11. ROS1_MediaPipe Human-Robot Interaction Courses
11.1 Introduction to MediaPipe
11.1.1 MediaPipe Description
11.1.2 MediaPipe Pros and Cons
  • MediaPipe Pros
(1) MediaPipe supports various platforms and languages, including iOS, Android, C++, Python, JAVAScript, Coral, etc.
(2) Swift running. Models can run in real-time.
(3) Models and codes are with high reuse rate.
  • MediaPipe Cons
(1) For mobile devices, MediaPipe will occupy 10M or above.
(2) As it greatly depends on Tensorflow, you need to alter large amount of codes if you want to change it to other machine learning frameworks, which is not friendly to machine learning developer.
(3) It adopts static image which can improve efficiency, but make it difficult to find out the errors.
11.1.3 How to use MediaPipe
  • Dependency
For seamless usage of MediaPipe, we suggest gaining a basic understanding of OpenCV. To delve into OpenCV.
  • MediaPipe Solutions
11.1.4 MediaPipe Learning Resources
MediaPipe website:https://developers.google.com/mediapipe
11.2 Image Background Segmentation
11.2.1 Program Logic
To begin, import the selfie segmentation model from MediaPipe and subscribe to the corresponding topic to access the live camera feed.
Next, flip the image and apply the segmentation to the background image. For improved boundary segmentation, implement dual-border segmentation.
Finally, complete the process by replacing the background with a virtual background.
11.2.2 Operation Steps
(1) Start the robot, and enter the robot system desktop using VNC.
(3) Execute the command to navigate to the directory where programs are saved.
cd /home/ubuntu/puppypi/src/puppy_extend_demo/scripts
(4) Enter the following command to start the game.
python3 self_segmentation.py
(5) If you want to exit this game, please use shortcut key Ctrl+C. If the game cannot be closed, please retry.
11.2.3 Program Outcome
Once the game starts, the screen will transition to a gray virtual background. As soon as a human figure appears, the program will automatically execute background removal, effectively separating the human from the virtual background.
11.2.4 Program Analysis
The source code of this program is saved in: /home/ubuntu/puppypi/src/puppy_extend_demo/scripts/self_segmentation.py
  • Build Selfie Segmentation Model
class SegmentationNode:
        rospy.init_node(name)
        self.mp_selfie_segmentation = mp.solutions.selfie_segmentation
        self.mp_drawing = mp.solutions.drawing_utils
        self.BG_COLOR = (192, 192, 192)  # gray
        self.bridge = CvBridge()
        self.image_sub = rospy.Subscriber('/usb_cam/image_raw', Image, self.image_callback)
        rospy.loginfo('\033[1;32m%s\033[0m' % 'start')
        self.cli = rospy.ServiceProxy('/puppy_control/go_home', Empty)
        self.cli()
The SegmentationNode is a ROS-based node designed for real-time image processing and selfie segmentation. Upon initialization, it loads MediaPipe’s selfie_segmentation model and sets up an image subscriber to receive raw image data.
Incoming images are handled by the image_callback function, which converts the ROS image messages into NumPy arrays and stores them in a queue with a maximum capacity of two. If the queue is full, the oldest image is discarded to ensure real-time performance.
        # Convert the ROS image message to a CV2 image
        rgb_image = self.bridge.imgmsg_to_cv2(ros_image, "bgr8")
    except CvBridgeError as e:
        rospy.logerr(f"Error converting image: {e}")
The main function processes the images from the queue and performs selfie segmentation using MediaPipe’s model. A segmentation mask is generated to separate the foreground (typically the person) from the background. The background can be customized—either replaced with a solid color or an external image. The final output, including the processed image and the current FPS (frames per second), is displayed in a window.
    with self.mp_selfie_segmentation.SelfieSegmentation(model_selection=1) as selfie_segmentation:
        bg_image = None
            # To improve performance, optionally mark the image as not writeable to
            # pass by reference.
            image.flags.writeable = False
            results = selfie_segmentation.process(image)
            image.flags.writeable = True
            # Since the input image is in RGB, directly use it
            condition = np.stack((results.segmentation_mask,) * 3, axis=-1) > 0.1
            if bg_image is None:
                bg_image = np.zeros(image.shape, dtype=np.uint8)
                bg_image[:] = self.BG_COLOR
            output_image = np.where(condition, image, bg_image)
            # Display image (already in RGB)
            cv2.imshow('MediaPipe Selfie Segmentation', output_image)
            if key == ord('q') or key == 27:  # Press q or esc to exit
The code also includes a queue management system to ensure smooth image processing. Users can exit the program at any time by pressing a key. Upon exiting, all OpenCV windows are closed, and ROS resources are properly released.
11.3 Face Detection
11.3.1 Feature Overview
This function performs real-time face detection. Once a face is identified, it is highlighted in the video stream with a bounding box.
Face recognition is one of the most common applications of image recognition in AI. It’s widely used in scenarios such as smart door locks and smartphone facial unlocking.
In this module, a pre-trained face detection model is used. The image is first resized to facilitate detection. After detecting a face, the coordinates are mapped back to the original resolution. The system then identifies the largest detected face and highlights it with a bounding box.
11.3.2 Start and Stop the Game
Commands are case-sensitive. You can use the Tab key to auto-complete commands.
(1) Power on the robot and connect to the Raspberry Pi desktop via VNC.
(2) On the desktop, double-click the Terminator icon to open a terminal window and enter the ROS1 development environment.
(3) Navigate to the program directory by entering:
(4) Start the face detection program by running:
python3 face_detect.py
(5) To stop the program, press Ctrl + C in the terminal. If it doesn’t respond immediately, try pressing it again.
11.3.3 Program Outcome
Once the program is running, it will detect faces in the camera feed and highlight them with bounding boxes in real time.
11.3.4 Program Analysis
The corresponding script for this feature is located in the Docker container at:
/home/ubuntu/puppypi/src/puppy_extend_demo/scripts/face_detect.py
This script continuously processes images from the camera using the MediaPipe library for face detection. If no face is detected, the program continues to subscribe to the camera topic to retrieve new frames. Once a face is identified, it is outlined in the image.
  • Face Detection
The face detector is initialized using the mp.solutions.face_detection() method, which enables facial feature recognition.
self.bridge = CvBridge()  # cv_bridge is required in ROS1 for image conversion. (ROS1需要cv_bridge进行图像转换)
# Initialize Mediapipe. (Mediapipe初始化)
self.face = mp.solutions.face_detection
self.face_detection = self.face.FaceDetection(min_detection_confidence=0.6)
self.img_h, self.img_w = 0, 0
# Image queue and subscriber. (图像队列和订阅者)
self.image_sub = rospy.Subscriber('/usb_cam/image_raw', Image, self.image_callback, queue_size=1)
# Start the processing thread. (启动处理线程)
  • Image Processing
        # Use cv_bridge to convert ROS image messages. (使用cv_bridge转换ROS图像消息)
        rospy.logerr(e)
        return
    img_copy = cv_image.copy()
    self.img_h, self.img_w = cv_image.shape[:2]
    # Process using Mediapipe. (Mediapipe处理)
    imgRGB = cv2.cvtColor(img_copy, cv2.COLOR_BGR2RGB)
    results = self.face_detection.process(imgRGB)
    if results.detections:
        for detection in results.detections:
            bboxC = detection.location_data.relative_bounding_box
            bbox = (int(bboxC.xmin * self.img_w),
                    int(bboxC.ymin * self.img_h),
                    int(bboxC.width * self.img_w),
                    int(bboxC.height * self.img_h))
            cv2.rectangle(cv_image, bbox, (0,255,0), 2)
    # Put into queue. (放入队列)
    self.image_queue.put(cv_image)
A ROS image callback function receives incoming image messages. The MediaPipe model is then used to detect faces, draw bounding boxes, and store the processed images in a queue for further use.
11.4 Skeletal Recognition and Interaction
11.4.1 Program Overview
The system first initializes a human pose estimator to detect and extract key body joint positions. These keypoints are then connected to form a skeletal structure.
Next, the joint positions are analyzed using simple 2D geometric features to determine the arm movements.
When both arms are detected in a horizontal position (T-pose), the system prepares to enter imitation mode. Once the arms are fully extended, the robot begins imitating the movement. It controls four servos—left upper arm, right upper arm, left forearm, and right forearm—to replicate the detected limb actions.
11.4.2 Start and Stop the Game
(4) Start the program by running:
python3 mediapipe_pose_node.py
11.4.3 Program Outcome
Once the mode is activated, the robot will enter pose imitation standby mode.
(1) Stand in front of the robot’s camera.
The system will detect key points on your body and draw lines to represent limb connections.
(2) Trigger imitation mode:
When the robot detects both arms extended horizontally, it will emit a beep sound, indicating that it’s ready to enter imitation mode.
(3) Start imitation:
Extend your arms horizontally again, and the robot will begin its imitation movements. The robot’s front “arms” will move in sync with your gestures.
(4) Exit imitation mode:
Raise and cross both arms above your head. The robot will recognize this gesture and automatically exit imitation mode.
11.4.4 Program Analysis
The script for this section is located in the Docker container at:
/home/ubuntu/puppypi/src/puppy_extend_demo/scripts/mediapipe_pose_node.py
This program captures video from the robot’s camera and uses the MediaPipe library to perform real-time human pose detection.
If no body landmarks are detected in the current frame, the system continues to subscribe to the camera feed until valid body features are identified. Once detected, it analyzes the pose to determine the user’s movement.
When the system recognizes a specific gesture—such as raising the arms—the robot will automatically perform the corresponding action in response.
  • Human Pose Recognition
To perform human pose recognition, the program uses the mp.solutions.pose.Pose() function from the MediaPipe library to create a pose estimator, which identifies key body joint landmarks.
The function parameters are explained as follows:
# Initialize MediaPipe Pose.(初始化 MediaPipe Pose)
self.mp_pose = mp.solutions.pose
self.pose = self.mp_pose.Pose(
    static_image_mode=False,
    model_complexity=1,
    smooth_landmarks=True,
    min_detection_confidence=0.5,
    min_tracking_confidence=0.5
static_image_mode: Indicates whether the input is a static image. The default is False, meaning the input is treated as a video stream.
model_complexity: Specifies the complexity level of the pose estimation model.
smooth_landmarks: Determines whether to smooth landmark coordinates over time for video streams. Typically set to True to reduce jitter.
min_tracking_confidence: Sets the minimum confidence threshold (between 0 and 1) for the model to consider pose tracking successful. If tracking fails, the model will fall back to detection in the next frame.
min_detection_confidence: Defines the minimum confidence threshold (between 0 and 1) for the initial pose detection to be considered successful.
  • Detecting Arm Poses
The detected body keypoints are passed to the is_T_pose function to determine the user’s current arm posture.
By analyzing the angles between the shoulders, elbows, and wrists, the system can recognize whether the user is performing a T-pose (arms extended horizontally) or a crossed-arm gesture, triggering corresponding actions based on the detected pose.
T-Pose Detection and Mode Activation
When a T-pose is detected (i.e., both arms stretched out horizontally), the robot enters Interactive Mode. In this mode, the servo motors are set to specific target angles to perform predefined actions.
The is_T_pose function determines whether the body is in a T-pose by calculating joint angles and comparing them against defined thresholds.
282
284
285
286
287
288
289
290
291
292
294
295
296
297
298
299
300
301
302
def is_T_pose(self, pixel_landmarks):
    """Determine if it's a T-pose.(判断是否为 T 姿势)"""
        left_shoulder = pixel_landmarks[Landmark.LEFT_SHOULDER.value]
        right_shoulder = pixel_landmarks[Landmark.RIGHT_SHOULDER.value]
        left_elbow = pixel_landmarks[Landmark.LEFT_ELBOW.value]
        right_elbow = pixel_landmarks[Landmark.RIGHT_ELBOW.value]
        left_wrist = pixel_landmarks[Landmark.LEFT_WRIST.value]
        right_wrist = pixel_landmarks[Landmark.RIGHT_WRIST.value]
    except IndexError:
        rospy.logwarn("检测到的关键点数量不足以判断 T 姿势。")
        return False
    angle_threshold = 20
    horizontal_threshold = 20
    left_arm_angle = self.calculate_angle(left_shoulder, left_elbow, left_wrist)
    right_arm_angle = self.calculate_angle(right_shoulder, right_elbow, right_wrist)
    rospy.logdebug(f"左前臂角度: {left_arm_angle:.2f} 度")
    rospy.logdebug(f"右前臂角度: {right_arm_angle:.2f} 度")
    left_straight = abs(left_arm_angle - 180) < angle_threshold
    right_straight = abs(right_arm_angle - 180) < angle_threshold
    left_horizontal = self.is_horizontal(left_shoulder, left_wrist, horizontal_threshold)
    right_horizontal = self.is_horizontal(right_shoulder, right_wrist, horizontal_threshold)
    return left_straight and right_straight and left_horizontal and right_horizontal
383
384
385
386
387
388
389
390
391
392
393
394
395
396
397
398
399
400
401
402
403
@staticmethod
def calculate_angle(a, b, c):
    Calculate the angle at point b, where points a, b, c have (x, y) coordinates.(计算点 b 处的夹角,点 a, b, c 坐标为 (x, y))
        vector1 = (a[0] - b[0], a[1] - b[1])
        vector2 = (c[0] - b[0], c[1] - b[1])
        len1 = math.hypot(*vector1)
        len2 = math.hypot(*vector2)
        if len1 == 0 or len2 == 0:
            return 0.0
        dot = vector1[0] * vector2[0] + vector1[1] * vector2[1]
        angle = math.acos(max(min(dot / (len1 * len2), 1.0), -1.0)) * (180.0 / math.pi)
        return angle
        rospy.logwarn(f"计算角度时出错: {e}")
        return 0.0
  • Threshold Adjustment
287
288
350
351
352
353
354
355
356
357
358
359
360
361
362
363
364
elbow_angle_threshold = 50
elbows_bent = left_elbow_angle < elbow_angle_threshold and right_elbow_angle < elbow_angle_threshold
rospy.logdebug(f"左肘弯曲角度: {left_elbow_angle:.2f} 度")
rospy.logdebug(f"右肘弯曲角度: {right_elbow_angle:.2f} 度")
if not elbows_bent:
    self.hands_crossed_history.append(False)
    return False
hands_distance = abs(left_wrist[0] - right_wrist[0])
hands_distance_threshold = 100  # Pixels.(像素)
rospy.logdebug(f"双手水平距离: {hands_distance} 像素")
rospy.logdebug(f"双手水平距离阈值: {hands_distance_threshold} 像素")
angle_threshold (Angle Threshold): A higher value makes it easier to consider the arms as “straight”, while a lower value increases precision by requiring the arms to be closer to a 180-degree angle.
horizontal_threshold (Horizontal Threshold): Increasing this value makes it more tolerant when identifying the wrists as horizontal; decreasing it demands a nearly perfect horizontal alignment for detection.
elbow_angle_threshold (Elbow Angle Threshold): A higher value allows elbows to be recognized as bent more easily, while a lower value requires a smaller angle to confirm the bend.
hands_distance_threshold (Hands Distance Threshold): Raising this value permits a greater distance between the hands to be classified as “crossed”, while lowering it requires the hands to be closer together for the same classification.
  • Keypoint Connections
506
507
508
if results.pose_landmarks:
    self.mp_drawing.draw_landmarks(cv_image, results.pose_landmarks, self.mp_pose.POSE_CONNECTIONS)
    pixel_landmarks = self.convert_landmarks_to_pixels(cv_image, results.pose_landmarks.landmark)
Human body keypoints are visualized using the draw_landmarks() function. For example, the following line of code:
includes the following parameters:
cv_image: The image frame where the pose is detected.
results.pose_landmarks: The set of detected human pose landmarks (keypoints).
self.mp_pose.POSE_CONNECTIONS: The connections between the landmarks, used to draw the skeletal structure of the body.
  • Motion Imitation
When motion imitation mode is activated, the system analyzes the angles of the arm joints based on the detected keypoints. These angles are then used to control the servos, allowing the robot’s arms to mimic the same posture.
572
573
574
575
576
577
578
579
580
581
582
583
584
585
586
587
588
589
590
591
592
593
594
# Calculate left upper arm angle.(计算左上臂角度)
left_shoulder_angle = self.calculate_shoulder_angle(left_shoulder, left_elbow, nose)
self.filtered_angles['left_upper'] = self.apply_low_pass_filter('left_upper', left_shoulder_angle)
self.servos['left_upper'].pid.update(left_shoulder_angle)
pulse_left_upper = self.map_arm_angle_to_pulse(self.filtered_angles['left_upper'], self.servos['left_upper'])
# Calculate right upper arm angle.(计算右上臂角度)
right_shoulder_angle = self.calculate_shoulder_angle(right_shoulder, right_elbow, nose)
self.filtered_angles['right_upper'] = self.apply_low_pass_filter('right_upper', right_shoulder_angle)
self.servos['right_upper'].pid.update(right_shoulder_angle)
pulse_right_upper = self.map_arm_angle_to_pulse(self.filtered_angles['right_upper'], self.servos['right_upper'])
# Calculate left forearm angle.(计算左前臂角度)
left_forearm_angle = self.calculate_angle(left_shoulder, left_elbow, left_wrist)
self.filtered_angles['left_forearm'] = self.apply_low_pass_filter('left_forearm', left_forearm_angle)
self.servos['left_forearm'].pid.update(left_forearm_angle)
pulse_left_forearm = self.map_arm_angle_to_pulse(self.filtered_angles['left_forearm'], self.servos['left_forearm'])
# Calculate right forearm angle.(计算右前臂角度)
right_forearm_angle = self.calculate_angle(right_shoulder, right_elbow, right_wrist)
self.filtered_angles['right_forearm'] = self.apply_low_pass_filter('right_forearm', right_forearm_angle)
self.servos['right_forearm'].pid.update(right_forearm_angle)
pulse_right_forearm = self.map_arm_angle_to_pulse(self.filtered_angles['right_forearm'], self.servos['right_forearm'])
  • Exiting the Mode
To exit the motion imitation mode, simply cross both arms in front of the chest. This gesture will be recognized as the signal to stop the current mode.
610
611
if self.is_hands_crossed_on_chest(pixel_landmarks):
    self.exit_play_mode()
