(2) Because the range of the cosine value is [-1, 1], check if the absolute value of cos∠AOP is greater than 1. If it is greater than 1, it means that the given end coordinates cannot form a linkage structure.
98 99 100 | if abs(cos_AOP) > 1: print('ERROR:不能构成连杆结构, abs(cos_AOP)为%s > 1' %(abs(cos_AOP))) return False |
(3) Then calculate the sin∠POB value, round it to four decimal places, and check again whether its absolute value is greater than 1.
102 103 104 105 | sin_POB = round(PB/PO,4) if abs(sin_POB) > 1: print('ERROR:不能构成连杆结构, abs(sin_POB)为%s > 1' %(abs(sin_POB)) ) return False |
(4) Next, use the inverse cosine function and the inverse sine function to find the radians of the angles ∠AOP and ∠POB, then add them together to obtain the value of the angle ∠AOB.
107 | AOB = acos(cos_AOP) + asin(sin_POB) #l1与x轴的夹角(the angle between l1 and the X-axis) |
(5) Finally, subtract the angle ∠OAB, converted to degrees, from 180 degrees to obtain the rotation angle of the base joint theta.
109 | theta = 180 - degrees(AOB) |
on the left upper corner to open the ROS2 Terminator terminal.
