19.ROS1_AI Large Model Courses
19.1 Large Language Model Courses
19.1.1 Overview of Large Language Model
Basic Concept
Features
Working Principle
Large Language Model (LLM) are built on deep learning principles and are trained using massive datasets and substantial computational resources to develop neural networks with billions of parameters. Through iterative training and parameter optimization, these models learn to perform a wide range of tasks with high accuracy. The large in LLM reflects their immense scale—encompassing a vast number of parameters, extensive training data, and significant computational demands. This scale enables advanced models to achieve superior generalization capabilities and deliver increasingly accurate results, even in highly specialized domains.
Application Scenarios
(1) Text Generation
(2) Text Classification
(3) Machine Translation
(4) Question-Answering Systems
19.1.2 Large Language Model Deployment
OpenAI Account Registration and Setup
(1) Copy the following URL: https://platform.openai.com/docs/overview
Open the OpenAI website and click on the Sign Up button in the top right corner.
(2) Follow the prompts to register and log in using your Google, Microsoft, or Apple account.
(3) Click on the settings icon, then select Billing, followed by Payment Methods, to link your payment method. Recharge your account to purchase tokens.
(4) After completing the setup, click on API Keys, then select Create New Secret Key. Follow the prompts to fill in the required information. Once the key is created, make sure to save it for future use.
(5) With these steps, the large model has been successfully created and deployed. You can now use the API in the upcoming lessons.
OpenRouter Account Registration and Setup
(1) Copy the following URL: https://openrouter.ai/
Open the webpage in your browser and click Sign In. Register using your Google account or another available login option.
(2) After logging in, click the icon in the top-right corner and select Credits to link your payment method.
(3) To create an API key, go to API Keys, then click Create Key. Follow the prompts to complete the process. Once the key is generated, make sure to save it for future use.
(4) At this point, the large model is successfully created and deployed. You can now use the API in the upcoming lessons.
19.1.3 Large Language Model Accessing
To proceed with this section, you will need to register on the appropriate website and obtain the API key for the large model (please refer to the file 19.1.2 Large Language Model Deployment).
Environment Configuration
sudo apt install vim
sudo apt install gedit
sudo apt install python3 python3-pip python3-all-dev python3-pyaudio portaudio19-dev libsndfile1
Importing the Large Model Program Directory
(1) In this section, locate the Appendix -> 3. Source Code folder within the same directory as this tutorial document.
(2) Using the MobaXterm remote connection tool (as outlined in the 3 Remote Tool Installation and Docker Entry Method -> 3.1. VNC Installation and Connection tutorial), drag the folder into the root directory of the main controller. The software installation package can be found in the 3 Remote Tool Installation and Docker Entry Method -> 3.1. VNC Installation and Connection directory.
(3) Next, execute the command to navigate to the speech_pkg directory.
cd ~/large_models/speech_pkg/
(4) Execute the following commands to install the necessary third-party libraries.
(5) Then, use the command in the terminal to navigate to the speech directory.
(6) Run the command to list the files in the speech directory.
(7) Depending on the type of main controller and Python version you’re using, switch to the appropriate folder for packaging and distribution. This tutorial uses the Jetson Orin controller as an example.
| Type of main controller | Python version |
| jetson_nano | 3.6 |
| jetson_orin | 3.10 |
| rpi5 | 3.11 |
| rpi5_docker | 3.8 |
(8) Execute the following command to navigate to the Jetson Orin folder.
cd jetson_orin/
(9) Enter the command to copy the speech.so file to the parent directory.
cp -r speech.so ..
(10) Enter the command to navigate to the parent directory.
cd ../..
(11) Execute the command to package the speech file for the Python environment.
pip3 install .
(12) Enter the command to install and update the OpenAI Python library.
pip3 install openai -U
Key Configuration
(1) Open the terminal and enter the following command to navigate to the directory for configuring the large model keys:
cd ~/large_models
(2) Then, open the configuration file by running:
vim config.py
(3) Once the file is open, configure the OpenAI and OpenRouter keys by filling in the llm_api_key and vllm_api_key parameters, respectively (you can obtain these keys from the 19.1.2 Large Language Model Deployment course).
For instance, copy the key created in Section 1.2 of this chapter and paste it into the appropriate field. To paste the key, place the cursor between the quotation marks, hold the Shift key, right-click, and select Paste
Do not mix keys from different models, as this may cause the functionality to malfunction.
(4) After pasting, press the Esc. key, then type the following command and press Enter to save the file:
Running the Demo Program
Once the keys are configured, you can run the demo program (openai_llm_demo.py) to experience the text generation capabilities of the large model. For example, the program’s prompt might be: Write a 50-word article about how technology is changing life.
(1) To run the demo, enter the following command in the terminal:
python3 openai_llm_demo.py
(2) After running the program, the output will appear as shown in the image below.
19.1.4 Semantic Understanding with Large Language Model
Before starting this section, make sure you have completed the API key configuration outlined in the file 19.1.3 Large Language Model Accessing.
cd large_models/
19.1.5 Emotional Perception with Large Language Model
To proceed with this section, ensure that you have completed the API key configuration as described in the file 19.1.3 Large Language Model Accessing.
cd large_models/
python3 openai_llm_er_demo.py
(4) In this program, we send two emotional expressions to the model: the first is an expression of sadness, So Sad. After the model responds, we then send an expression of happiness, Ha Ha, and observe how the model reacts.
19.2 Large Speech Model Courses
19.2.1 Overview of Large Speech Model
What is a Large Speech Model?
A Speech Large Model (LSM) refers to a machine learning model that uses deep learning techniques to process and understand speech data. These models can be applied in a variety of tasks, such as speech recognition, speech synthesis, speech translation, and emotional analysis of speech. The design and training of these models typically require large amounts of speech data and substantial computational resources, which is why they are referred to as large models.
Why Do We Need Large Speech Model?
Their advantages include:
(1) High Accuracy: They maintain a high recognition rate even in noisy environments and with various accents.
(2) Naturalness: Speech generated by synthesis models is more natural, closely resembling human speech.
(3) Versatility: These models support a wide range of languages and tasks, such as multilingual speech recognition, speech-to-text (STT), text-to-speech (TTS), and emotion recognition.
Development of Speech Recognition Technology
Phrase-Level Speech Recognition: With the expansion of data and advancements in algorithms, speech recognition systems gradually gained the ability to recognize longer phrases, such as Please turn on my computer.
Differences Between Large Speech Model and Traditional Speech Processing Technologies
(1) Processing Methods
(2) Model Complexity
(3) Recognition Capability
(4) Training Data Requirements
Core Technologies of Speech Large Model
(1) Automatic Speech Recognition (ASR)
(2) Text-to-Speech (TTS)
(3) Speech Enhancement and Noise Reduction
Applications of Speech Large Model
19.2.2 Voice Device Introduction and Testing
Device Overview
(1) WonderEchoPro
① Introduction
WonderEcho Pro, also known as the AI Voice Interaction Box, is equipped with a high-performance noise-canceling microphone and a high-fidelity speaker. It utilizes a USB-to-audio module, making it plug-and-play with no drivers required, and is compatible with multiple operating systems for both playback and recording.
Integrating various voice processing technologies, WonderEcho Pro features advanced noise suppression algorithms that effectively filter background noise from the environment. It supports a complete voice interaction process—from wake-up to recognition and response. With its modular design, each functional component (e.g., wake word detection, sound detection, speech recognition, and synthesis) can be developed and tested independently.
② Features and Specifications
Built-in microphone and speaker interface, supporting both audio input and output
Driver-free, plug-and-play functionality compatible with Windows, macOS, Linux, Android, and more
Standard USB 2.0 interface
Control interface: USB
Voice chip model: CL1302
Speaker output: 3.0W per channel (4Ω BTL)
Power supply voltage: 5V
① Introduction
Recording and Playback Test
(1) Connection Illustration and Detection
If the main controller is a Raspberry Pi, you can use VNC remote desktop access (refer to the appendix: 3 Remote Tool Installation and Docker Entry Method -> 3.1. VNC Installation and Connection) to log into the Raspberry Pi system. Once connected, check the upper right corner of the desktop for microphone and speaker icons. As shown in the image below, the presence of these icons indicates a successful connection.
(2) Recording Test
① Next, open a new terminal window and enter the following command to check the available recording devices. Note that the -l option is a lowercase L. You should see the card number (card) listed—for example, card 0. This is just an example; please refer to your actual query result.
arecord -l
② Then, use the following command to start recording. Replace the red-marked card number (hw:0,0) with the actual number you found in the previous step:
③ This will create a test.wav audio file in the current directory.
④ You can record a short 5-second sample, then press Ctrl + C to stop the recording.
(3) Playback Test
① After the recording is complete, you can check whether the audio file was successfully created by listing the contents of the current directory:
② If test.wav appears in the list, the recording was successful. To play back the recording, use the following command:
aplay test.wav
19.2.3 Voice Wake-Up
WonderEcho Pro Wake-Up
(1) Device Check
To proceed, we need to identify the USB device name assigned to the connected WonderEcho Pro or Circular Microphone Array (hereafter referred to as the voice device). Please follow the steps below carefully.
First, disconnect the voice device, then open a terminal and run the following command:
ll /dev | grep USB
Next, reconnect the voice device to the USB port on your main board and run the same command again:
ll /dev | grep USB
You should now see a newly listed USB port, such as ttyCH341USB1.
(2) Wake-Up Test
vim wakeup_demo.py
Press “i” to enter edit mode and make the necessary changes as shown below (update the port number accordingly and adjust comments as needed).
Once the changes are complete, press Esc., then type :wq and press Enter to save and exit the editor.
② Next, return to the system interface and run the wake-up demo using the command below. Speak the wake word HELLO HIWONDER clearly toward the WonderEcho Pro voice device.
If the output includes keyword detect, it indicates that the firmware has been successfully flashed and the wake word is functioning correctly.
6-Microphone Circular Array
(1) Device Check
(2) Wake-Up Test
② Press “i” to enter edit mode.
③ Update the port to match the device port number you previously identified. Comment out the WonderEcho Pro configuration (add # at the beginning of the corresponding line), and uncomment the line using the circular microphone array on line 11 as the input device (see red box in the referenced image).
④ Press Esc. to return to command mode, then type :wq and press Enter to save and exit.
⑥ After about 30 seconds of initialization, speak the wake word hello hiwonder to test the device.
Brief Program Overview
This is a Python-based wake word detection script that utilizes the speech module to process audio input and detect a specific wake word (e.g., HELLO_HIWONDER).
(1) Importing Required Modules
5 6 7 8 9 | import os import time from config import * from speech import awake from speech import speech |
(2) Initializing the wonderecho Class
9 10 11 | port = '/dev/ttyUSB0' kws = awake.WonderEchoPro(port) # kws = awake.CircleMic(port) |
(3) Attempts to Turn Off the Cooling Fan on Raspberry Pi 5
13 14 15 16 | try: # If a fan is present, it's recommended to turn it off before detection to reduce interference(如果有风扇,检测前推荐关掉减少干扰) os.system('pinctrl FAN_PWM op dh') except: pass |
(4) Main Wake Word Detection Loop
18 19 | kws.start() # Start detection(开始检测) print('start...') |
(5) Main Program Logic
20 21 22 23 24 25 26 27 28 29 30 31 | while True: try: if kws.wakeup(): # Wake-up detected(检测到唤醒) print('hello hiwonder') time.sleep(0.02) except KeyboardInterrupt: kws.exit() # Cancel processing (关闭处理) try: os.system('pinctrl FAN_PWM a0') except: pass break |
Extended Functionality
(1) Modifying the Wake-Up Response Text
① For example, if the wake word HELLO_HIWONDER is detected, and you’d like the program to print hello instead of the default message, follow the steps below. Navigate to the large_models directory and open the script with:
vim wakeup_demo.py
② Press “i” to enter INSERT mode (you’ll see -- INSERT -- at the bottom of the screen). Locate the line print('hello hiwonder'), and modify it to print('hello')
i
③ Press Esc., then type :wq and press Enter to save and exit.
python3 wakeup_demo.py
(2) Creating Custom Firmware for WonderEchoPro
If you’d like to create more advanced or customized wake words and voice commands, please refer to the document titled: Appendix → 1. Firmware Flashing Tool → Creating Firmware for WonderEchoPro.
19.2.4 Speech Recognition
What is Speech Recognition?
How It Works
Preparation Before the Experiment
Before proceeding, refer to the course 19.1.2 Large Language Model Deployment to obtain your API key, and make sure to add it into the configuration file (config).
Experiment Steps
(1) Power on the device and connect to it using MobaXterm.
For detailed instructions, please refer to 3 Remote Tool Installation and Docker Entry Method -> 3.1. VNC Installation and Connection.
(2) Navigate to the program directory by entering the following command:
cd large_models/
(3) Open the configuration file to input your API Key by entering the command below. Press “i” to enter INSERT mode and enter your API Key. Once finished, press Esc., type :wq, and hit Enter to save and exit.
vim config.py
(4) Run the speech recognition program with:
python3 openai_asr_demo.py
Function Realization
Brief Program Analysis
(1) Module Import
5 6 | from config import * from speech import speech |
(2) Define ASR Class
11 12 13 | asr = speech.RealTimeOpenAIASR() # whisper-1 fast than gpt-4o-transcribe asr.update_session(model='whisper-1', language='en', threshold=0.2, prefix_padding_ms=300, silence_duration_ms=800) |
(3) Speech Recognition Functionality
15 16 | print('start talking...') print(asr.asr()) |
Function Extension
(1) Enter the following command to edit the script:
vim openai_asr_demo.py
(2) Press the “i” key to enter INSERT mode, and update the model setting. For example, modify it to use the gpt-4o-transcribe model.
i
(3) Then, run the program with the command:
python3 asr_demo.py
(4) Record a sample sentence such as Hello, can you hear me clearly?, and the recognized text will be printed on the console.
19.2.5 Speech Synthesis
What is Speech Synthesis?
How It Works
Refer to the course 19.1.2 Large Language Model Deployment to obtain your API key, and update the configuration file accordingly.
Experiment Steps
(1) Power on the device and connect to it using MobaXterm (refer to the appendix 3 Remote Tool Installation and Docker Entry Method -> 3.1. VNC Installation and Connection for detailed guidance).
cd large_models/
(3) Open the configuration file to enter your API Key. After editing, press Esc., type :wq, and hit Enter to save and exit:
vim config.py
(4) Finally, run the program with the following command:
python3 openai_tts_demo.py
Upon running the program, it will play an audio message saying Hello, Can I Help You, and simultaneously save the audio file with the same content to the following directory: /home/ubuntu/large_models/resources/audio/
(1) Module Import
(2) Definition for TTS Class
8 9 10 11 | tts = speech.RealTimeOpenAITTS() tts.tts("Hello, Can I help you?") tts.tts("Hello, Can I help you?", model="tts-1", voice="onyx", speed=1.0, instructions='Speak in a cheerful and positive tone.') tts.save_audio("Hello, Can I help you?", model="gpt-4o-mini-tts", voice="onyx", speed=1.0, instructions='Speak in a cheerful and positive tone.', audio_format='wav', save_path="./resources/audio/tts_audio.wav") |
This line creates a real-time text-to-speech object named tts. The RealTimeOpenAITTS class is used to interact with the text-to-speech service.
(3) Function Extension
① Open the program by entering the command:
vim openai_tts_demo.py
② Press “i” on your keyboard to enter INSERT mode. Locate the line voice="onyx" and modify it to voice="nova".
i
③ Press Esc., then type :wq and hit Enter to save and exit.
④ Execute the program with the following command:
19.2.6 Voice Interaction
What is Voice Interaction?
How It Works
Experiment Steps
(1) Power on the device and connect to it via MobaXterm (refer to 3 Remote Tool Installation and Docker Entry Method -> 3.1. VNC Installation and Connection for connection guidance).
(2) To check the microphone’s port number, first disconnect the microphone and run the command. Then reconnect the microphone and run the command again to determine the port number
Do not connect any other USB devices during this process.
ll /dev | grep USB
Upon reconnecting the microphone, a USB port (e.g.,
ttyCH341USB1) will be listed (make sure to note this device name). The device name may vary depending on the main controller.
(3) Navigate to the program directory:
cd large_models/
(4) Open the configuration file to enter your API Key. After editing, press Esc., then type :wq and hit Enter to save and exit:
vim config.py
(5) Enter the port number you obtained and modify the corresponding microphone port settings for either WonderEcho Pro or the six-microphone setup. Uncomment the configuration for the port you intend to use and comment out the settings for any unused ports.
(6) Run the program:
(7) To stop the program at any time, simply press Ctrl+C.
After successful execution, the voice device will announce I’m ready. Then, upon hearing the wake-up word HELLO_HIWONDER, the device will respond with I’m here, indicating that the assistant has been successfully awakened. You can now ask the AI assistant any questions:
For example: What are some fun places to visit in New York?
(1) Module Import
11 12 13 14 15 16 17 18 19 20 21 22 | wakeup_audio_path = './resources/audio/en/wakeup.wav' start_audio_path = './resources/audio/en/start_audio.wav' no_voice_audio_path = './resources/audio/en/no_voice.wav' port = '/dev/ttyUSB0' kws = awake.WonderEchoPro(port) # kws = awake.CircleMic(port) asr = speech.RealTimeOpenAIASR() asr.update_session(model='whisper-1') tts = speech.RealTimeOpenAITTS() client = speech.OpenAIAPI(llm_api_key, llm_base_url) |
(3) Main Functional Logic
33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 | def main(): kws.start() while True: try: if kws.wakeup(): # Wake word detected(检测到唤醒词) speech.play_audio(wakeup_audio_path) # Play wake-up sound(唤醒播放) asr_result = asr.asr() # Start voice recognition(开启录音识别) print('asr_result:', asr_result) if asr_result: # Send the recognition result to the agent for a response(将识别结果传给智能体让他来回答) response = client.llm(asr_result, model='gpt-4o-mini') print('llm response:', response) tts.tts(response) else: speech.play_audio(no_voice_audio_path) time.sleep(0.02) except KeyboardInterrupt: kws.exit() try: os.system('pinctrl FAN_PWM a0') except: pass break except BaseException as e: print(e) |
19.3 Vision Language Model Courses
19.3.1 Overview of Vision Language Model
Basic Concept
Features
Powerful Visual-Semantic Understanding: With extensive knowledge accumulated from large-scale visual datasets, VLM excel at tasks such as object detection, classification, and image captioning.
How It Works
(1) Image Captioning
(2) Visual Question Answering
Users can ask questions related to an image, such as What is in this picture? or What color is the car? The model analyzes the image content and provides accurate, natural-language responses, making it highly applicable in fields such as education, customer support, and information services.
(3) Image Retrieval
(4) Augmented Reality (AR)
(5) Content Creation and Editing
(6) Social Media Interaction
(7) Medical Imaging Analysis
19.3.2 Vision Language Model Accessing
This section requires the configuration of the API key in 19.3.2 Vision Language Model Accessing before proceeding. Additionally, ensure that the images to be used in this section are imported.
This experiment requires either an Ethernet cable or Wi-Fi connection to ensure the main control device can access the network properly.
Experiment Steps
(1) Execute the following command to navigate to the directory of Large Model.
cd large_models/
(2) Run the program:
After running the program, the output printed matches our request of Describe the image.
19.3.3 Vision Language Model: Object Detection
In this course, we will use a program to transmit an image to the large model for recognition, which will then identify and locate the objects within the image by drawing bounding boxes around them.
Experiment Steps
cd large_models/
Function Expansion
(1) Change Pictures
② Then, input the command:
③ Press the “i” key on your keyboard, which will display INSERT at the bottom.
i
To: image = cv2.imread('./resources/pictures/apples.png')
19.3.4 Vision Language Model: Scene Understanding
In this course, we will use a program to send an image to the large model for recognition and generate a description of the content within the image.
Experiment Steps
cd large_models/
Function Expansion
(1) First, drag your image directly into the ~/large_models/resources/pictures/ path using MobaXterm, and rename the image to test.png.
(2) Then, open the scene understanding script by entering the following command in the terminal:
(3) Change the image path in the code to reflect the name of your image (e.g., test.png).
(4) Run the program:
19.3.5 Vision Language Model: Optical Character Recognition
In this course, we use a program to transmit an image to the large model for recognition, extracting and identifying the text within the image.
Experiment Steps
cd large_models/
python3 openai_vllm_ocr.py
Function Expansion
(1) Change Pictures
① Drag the image directly into the ~/large_models/resources/pictures/ path using MobaXterm. Here, we can drag in the image named ocr1.png as an example, and let the program recognize the text COME ON.
i
To: image = cv2.imread('./resources/pictures/ocr1.png')
⑤ Run the program:
19.4 Multimodal Model Courses
19.4.1 Overview of Multimodal Model
Basic Concept
Features
How It Works
(1) Education
(2) Healthcare
(3) Entertainment
(4) Advertising and Marketing
19.4.2 Agent Behavior Orchestration
The purpose of this course experiment is to obtain data in a specified format returned by the large model based on the prompt words set in the model. During development, you can use the returned data for further tasks.
Experiment Steps
(1) To check the microphone’s port number, first disconnect the microphone and run the command. Then reconnect the microphone and run the command again to determine the port number
ll /dev | grep USB
(2) Execute the following command to navigate to the directory of Large Model.
cd large_models/
(3) Open the configuration file to enter your API Key. After editing, press Esc., then type :wq and hit Enter to save and exit:
vim config.py
(4) Fill in the detected port number and update the corresponding microphone port settings for either the WonderEcho Pro or the Six-channel Microphone.
vim openai_agent_demo.py
(5) Run the program:
python3 openai_agent_demo.py
(6) The program will print the prompts configured for the large model. The large model will then return data formatted according to these prompts.
(1) After running the program, the voice device will announce, I’m ready. At this point, say HELLO_HIWONDER to the device to activate the agent.
When the device responds with I’m here, it indicates that the agent has been successfully awakened. To modify the wake word. For the Six-channel Microphone, refer to 19.2.3 Voice Wake-Up for instructions on customizing the wake word. For WonderEcho Pro, refer to the section Appendix -> 1. Firmware Flashing Tool -> WonderEchoPro Firmware Generation.
(2) After updating the wake word, you can say: Take two steps forward, turn left and take one step back. The agent will respond according to the format we have defined.
19.5 Multimodal Model Applications
19.5.1 Obtaining and Configuring the Large Model API Key
(1) OpenAI Registration
① Visit the following link to access the OpenAI platform: https://platform.openai.com/docs/overview, and sign up.
② You can register using your Google, Microsoft, or Apple account as prompted.
③ Once registered, click on the Settings icon, navigate to Billing, and then select Payment Methods to add a payment option. This is required to purchase tokens.
④ After setting up your billing information, go to the API Keys section, click Create New Secret Key, and follow the on-screen instructions. Be sure to save the key for future use.
With these steps completed, you’ve successfully created and deployed your large model API key, which will be used in the upcoming course sessions.
(2) Deploying the API Key
The program’s configuration file is located within the Docker container at: /home/ubuntu/puppypi/src/large_models/scripts/config.py
① Use the following command and press Enter to navigate to the directory containing the configuration file:
cd /home/ubuntu/puppypi/src/large_models/scripts
② Enter the following command to open the configuration file and insert the OpenAI key:
gedit config.py
OpenRouter API Configuration
(1) Visit the following link to access the OpenAI platform: https://openrouter.ai/
Click on Login and use your Google account or another supported account to register or log in.
(2) After logging in, click on the icon in the top-right corner, select Credits, and link your payment method.
(3) To create an API key: Navigate to API Keys and click Create Key. Then follow the prompts to generate your API key, and make sure to save it for future use.
(4) Use the following command and press Enter to navigate to the directory containing the configuration file:
(5) Open the configuration file using the following command, then paste your OpenRouter API key into it:
gedit config.py
19.5.2 Multimodal Model: Voice Control
Brief Game Instructions
Once the program starts running and WonderEcho Pro announces I am ready.
Say the wake-up word (the wake-up word depends on the firmware flashed, and by default, the wake-up word for our factory firmware is Hello, HiWonder) to activate WonderEcho Pro. It will respond with I am here.
You can then control PuppyPi using voice commands—for example, say, Hello, please take two steps forward. After the command is recognized, the terminal will display the detected speech, the system will respond verbally, and PuppyPi will carry out the requested action.
(1) Verifying the WonderEcho Pro Firmware
By default, the wake-up word for the WonderEcho Pro factory firmware is Hello, Hiwonder. If you wish to change the wake-up word to PuppyPi, please refer to the tutorial titled 12. ROS AI Voice Interaction Courses -> 12.1 Introduction to WonderEcho Pro and Installation -> 12.1.6 Firmware Flashing Method for step-by-step instructions.
(2) Obtaining and Configuring the Large Model API Key
By default, the program does not include the configuration of the Large AI Model-related API keys. Before activating features related to the Large AI Model, please refer to the section 19.5.1 Obtaining and Configuring the Large Model API Key to configure the necessary keys. This step is mandatory and cannot be skipped, as it is crucial for the proper functioning and experience of the large model features.
(3) Network Configuration
The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet. For detailed instructions on network configuration, please refer to the course 3.5 Network Configuration Instructions
Starting and Stopping the Game
The input commands must strictly observe case sensitivity and spacing.
(1) Power on the robot and remotely connect to the Raspberry Pi desktop via VNC.
(2) Double-click the Terminator icon on the Raspberry Pi desktop
(3) Then, input the command to disable the auto-start service:
(4) Then, input the command to start the game:
roslaunch large_models multimodel_large_models.launch
(5) Once the command line outputs the message below and the device announces I am ready, it indicates that the voice device has been initialized. You can now say the wake word, hello hi wonder.
(6) When the following output appears in the command line, WonderEcho Pro will announce I am Here, indicating that WonderEcho Pro has been successfully activated. At this point, the system will begin recording the user’s command.
You can freely express your commands to control PuppyPi’s movements—for example, Take three steps forward, two steps back, then do a push-up. When the command line shows the output below, it indicates that the cloud-based large speech model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under publish_asr_result.
(7) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (response), as well as designed an action that aligns with the user’s command meaning.
The response is automatically generated by the large model, ensuring the accuracy of the meaning, though the wording and structure of the reply may vary.
(8) When the command line shows the output as pictured below, it means the current interaction has ended. You can then say the wake-up phrase Hello, HiWonder to initiate a new conversation.
(9) To exit this feature, simply press Ctrl+C in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
How It Works
Once the game is activated, we can freely give commands to control PuppyPi, instructing it to perform the following actions either individually or in sequence.
| NO. | Actions | NO. | Actions |
| 1 | Stand: stand() |
10 | Sit:sit() |
| 2 | Move a step forward: forward() |
11 | kick_ball_left/right() |
| 3 | Move backward: Step backwards: back() |
12 | Dance: moonwalk() |
| 4 | Turn left: turn_left() |
13 | Lie down: lie_down() |
| 5 | Turn right: turn_right() |
14 | Have a good stretch: temp() |
| 6 | Box: boxing() |
15 | Bow: bow() |
| 7 | Push up: push_up() |
16 | Kick red ball: kick_ball('red') |
| 8 | Handshake: shake_hands() |
17 | Trace red line: visual_patrol('red') |
| 9 | Nod: nod() |
18 |
For the rules governing text responses and action design by the large model, please refer to the prompt settings within the program. Detailed instructions can be found in the PROMPT section of /home/ubuntu/puppypi/src/large_models/scripts/function_call.py.
(1) Main Control Program Analysis
The launch file is saved in: /home/ubuntu/puppypi/src/large_models/launch/multimodal_large_models.launch
<launch>
<include file="$(find lab_config)/launch/lab_config_manager.launch" />
<!-- Include other launch files -->
<include file="$(find large_models)/launch/start.launch" />
<!-- Launch the visual_patrol node -->
<pause duration="5.0"/>
<node pkg="large_models" type="visual_patrol_demo.py" name="visual_patrol_demo" output="screen"/>
<!-- Launch the kick_ball node -->
<node pkg="large_models" type="kick_ball_demo.py" name="kick_ball_demo" output="screen"/>
<!-- Launch the function_call node -->
<node pkg="large_models" type="function_call.py" name="function_call" output="screen"/>
</launch>
Initialize Core Services
Launch the following files to start essential services:
lab_config_manager: Handles color configuration.
ros_robot_controller_node: Manages robot control functions.
usb_cam: Starts the camera service.
start: Initializes additional components such as speech recognition and synthesis nodes.
Start the Line-Following Node
The visual_patrol node activates the line-following functionality. Control requests—such as entering the mode, setting the target color, and starting the task—are sent via the function_call node.
Start the Ball-Kicking Node
The kick_ball node launches the ball-tracking and kicking feature. Similar to the patrol function, it is managed through the function_call node, which sends requests to enter the mode, configure target color, and initiate execution.
Start the Main Control Node
The function_call node serves as the central control module for the multimodal model. It coordinates multiple subsystems, including speech recognition, speech synthesis, and robot action execution.
(2) Overview and Code Analysis of the Main Control Logic
The main processing program is located at: /home/ubuntu/puppypi/src/large_models/scripts/function_call.py.
Library Files Import
Import the required modules for operating PuppyPi, including those for control services, large language model integration, and voice processing.
6 7 8 9 10 11 12 13 14 15 16 | import time import math import rospy import threading from config import * from speech import speech from std_msgs.msg import String, Bool from puppy_control.srv import SetRunActionName from large_models.srv import SetModel, SetString from std_srvs.srv import Trigger, Empty, SetBool from puppy_control.msg import Velocity, Pose, Gait |
Create a Publisher
135 136 137 138 139 | # Create topic publishers (创建话题发布者) self.tts_text_pub = rospy.Publisher('/tts_node/tts_text', String, queue_size=1) self.pose_publisher = rospy.Publisher('/puppy_control/pose', Pose, queue_size=10) self.gait_publisher = rospy.Publisher('/puppy_control/gait', Gait, queue_size=10) self.velocity_publisher = rospy.Publisher('/puppy_control/velocity', Velocity, queue_size=10) |
Set up multiple publishers dedicated to handling TTS (text-to-speech), posture control, gait coordination, and speed adjustment.
Create service proxies and clients as follows:
144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 | # Create service proxies (创建服务代理) self.cli = rospy.ServiceProxy('/puppy_control/go_home', Empty) self.set_model_client = rospy.ServiceProxy('/agent_process/set_model', SetModel) self.set_prompt_client = rospy.ServiceProxy('/agent_process/set_prompt', SetString) self.awake_client = rospy.ServiceProxy('/vocal_detect/enable_wakeup', SetBool) rospy.Subscriber('/tts_node/play_finish', Bool, self.play_audio_finish_callback) rospy.Subscriber('/agent_process/result', String, self.llm_result_callback) self.run_action_group_srv = rospy.ServiceProxy('/puppy_control/runActionGroup', SetRunActionName) # kick_ball client (kick_ball 客户端) self.enter_client_kick_ball = rospy.ServiceProxy('/kick_ball_demo/enter', Trigger) self.start_client_kick_ball = rospy.ServiceProxy('/kick_ball_demo/enable_running', SetBool) self.set_target_client_kick_ball = rospy.ServiceProxy('/kick_ball_demo/set_color_target', SetString) # visual_patrol client (visual_patrol 客户端) self.enter_client_visual_patrol = rospy.ServiceProxy('/visual_patrol_demo/enter', Trigger) self.start_client_visual_patrol = rospy.ServiceProxy('/visual_patrol_demo/enable_running', SetBool) self.set_target_client_visual_patrol = rospy.ServiceProxy('/visual_patrol_demo/set_color_target', SetString) |
19.5.3 Multimodal Model: Ball Tracking and Shooting
When the program starts, WonderEcho Pro announces I am ready and immediately begins monitoring the surrounding environment for sounds.
You can then control PuppyPi using voice commands—for example, saying Kick the red ball. Once the command is recognized, the terminal will display the detected input, a thoughtful response will be generated and spoken, and the kick-ball routine will be executed in real time.
The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet. For detailed instructions on network configuration, please refer to the course 3.5 Network Configuration Instructions.
on the Raspberry Pi desktop to open the command-line terminal.
(7) You can freely organize your language and issue commands to control PuppyPi to start tracking and kicking the ball, such as kick the red ball away. When the command line shows the output below, it indicates that the cloud-based large speech model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under publish_asr_result.
(8) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (response), as well as designed an action that aligns with the user’s command meaning.
(9) When the command line shows the output as pictured below, it means the current interaction has ended. You can then say the wake-up phrase Hello, HiWonder to initiate a new conversation.
(10) To exit this feature, simply press Ctrl+C in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
How It Works
After the mode is activated, you can control PuppyPi to autonomously kick the ball using voice commands. If the target-colored ball is not detected within three seconds, or after the ball has been successfully kicked, PuppyPi will automatically exit Kick Ball mode. You’re free to phrase your commands naturally, allowing PuppyPi to perform the following actions either individually or in sequence.
10 | Sit:sit() |
11 | Left/ right foot kick: kick_ball_left/right() |
| 3 | Step backwards: back() |
| 6 | Box: boxing() |
15 | Bow: bow() |
| 9 | Nod: nod() |
18 |
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 | <launch> <include file="$(find lab_config)/launch/lab_config_manager.launch" /> <!-- Include other launch files --> <include file="$(find large_models)/launch/start.launch" /> <!-- Launch the visual_patrol node --> <pause duration="5.0"/> <node pkg="large_models" type="visual_patrol_demo.py" name="visual_patrol_demo" output="screen"/> <!-- Launch the kick_ball node --> <node pkg="large_models" type="kick_ball_demo.py" name="kick_ball_demo" output="screen"/> <!-- Launch the function_call node --> <node pkg="large_models" type="function_call.py" name="function_call" output="screen"/> </launch> |
Create a Publisher
19.5.4 Multimodal Model: Autonomous Cruise
You can then control PuppyPi using voice commands—for example, saying Follow the black line. Once the command is recognized, the terminal will display the detected input, a thoughtful response will be generated and spoken, and the kick-ball routine will be executed in real time.
(7) You can freely express your commands to control PuppyPi’s movements—for example, Walk forward with big steps along the black line. When the command line shows the output below, it indicates that the cloud-based large speech model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under publish_asr_result.
(9) When the output shown below appears in the command line, it indicates that the current round of interaction has concluded. You can now use the wake word to reactivate WonderEcho Pro and begin a new conversation cycle.
How It Works
Once the activity is activated, you can freely issue voice commands—for example, Walk forward with big steps along the black line—to guide PuppyPi in autonomous cruising mode. In this mode, PuppyPi can follow a black line or other predefined paths. If it fails to detect the guiding line for more than 3 seconds, it will automatically exit autonomous cruising and return to standby, ready to be reactivated with a new command.
Create a Publisher
Create multiple service clients:
① awake_client: wake up PuppyPi
② kick_ball: Service client to initiate the kick ball routine
③ visual_patrol: Service client to start the visual line-following service
Main Loop
① Extract actions and response text from the large model’s results.
209 210 211 212 213 214 215 216 | if 'action' in self.llm_result: self.result = eval(self.llm_result[self.llm_result.find('{'):self.llm_result.find('}') + 1]) if 'action' in self.result: action_list = self.result['action'] if 'response' in self.result: response = self.result['response'] else: response = self.result |
② Publish TTS text for voice synthesis
220 221 222 223 | # Publish TTS text (发布 TTS 文本) response_msg = String() response_msg.data = response self.tts_text_pub.publish(response_msg) |
③ Execute corresponding actions according to the responses returned by the large language model.
228 229 230 231 232 233 234 235 236 237 | # Execute action list (执行动作列表) for a in action_list: if a == "forward": self.set_move(x=15.0) time.sleep(1.05) self.set_move(x=0.0) elif a == "back": self.set_move(x=-5.0) time.sleep(1.05) self.set_move(x=0.0) |
④ The goal of this lesson is to send service requests to the visual_patrol_demo node to initiate the activity mode, set the target color, and start the line-following task.
256 257 258 259 260 261 262 263 264 | elif a.startswith("visual_patrol("): # Handle visual patrol action (处理视觉巡逻动作) color = a.split("'")[1] self.enter_client_visual_patrol() self.set_target_client_visual_patrol(color) self.start_client_visual_patrol(True) |
(3) Program Analysis
The program is located at: /home/ubuntu/puppypi/src/large_models/scripts/visual_patrol_demo.py
Program Initialization
Initialize the system by publishing PuppyPi’s initial state and gait configuration.
88 89 90 91 92 93 94 95 | # 初始位置(initial position) def initMove(delay=True): global GaitConfig PuppyMove['x'] = 0 PuppyMove['yaw_rate'] = math.radians(0) PuppyVelocityPub.publish(x=PuppyMove['x'], y=PuppyMove['y'], yaw_rate=PuppyMove['yaw_rate']) rospy.sleep(0.2) rospy.ServiceProxy('/puppy_control/go_home', Empty)() |
Movement Control
PuppyPi adjusts its direction based on the difference between the X-coordinate of the detected line and the center X-coordinate of the image (self.line_centerx - self.img_centerx), enabling it to follow the line accurately.
115 116 117 118 119 120 121 122 123 124 125 126 | def move_robot(error): if abs(error) <= 20: PuppyMove['x'] = 10 PuppyMove['yaw_rate'] = math.radians(0) elif error > 50: PuppyMove['x'] = 8 PuppyMove['yaw_rate'] = math.radians(-15) elif error < -50: PuppyMove['x'] = 8 PuppyMove['yaw_rate'] = math.radians(15) else: time.sleep(0.02) PuppyVelocityPub.publish(x=PuppyMove['x'], y=PuppyMove['y'], yaw_rate=PuppyMove['yaw_rate']) |
Main Program Workflow
① Initialize the ROS node using rospy.init().
② Wait for the parameter server to start and retrieve posture-related parameters for PuppyPi.
③ Set up a subscriber to process image data from the camera, and a publisher to control PuppyPi’s movement parameters such as velocity and posture.
④ Create additional publishers to send processed images with target annotations (image_result) and to broadcast the robot’s operational states, including gait, speed, and posture.
⑤ Upon completion, ensure a clean shutdown of the node and release system resources.
19.6 Embodied AI Applications
19.6.1 Embodied AI Applications in Robotic Watchdog
In this lesson, you will learn how to use a large AI model to detect and analyze real-time environments for implementing the watchdog function.
While using this mode, you can freely issue commands to PuppyPi to check for obstacles. Upon detecting any, PuppyPi can perform specified actions such as sounding an alert or executing a predefined gesture. For example: I’m about to go out. Please check for any obstacles. If there are any, make a sound and do a push-up to alert me.
(2) On the Raspberry Pi desktop, double-click the Terminator icon
to open the command-line terminal and enter the ROS1 development environment.
(4) Enter the command and press the Enter key to start the game:
roslaunch large_models vllm_watch_dogs.launch
(5) Once the system starts successfully, PuppyPi will say, I am ready, and show the live camera feed. To activate the large AI model, simply say the wake phrase, Hello, Hiwonder. The robot will respond with, I am Here, confirming it is ready to interact.
While using this mode, you can freely issue commands to control PuppyPi. Upon detecting any, PuppyPi can perform specified actions such as sounding an alert or executing a predefined gesture. For example: I’m about to go out. Please check if there are any obstacles. If there are, make a sound and do a push-up to alert me.
(7) When the command line displays the output shown below, it indicates that the Raspberry Pi has successfully accessed the cloud-based speech recognition service powered by the large language model. The message publish vllm result represents the recognized result of the user’s voice command. Object: Identifies the current obstacle.
Action: Executes the corresponding movement based on the given command.
Response: Plays the appropriate voice feedback.
(8) When the output shown below appears in the command line, it indicates that the current round of interaction has concluded. You can now use the wake word to reactivate WonderEcho Pro and begin a new conversation cycle.
How It Works
(1) Once the program starts running and WonderEcho Pro announces I am ready.
To activate WonderEcho Pro, simply say the wake word Hello, Hiwonder. The device will respond with the voice prompt, I am here.
(2) Upon recognizing the speech, the system retrieves an image from the image queue and passes both the recognition result and the image to the agent for response generation.
(3) You can then control PuppyPi using voice commands such as: I’m about to go out. Please check for any obstacles. If there are any, make a sound and do a push-up to alert me.
WonderEcho Pro will analyze the command, provide a spoken response, and carry out the appropriate actions accordingly.
For the rules governing text responses and action design by the large model, please refer to the prompt settings within the program. Detailed instructions can be found in the PROMPT section of /home/ubuntu/puppypi/src/large_models/scripts/vllm_watch_dogs.py.
The actions available in this mode are predefined within the program library and are limited in number. The core mechanism for controlling PuppyPi’s movements relies on action strings (function names) generated by the large AI model. These strings are used to call corresponding executable functions from the library. If a user command involves a behavior that is not predefined for PuppyPi, the AI model may generate an unsupported action string. In such cases, the program will not be able to execute the action, and the robot will not perform the requested movement.
(1) Analysis of Python Files
The program’s configuration file is located within the Docker container at: /home/ubuntu/puppypi/src/large_models/scripts/vllm_watch_dogs.py
Feature Package Import
① Use the import statement to include necessary modules and custom libraries. Examples include:
② cv_bridge: Converts ROS image messages to OpenCV format.
③ PuppyControlNode: A robot control class responsible for executing predefined actions.
④ speech: A speech module that provides Text-to-Speech (TTS) functionality.
⑤ SetString and SetRunActionName: Custom ROS services for configuring the language model and controlling actions.
⑥ rclpy: The Python client library for ROS 2, used to create and manage ROS nodes.
⑦ sensor_msgs and std_msgs: Message types for subscribing to image data and publishing string data, respectively.
6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 | import os import cv2 import sys import math import json import time import rospy import queue import threading from config import * from speech import speech from cv_bridge import CvBridge from sensor_msgs.msg import Image from action import PuppyControlNode from std_msgs.msg import String, Bool from puppy_control.srv import SetRunActionName from std_srvs.srv import SetBool, Trigger, Empty from large_models.srv import SetModel, SetString, SetStringRequest |
Global Prompt
Depending on the system language setting, corresponding instructions in Chinese or English define the model’s input-output format and behavior rules:
If an obstacle is detected: identify the object by name, provide a safety alert, and execute the appropriate action. If no obstacle is detected: return the message “No obstacles”.
152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 | PROMPT = ''' **Role: You are an intelligent robot assistant capable of real-time image recognition of obstacles. Based on the following rules, you must output the identified object and related tips in the response. **Rules: 1. If an obstacle is detected: object: Return the name of the detected item. response: Inform the user where the obstacle is and give a friendly safety reminder. If the instruction includes multiple actions, include all specified actions in the action array in the same order as mentioned in the instruction. Function names in action must be selected from the following list: - stand(): Stand - boxing(): Punch - push_up(): Push-up - shake_hands(): Shake hands - nod(): Nod - sit(): Sit - kick_ball_left(): Kick left foot - kick_ball_right(): Kick right foot - moonwalk(): Dance - lie_down(): Lie down - temp(): Stretch - bow(): Cutesy gesture - man(): Bark / make a noise Example 1: Input: Check if there are any obstacles. If there are, make a sound to alert me. Output:{ "type": "detect", "object": "Obstacle Name", "action": ["man()"], "Play": ["detect"], "response": "There is an obstacle at the door. I'll make a sound to alert you—please be careful!" } |
Subscriptions and Services:
Subscribe to image data and results from the large language model as needed.
240 241 242 | rospy.Subscriber('/usb_cam/image_raw', Image, self.image_callback) rospy.Subscriber('/agent_process/result', String, self.vllm_result_callback) rospy.Subscriber('/tts_node/play_finish', Bool, self.play_audio_finish_callback) |
Initialize Language Model and Actions:
Set Prompt: Send customizable instruction prompts to the large language model via service calls.
Load Model: Specify and load the desired model, such as vllm or others.
Start Image Processing Thread: Begin image processing by calling the appropriate method (e.g., process()).
264 265 266 267 268 269 270 271 272 273 274 275 276 277 | def init_process(self): if os.environ['ASR_LANGUAGE'] == 'Chinese': self.set_model_client(stepfun_vllm_model, 'vllm', stepfun_api_key, stepfun_base_url) else: self.set_model_client(vllm_model, 'vllm', vllm_api_key, vllm_base_url) self.set_prompt_client(PROMPT) # Run initial actions (运行初始动作) try: runActionGroup('look_down.d6ac', True) rospy.loginfo("运行初始动作: look_down.d6ac") except Exception as e: rospy.logerr("运行初始动作失败: %s" % e) |
Image Processing:
Image Conversion: Convert incoming ROS Image messages into OpenCV format or another desired format.
Queue Management: Manage image frames in a queue, discarding older frames to maintain real-time responsiveness.
393 394 395 396 397 398 399 400 401 402 403 404 | def image_callback(self, ros_image): """Image callback: convert ROS Image to OpenCV image and enqueue (图像回调函数,将 ROS Image 转换为 OpenCV 图像并放入队列)""" try: # Use cv_bridge to convert ROS Image to OpenCV image (使用 cv_bridge 将 ROS Image 转换为 OpenCV 图像) rgb_image = self.bridge.imgmsg_to_cv2(ros_image, desired_encoding='bgr8') if self.image_queue.full(): # If queue is full, discard the oldest image (如果队列已满,丢弃最旧的图像) discarded = self.image_queue.get() # Enqueue the image (将图像放入队列) self.image_queue.put(rgb_image) except Exception as e: rospy.logerr("处理图像时出错: %s" % e) |
Handle Language Model Results and Execute Actions:
Store the model’s response (e.g., in JSON format), parse action commands to control PuppyPi or other devices, and provide feedback through the TTS module or other output methods.
304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 | def handle_vllm_result(self): """Logic to process VLLM results, including action parsing and response publishing (处理 VLLM 结果的逻辑,包括动作解析和响应发布)""" if not self.vllm_result: rospy.logwarn("VLLM 结果为空,跳过处理") return try: # Extract and parse JSON string (提取 JSON 字符串并解析) start = self.vllm_result.find('{') end = self.vllm_result.rfind('}') + 1 if start == -1 or end <= start: raise ValueError("无效的 JSON 格式") result_json = self.vllm_result[start:end] result = json.loads(result_json) rospy.loginfo("解析后的 JSON: %s" % result_json) |
Processing Loop:
Continuously retrieve and process images from the queue on a frame-by-frame basis.
Display or handle processed images using OpenCV or an alternative visualization tool.
373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 | def process(self): """Image processing thread (图像处理线程)""" rospy.loginfo("图像处理线程已启动。") while not rospy.is_shutdown() and self.running: try: image = self.image_queue.get(block=True, timeout=1) # Display image (显示图像) cv2.imshow('image', image) if cv2.waitKey(1) & 0xFF == ord('q'): self.running = False rospy.loginfo("检测到 'q' 按键,关闭图像窗口。") break except queue.Empty: continue except Exception as e: rospy.logerr("处理图像时出错: %s" % e) cv2.destroyAllWindows() rospy.loginfo("图像处理线程已结束。") |
(2) Analysis of launch File
The launch file is saved in: /home/ubuntu/puppypi/src/large_models/launch/vllm_watch_dogs.launch
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 | <launch> <!-- 启动 vocal_detect 节点 --> <include file="$(find large_models)/launch/vocal_detect.launch" /> <!-- 启动 agent_process 节点 --> <include file="$(find large_models)/launch/agent_process.launch" /> <!-- 启动 tts_node 节点 --> <include file="$(find large_models)/launch/tts_node.launch" /> <!-- 启动 puppy_control 节点 --> <node name="puppy_control" pkg="puppy_control" type="puppy.py" required="false" output="screen" /> <!-- 启动 vllm_with_camera.py 节点 --> <node name="vllm_watch_dogs" pkg="large_models" type="vllm_watch_dogs.py" required="false" output="screen" /> <!-- 启动 USB 摄像头节点 --> <arg name="camera_name" default="usb_cam" /> <node name="$(arg camera_name)" pkg="usb_cam" type="usb_cam_node" respawn="true" respawn_delay="2" output="screen"> <param name="video_device" value="/dev/video0" /> <param name="image_width" value="640" /> <param name="image_height" value="480" /> <param name="pixel_format" value="yuyv" /> <param name="camera_frame_id" value="$(arg camera_name)" /> <param name="io_method" value="mmap"/> </node> </launch> |
Voice Detection Node
The vocal_detect.launch file starts the voice detection program. This program listens for a predefined wake word to activate the agent and converts incoming audio into text for publication.
Semantic Understanding Node
The agent_process.launch file starts the semantic understanding program. It subscribes to the text output from the voice detection node, processes the input to interpret user intent, and publishes the results as ROS topics.
Response Playback
The tts_node.launch file initiates the text-to-speech module, which subscribes to the response messages published by the functional nodes and vocalizes the corresponding replies.
Launch the Low-Level Control Node
puppypi_control is responsible for managing the robot’s movement and executing motion commands.
Launch the Camera Node
The usb_cam_launch file starts the camera module, enabling access to real-time video feeds by subscribing to the camera topic.
19.6.2 Embodied AI Applications in Gender Recognition
In this lesson, we learn how to use a large AI model to analyze real-time scenes and implement gender recognition functionality.
To use this feature, you can freely issue voice commands for PuppyPi to recognize the gender of the person in front and perform corresponding actions. For example: Is the person in front a boy or a girl? If it’s a boy, please make a sound and then do a push-up.
(3) Run the following command to disable the auto-start service.
roslaunch large_models vllm_gender_identification.launch
You can freely phrase your commands to control PuppyPi. For example: Is the person in front a boy or a girl? If it’s a boy, please make a sound and then do a push-up.
(7) When the command line displays an output like the one shown below, it indicates that the Raspberry Pi has successfully called the cloud-based speech recognition service of the large language model and has processed the user’s voice command. Object: Identifies any obstacles in the current environment Action: Executes the corresponding action based on the instruction Response: Plays the appropriate voice feedback
(8) Once this output appears, it means the current round of interaction has concluded. You can then say the wake word again to re-activate WonderEcho Pro and begin a new round of dialogue.
How It Works
(1) Once the program starts running and WonderEcho Pro announces I am ready. To activate WonderEcho Pro, simply say the wake word Hello, Hiwonder. The device will respond with the voice prompt, I am here.
(3) You can then control PuppyPi via voice commands. For example: Is the person in front a boy or a girl? If it’s a boy, please make a sound and then do a push-up.
WonderEcho Pro will generate a response based on the analysis and broadcast it aloud while executing the corresponding actions.
The rules for generating text responses and corresponding actions using the large language model can be found in the prompt settings within the program, specifically in the following file: /home/ubuntu/puppypi/src/large_models/scripts/vllm_gender_identification.py
The program’s configuration file is located within the Docker container at: /home/ubuntu/puppypi/src/large_models/scripts/vllm_gender_identification.py
⑦ Node: The base class for ROS 2 nodes.
⑧ sensor_msgs and std_msgs: Message types for subscribing to image data and publishing string data, respectively.
6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 | import cv2 import math import json import time import rospy import queue import threading import subprocess import numpy as np from config import * from speech import speech from sensor_msgs.msg import Image from action import PuppyControlNode from std_msgs.msg import String, Bool from cv_bridge import CvBridge, CvBridgeError from std_srvs.srv import SetBool, Trigger, Empty from large_models.srv import SetModel, SetString, SetStringRequest from puppy_control.srv import SetRunActionName, SetRunActionNameRequest |
Global Prompt
If a male or female is detected: The system will identify the gender and execute the corresponding action. If no male or female is detected: It will return the message, No male or female detected in front that requires a response.
87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 | PROMPT = ''' **Role: You are an intelligent robot assistant capable of recognizing the content in an image and, based on my description, identifying whether it’s a male or a female. **Rules: Return a JSON object containing the following fields: "type": Always set to "detect" "object": The name of the detected object. If nothing is detected, set to "None" "action": An array of function names (as strings) in execution order. If no corresponding action functions are found, return an empty array [] "response": Provide a response based on whether the detected target is a man or a woman If the instruction includes action requirements, provide the corresponding actions in order, using the following allowed function names: - stand(): Stand - boxing(): Punch - push_up(): Push-up - shake_hands(): Shake hands - nod(): Nod - sit(): Sit - kick_ball_left(): Kick left leg - kick_ball_right(): Kick right leg - moonwalk(): Dance - lie_down(): Lie down - temp(): Stretch lazily - bow(): Act cute - man(): Call out to a man - woman(): Call out to a woman If the detected object is "male", then:"object": "man" If the detected object is "female", then:"object": "women" If neither male nor female is detected, return:"object": "None","action": ["None"] Only return the name of the detected object and the corresponding action results. The response must always be included: If object is "man", then response should be: "There's a boy in front of me. Should I go bite him?" If object is "women", then response should be: "It's a girl. Should I go say hello to her?" Example 1: Input:Is the person in front of you a boy or a girl? Output:{ "type": "detect", "object": "man", "action": ["man()"], "response": "There's a boy in front of me. Should I go bite him?" } |
144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 | class VLLMGENDER(object): def __init__(self, name): rospy.init_node(name) self.action_done_event = threading.Event() self.image_queue = queue.Queue(maxsize=2) self.bridge = CvBridge() self.action = [] self.vllm_result = '' self.running = True self.puppy_control_node = PuppyControlNode() # Publisher (发布者) self.tts_text_pub = rospy.Publisher('/tts_node/tts_text', String, queue_size=1) # Subscriber (订阅者) rospy.Subscriber('/usb_cam/image_raw', Image, self.image_callback) rospy.Subscriber('/agent_process/result', String, self.vllm_result_callback) rospy.Subscriber('/tts_node/play_finish', Bool, self.play_audio_finish_callback) |
182 183 184 185 186 187 188 189 190 191 192 193 194 195 | def init_process(self): if os.environ['ASR_LANGUAGE'] == 'Chinese': self.set_model_client(stepfun_vllm_model, 'vllm', stepfun_api_key, stepfun_base_url) else: self.set_model_client(vllm_model, 'vllm', vllm_api_key, vllm_base_url) self.set_prompt_client(PROMPT) # Play start audio (播放开始音频) speech.play_audio(start_audio_path) # Start processing thread (启动处理线程) threading.Thread(target=self.process, daemon=True).start() |
Image Processing:
304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 | def image_callback(self, ros_image): """Image callback function: convert ROS Image to OpenCV image and enqueue (图像回调函数,将 ROS Image 转换为 OpenCV 图像并放入队列)""" try: # Use cv_bridge to convert ROS Image to OpenCV image (使用 cv_bridge 将 ROS Image 转换为 OpenCV 图像) rgb_image = self.bridge.imgmsg_to_cv2(ros_image, desired_encoding='bgr8') if self.image_queue.full(): # If the queue is full, discard the oldest image (如果队列已满,丢弃最旧的图像) discarded_image = self.image_queue.get() # Enqueue the image (将图像放入队列) self.image_queue.put(rgb_image) except CvBridgeError as e: rospy.logerr("转换图像时出错: %s" % e) except Exception as e: rospy.logerr("处理图像时出错: %s" % e) |
216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 | def handle_vllm_result(self): """Process VLLM result, including action parsing and response publishing (处理 VLLM 结果,包括解析动作和发布响应)""" if not self.vllm_result: rospy.logwarn("VLLM 结果为空,跳过处理。") return # If no result, return immediately (如果没有结果,直接返回) try: # Extract and parse JSON string (提取 JSON 字符串并解析) start_idx = self.vllm_result.find('{') end_idx = self.vllm_result.rfind('}') + 1 if start_idx == -1 or end_idx <= start_idx: raise ValueError("无效的 JSON 格式") result_json = self.vllm_result[start_idx:end_idx] rospy.loginfo("解析出的 JSON: %s" % result_json) result = json.loads(result_json) action_list = result.get('action', []) response = result.get('response', '') |
Processing Loop:
Display Image: Show the processed images using OpenCV.
288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 | def process(self): """Process image queue and display images (处理图像队列并显示图像)""" while not rospy.is_shutdown() and self.running: try: image = self.image_queue.get(block=True) cv2.imshow('image', image) if cv2.waitKey(1) & 0xFF == ord('q'): self.running = False rospy.loginfo("检测到 'q' 按键,关闭图像窗口。") break except Exception as e: rospy.logerr("处理图像时出错: %s" % e) cv2.destroyAllWindows() rospy.loginfo("图像处理线程已结束。") |
The launch file is saved in: /home/ubuntu/puppypi/src/large_models/launch/vllm_gender_identification.launch
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 | <launch> <!-- 启动 vocal_detect 节点 --> <include file="$(find large_models)/launch/vocal_detect.launch" /> <!-- 启动 agent_process 节点 --> <include file="$(find large_models)/launch/agent_process.launch" /> <!-- 启动 tts_node 节点 --> <include file="$(find large_models)/launch/tts_node.launch" /> <!-- 启动 puppy_control 节点 --> <node name="puppy_control" pkg="puppy_control" type="puppy.py" required="false" output="screen" /> <!-- 启动 vllm_gender_identification.py 节点 --> <node name="vllm_gender_identification" pkg="large_models" type="vllm_gender_identification.py" required="false" output="screen" /> <!-- 启动 USB 摄像头节点 --> <arg name="camera_name" default="usb_cam" /> <node name="$(arg camera_name)" pkg="usb_cam" type="usb_cam_node" respawn="true" respawn_delay="2" output="screen"> <param name="video_device" value="/dev/video0" /> <param name="image_width" value="640" /> <param name="image_height" value="480" /> <param name="pixel_format" value="yuyv" /> <param name="camera_frame_id" value="$(arg camera_name)" /> <param name="io_method" value="mmap"/> </node> </launch> |
Response Playback
19.6.3 Embodied AI Applications in Temperature Reporting
In this lesson, you will learn how to use a large AI model to perform real-time temperature detection and implement temperature reporting functionality.
By using this feature, you can freely issue commands to PuppyPi to either measure the current indoor temperature
or retrieve and report temperatures from other cities online.
(4) Sensor Installation
Step 1: Connect the temperature and humidity sensor to the indicated I2C port.
Step 2: Mount the WonderEcho Pro and, temperature and humidity sensor onto the back of the robot.
(4) Enter the command to launch the corresponding game.
roslaunch large_models llm_temperature.launch
(5) After successful startup, PuppyPi will announce, I am ready. Then, say the wake word Hello, HiWonder to activate the large AI model, and the robot will respond verbally with, I am here.
You can freely phrase your commands to control PuppyPi, such as What is the current indoor temperature? or What is the current weather temperature in Sydney? (or any other location).
(7) When the command line displays output similar to the image below, it indicates that the Raspberry Pi has successfully called the cloud-based large language model’s speech recognition service and processed the user’s audio command.
publish llm result: The recognized result
Object: Identifies the current temperature
Action: Executes the specified action based on the command
Response: Plays the corresponding voice feedback
How It Works
(2) Upon recognizing the speech, the system retrieves an image from the image queue and passes both the recognition result and the image to the agent for response generation. You can then control PuppyPi by voice, for example, by saying What is the current indoor temperature? PuppyPi will obtain the temperature from its sensors and WonderEcho Pro will verbally deliver the generated response after processing.
The rules for generating text responses and corresponding actions using the large language model can be found in the prompt settings within the program, specifically in the following file: /home/ubuntu/puppypi/src/large_models/scripts/llm_temperature.py
The program’s configuration file is located within the Docker container at: /home/ubuntu/puppypi/src/large_models/scripts/llm_temperature.py
② smbus: Utilized for communication with I2C devices.
③ time: Provides functions related to time operations.
④ rospy: The Python client library for ROS1, used for node creation and inter-node communication.
⑤ large_models_msgs.srv: Custom service definitions for interacting with large AI models.
⑥ re: Regular expression module for string matching and manipulation.
⑦ speech: Module for speech recognition functionality.
⑧ puppy_control_msgs.srv: Custom service definitions for controlling the robot.
6 7 8 9 10 11 12 13 14 15 16 | import re import json import time import smbus import rospy from config import * from speech import speech from std_msgs.msg import String,Bool from puppy_control.srv import SetRunActionName from std_srvs.srv import SetBool, Trigger, Empty from large_models.srv import SetModel, SetString, SetStringRequest |
Acquire the temperature
This module reads data from the temperature sensor (AHT10). It initializes the sensor by specifying the I2C bus and device address.
Sensor data is read via the I2C protocol and converted to Celsius. Finally, it outputs the current temperature value (ctemp).
99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 | # Get temperature and humidity sensor data via I2C (I2C获取温湿度传感器数据) class AHT10: CONFIG = [0x08, 0x00] MEASURE = [0x33, 0x00] def __init__(self, bus=1, addr=0x38): self.bus = smbus.SMBus(bus) self.addr = addr time.sleep(0.2) def getData(self): self.bus.write_i2c_block_data(self.addr, 0xAC, self.MEASURE) time.sleep(0.5) data = self.bus.read_i2c_block_data(self.addr, 0x00) temp = ((data[3] & 0x0F) << 16) | (data[4] << 8) | data[5] ctemp = ((temp * 200) / 1048576) - 50 return ctemp |
Initialize the Temperature Sensor
① Start by initializing the temperature sensor. Publisher: tts_text: Publishes TTS (Text-to-Speech) messages.
② Subscriber: Subscribes to the language model (LLM) to receive processing results.
③ Service Clients:
④ set_llm_client: Used to configure the LLM.
⑤ set_llm_content_client: Sends temperature data to the LLM.
⑥ Wait for Service Availability: Ensure that the LLM configuration and content services are up and running before proceeding.
117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 | class LLMTemperature: def __init__(self): # Initialize ROS node (初始化ROS节点) rospy.init_node('llm_control_sensor', anonymous=False) # Flag to prevent handling multiple requests simultaneously (标志位,防止同时处理多个请求) self.processing = False self.asr_result = '' # Initialize temperature sensor (初始化温度传感器) self.aht10 = AHT10() self.client = speech.OpenAIAPI(api_key, base_url) # Create publisher (创建发布者) self.tts_text_pub = rospy.Publisher('/tts_node/tts_text', String, queue_size=10) # Create subscriber (创建订阅者) rospy.Subscriber('/tts_node/play_finish', Bool, self.play_audio_finish_callback) rospy.Subscriber('/agent_process/result', String, self.llm_result_callback) rospy.Subscriber('/vocal_detect/asr_result', String, self.asr_callback) |
Configure LLM
Initiate an asynchronous call to the /agent_process/set_llm service to configure the LLM with the appropriate app_id and conversation_id.
Once the configuration is successfully applied, the configure_llm_callback function will be automatically triggered to handle subsequent actions.
154 155 156 157 158 159 160 161 162 163 164 165 166 167 | def init_process(self): self.set_model_client(llm_model, 'llm', api_key, base_url) self.set_prompt_client(PROMPT) # Play startup sound (播放启动音频) speech.play_audio(start_audio_path) # Call go_home service (调用 go_home 服务) try: self.go_home_cli() except rospy.ServiceException as e: rospy.logerr("调用 /puppy_control/go_home 服务时出错: {}".format(e)) |
Temperature Reading
Attempts to retrieve the current temperature; if unsuccessful, an error message will be displayed.
176 177 178 179 180 181 182 183 184 185 186 187 188 189 | def get_temperature(self): """ Get the current temperature and return it(获取当前温度并返回。) """ try: temperature = self.aht10.getData() if os.environ['ASR_LANGUAGE'] == 'Chinese': rospy.loginfo("当前温度: {:.2f} °C".format(temperature)) else: rospy.loginfo("Current temperature: {:.2f} °C".format(temperature)) return temperature except Exception as e: rospy.logerr("温度传感器读取失败: {}".format(e)) return None |
Publishing TTS Message
Publish the temperature text message to the tts_node/tts_text topic, enabling the text-to-speech (TTS) node to broadcast the temperature via voice.
279 280 281 282 283 284 285 286 287 | def publish_tts(self, message): """ Publish TTS message to tts_node/tts_text topic (发布 TTS 消息到 tts_node/tts_text 主题) """ #rospy.loginfo("准备发布 TTS 消息: {}".format(message)) tts_msg = String() tts_msg.data = message self.tts_text_pub.publish(tts_msg) #rospy.loginfo("发布 TTS 消息: {}".format(tts_msg.data)) |
The launch file for this program is located at:
/home/ubuntu/puppypi/src/large_models/launch/llm_temperature.launch
The agent_process.launch file launches the semantic understanding module. It subscribes to the speech recognized by the voice detection node, forwards the audio to the Baidu AI agent for interpretation, and publishes the parsed results as ROS topics for subsequent processing.
Response Playback
19.6.4 Embodied AI Applications in Scene Understanding
In this lesson, you’ll learn how to leverage large language models to analyze and report on real-time scenarios.
By engaging in this activity, you’ll use PuppyPi to recognize the current environment, generate insightful analysis, and deliver a spoken report—all while freely organizing your own language expressions.
roslaunch large_models vllm_with_camera.launch
Feel free to phrase your commands in your own words when interacting with PuppyPi—for example: What do you see? Please describe the scene.
How It Works
(2) Upon recognizing the speech, the system retrieves an image from the image queue and passes both the recognition result and the image to the agent for response generation. From there, you can control PuppyPi using voice commands—for example: What scene do you see? Please describe it. PuppyPi will use its camera to capture the surroundings, analyze the scene, and deliver a spoken response through the WonderEcho Pro.
The program’s configuration file is located within the Docker container at: /home/ubuntu/puppypi/src/large_models/large_models/scripts
② cv2: OpenCV image processing library.
③ rospy: The Python client library for ROS, used to interface with ROS nodes in Python.
④ std_msgs.msg: Provides standard message types in ROS, such as string messages.
⑤ sensor_msgs.msg: Contains message definitions for sensor data, including image messages.
⑥ std_srvs.srv: Defines standard ROS service types, such as trigger services with empty requests and responses.
⑦ cv_bridge: A utility for converting between ROS image messages and OpenCV image formats.
⑧ speech: A custom module for handling speech recognition.
⑨ PuppyControlNode: A robot control class responsible for executing predefined actions.
6 7 8 9 10 11 12 13 14 15 16 17 18 19 | import cv2 import sys import queue import rospy import threading from config import * from speech import speech from cv_bridge import CvBridge from sensor_msgs.msg import Image from action import PuppyControlNode from std_msgs.msg import String, Bool from puppy_control.srv import SetRunActionName from std_srvs.srv import Trigger, Empty, SetBool from large_models.srv import SetModel, SetString, SetStringRequest |
Initializing Node
The ROS node is initialized, setting up an image queue, a speech recognition model, and the robot control node. It subscribes to the image and VLLM result topics, configures the relevant service clients, and completes the startup by invoking the initialization routine.
25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 | class VLLMCamera(object): def __init__(self, name): rospy.init_node(name) self.image_queue = queue.Queue(maxsize=2) self.language = os.environ["ASR_LANGUAGE"] self.bridge = CvBridge() self.vllm_result = '' self.running = True self.puppy_control_node = PuppyControlNode() # Publisher (发布者) self.tts_text_pub = rospy.Publisher('/tts_node/tts_text', String, queue_size=1) # Subscriber (订阅者) rospy.Subscriber('/usb_cam/image_raw', Image, self.image_callback) rospy.Subscriber('/agent_process/result', String, self.vllm_result_callback) rospy.Subscriber('/tts_node/play_finish', Bool, self.play_audio_finish_callback) |
Set the model to VLLM and initiate the audio service. Next, start the image processing thread by invoking the process() method.
57 58 59 60 61 62 63 64 65 66 67 68 69 70 | def init_process(self): """Initialization process (初始化过程)""" if os.environ['ASR_LANGUAGE'] == 'Chinese': self.set_model_client(stepfun_vllm_model, 'vllm', stepfun_api_key, stepfun_base_url) else: self.set_model_client(vllm_model, 'vllm', vllm_api_key, vllm_base_url) # Play start audio (播放启动音频) speech.play_audio(start_audio_path) # Start image processing thread (启动图像处理线程) threading.Thread(target=self.process, daemon=True).start() rospy.loginfo('启动成功') rospy.Service('~/init_finish', Trigger, self.get_node_state) |
Image Processing:
119 120 121 122 123 124 125 126 127 128 129 130 131 | def image_callback(self, ros_image): """Image callback function: convert ROS Image to OpenCV image and enqueue it (图像回调函数,将 ROS Image 转换为 OpenCV 图像并放入队列)""" try: # Use cv_bridge to convert ROS Image to OpenCV format (使用 cv_bridge 将 ROS Image 转换为 OpenCV 图像) rgb_image = self.bridge.imgmsg_to_cv2(ros_image, desired_encoding='bgr8') if self.image_queue.full(): # If the queue is full, discard the oldest image (如果队列已满,丢弃最旧的图像) discarded = self.image_queue.get() #rospy.logwarn("图像队列已满,丢弃最旧的图像") # Add the image to the queue (将图像放入队列) self.image_queue.put(rgb_image) except Exception as e: rospy.logerr("处理图像时出错: %s" % e) |
/home/ubuntu/puppypi/src/large_models/launch/start.launch
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 | <launch> <!-- 启动 vocal_detect 节点 --> <include file="$(find large_models)/launch/vocal_detect.launch" /> <!-- 启动 agent_process 节点 --> <include file="$(find large_models)/launch/agent_process.launch" /> <!-- 启动 tts_node 节点 --> <include file="$(find large_models)/launch/tts_node.launch" /> <!-- 启动 puppy_control 节点 --> <node name="puppy_control" pkg="puppy_control" type="puppy.py" required="false" output="screen" /> <!-- 启动 USB 摄像头节点 --> <arg name="camera_name" default="usb_cam" /> <node name="$(arg camera_name)" pkg="usb_cam" type="usb_cam_node" respawn="true" respawn_delay="2" output="screen"> <param name="video_device" value="/dev/video0" /> <param name="image_width" value="640" /> <param name="image_height" value="480" /> <param name="pixel_format" value="yuyv" /> <param name="camera_frame_id" value="$(arg camera_name)" /> <param name="io_method" value="mmap"/> </node> </launch> |
Response Playback
19.6.5 Embodied AI Application in Object Grasping
This lesson focuses on leveraging large language models to detect and analyze real-time scenes for target grasping tasks.
You’ll be able to freely issue commands to PuppyPi to pick up objects, such as: Help me grab the green block.
(4) Robotic Arm Installation
Please refer to 17. ROS1_ROS Robot with Robot Arm -> 17.1 Robotic Arm Installation and Wiring for the robotic arm installation guide.
roslaunch large_models vllm_track_start.launch
How It Works
(3) You can control PuppyPi through voice commands, such as Help me grab the green block. After processing, WonderEcho Pro will deliver a spoken response and execute the corresponding action.
The rules for generating text responses and corresponding actions using the large language model can be found in the prompt settings within the program, specifically in the following file: /home/ubuntu/puppypi/src/large_models/scripts/vllm_color_tracking.py
Function Expansion
If the color detection of the object is unsatisfactory during the game, it may be necessary to adjust the robotic arm’s grasping range. The instructions are as below:
(1) Enter the following command and press Enter to navigate to the directory where the program is located:
cd puppypi/src/large_models/scripts
(2) Run the following command to open the program file:
vim puppy_controller.py
(3) Find the program file, then modify the values of self.y_close_lower = 410 and self.y_close_upper = 420 according to the observed results.
(4) Press the “i” key to enter edit mode.
(5) Once the modification is complete, press the Esc. key. Then, type the following command (note that a colon : precedes the wq) and press Enter to save the changes:
(6) Follow the instructions, re-enter the command, and press Enter to initiate.
Brief Program Analysis
The program’s configuration file is located within the Docker container at: /home/ubuntu/puppypi/src/large_models/scripts/vllm_color_tracking.py
The large language model functionality is implemented by invoking the script at /home/ubuntu/puppypi/src/large_models/scripts/llm_tracking.py.
⑥ rclpy: The Python client library for ROS1, utilized for creating ROS nodes.
⑦ Node: The base class for ROS1 nodes.
4 5 6 7 8 9 10 11 12 13 | import rospy import threading import time import cv2 from cv_bridge import CvBridge, CvBridgeError from sensor_msgs.msg import Image from std_msgs.msg import Bool from std_srvs.srv import Trigger, TriggerResponse, SetBool, SetBoolResponse from large_models.srv import SetColor, SetColorResponse from puppy_controller import PuppyController, PuppyStatus |
Global Prompt
If an obstacle is detected: identify the object by name, provide a safety alert, and execute the appropriate action. If no obstacle is detected: return the message No obstacles.
24 25 26 27 28 29 30 31 32 33 34 | # Define prompt message (定义提示信息) language = os.environ["ASR_LANGUAGE"] if language == 'Chinese': PROMPT = ''' # 角色 你是一款智能陪伴四足机器狗,专注机器人动作规划,解析人类指令并以幽默方式描述即将展开的行动序列,为交互增添无限趣味。 ## 技能 ### 指令解析与创意演绎 - **智能解码**:瞬间领悟用户指令的核心意图。 - **灵动编排**:依据解析成果,精心构建一系列连贯且富有逻辑性的动作指令序列。 - **妙语生花**:为每个动作序列编织一句精炼(5至20字)、风趣且变化无穷的反馈信息,让交流过程妙趣横生。 |
15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 | class ControlServiceNode: def __init__(self): self.controller = PuppyController(debug=False) self.bridge = CvBridge() rospy.Subscriber('/usb_cam/image_raw', Image, self.image_callback) # Subscribe to the wake-up topic, stop the interaction when receiving True (订阅唤醒话题,收到 True 时停止玩法) rospy.Subscriber('/vocal_detect/wakeup', Bool, self.wakeup_callback) self.latest_image = None self.image_lock = threading.Lock() rospy.Service('color_tracking/enter', Trigger, self.enter_callback) rospy.Service('color_tracking/enable_color_tracking', SetBool, self.enable_callback) rospy.Service('color_tracking/set_color', SetColor, self.set_color_callback) rospy.Service('color_tracking/stop', Trigger, self.stop_callback) |
126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 | class LLMTracking: def __init__(self): # Initialize ROS node (初始化ROS节点) rospy.init_node('llm_tracking', anonymous=False) # Initialize variables (初始化变量) self.action = [] self.llm_result = '' self.running = True # Publisher: publishes to the 'tts_node/tts_text' topic (发布者:发布到 'tts_node/tts_text' 话题) self.tts_text_pub = rospy.Publisher('/tts_node/tts_text', String, queue_size=10) # Subscriber: subscribes to the '/agent_process/result' topic (订阅者:订阅 '/agent_process/result' 话题) rospy.Subscriber('/agent_process/result', String, self.llm_result_callback) rospy.Subscriber('/tts_node/play_finish', Bool, self.play_audio_finish_callback) |
275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 | def handle_result(self, result): """ Process the parsed JSON result (处理解析后的 JSON 结果) """ if 'action' not in result or not isinstance(result['action'], list): rospy.logerr("结果格式无效:缺少 'action' 或 'action' 不是列表。") return if 'grab' in result['action']: if 'object' in result and result['object']: color = result['object'] rospy.loginfo("动作: grab, 颜色: %s" % color) # Call SetColor service to set the color (调用 SetColor 服务设置颜色) try: set_color_request = SetColorRequest() set_color_request.color = color # Ensure the 'color' field exists in SetColorRequest (确保 SetColorRequest 中有 'color' 字段) set_color_response = self.set_color_client(set_color_request) if set_color_response.success: rospy.loginfo("设置颜色为 %s 成功。" % color) else: rospy.logerr("设置颜色为 %s 失败: %s" % (color, set_color_response.message)) except rospy.ServiceException as e: rospy.logerr("调用 SetColor 服务失败: %s" % e) |
Processing Loop:
Continuously retrieve and process images from the queue on a frame-by-frame basis. Display or handle processed images using OpenCV or an alternative visualization tool.
137 138 139 140 141 142 143 144 145 146 147 148 149 150 | def display_images(control_node): rospy.loginfo("图像显示线程启动") while not rospy.is_shutdown(): img = control_node.get_latest_image() if img is not None: processed = control_node.controller.process_image(img.copy()) cv2.imshow('Frame', processed) if cv2.waitKey(1) == 27: # Press ESC to exit(ESC键退出) rospy.signal_shutdown('ESC pressed') break else: time.sleep(0.01) cv2.destroyAllWindows() rospy.loginfo("图像显示线程结束") |
The launch file is saved in: /home/ubuntu/puppypi/src/large_models/large_models/launch/vllm_track_start.launch
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 | <launch> <!-- 启动 vocal_detect 节点 --> <include file="$(find large_models)/launch/vocal_detect.launch" /> <!-- 启动 agent_process 节点 --> <include file="$(find large_models)/launch/agent_process.launch" /> <!-- 启动 tts_node 节点 --> <include file="$(find large_models)/launch/tts_node.launch" /> <!-- 启动 puppy_control 节点 --> <node name="puppy_control" pkg="puppy_control" type="puppy.py" required="false" output="screen" /> <!-- 启动 llm_tracking 节点 --> <node name="llm_tracking" pkg="large_models" type="llm_tracking.py" required="false" output="screen" /> <!-- 启动 vllm_color_tracking.py 节点 --> <node name="vllm_color_tracking" pkg="large_models" type="vllm_color_tracking.py" required="false" output="screen" /> <!-- 启动 USB 摄像头节点 --> <arg name="camera_name" default="usb_cam" /> <node name="$(arg camera_name)" pkg="usb_cam" type="usb_cam_node" respawn="true" respawn_delay="2" output="screen"> <param name="video_device" value="/dev/video0" /> <param name="image_width" value="640" /> <param name="image_height" value="480" /> <param name="pixel_format" value="yuyv" /> <param name="camera_frame_id" value="$(arg camera_name)" /> <param name="io_method" value="mmap"/> </node> </launch> |
Response Playback
