19. ROS2-AI Large Model Courses
19.1 Large Models Basic Courses
19.1.1 Large Language Model Courses
(1) Basic Concept
(2) Features
(3) Working Principle
(4) Application Scenarios
① Text Generation
② Text Classification
③ Machine Translation
④ Question-Answering Systems
To proceed with this section, you will need to register on the appropriate website and obtain the API key for the large model (please refer to the file 19.1.1 Large Language Model Courses -> Large Language Model Deployment).
(1) Environment Configuration
sudo apt install vim
sudo apt install gedit
sudo apt install python3 python3-pip python3-all-dev python3-pyaudio portaudio19-dev libsndfile1
cd ~/large_models/speech_pkg/
jetson_nano 3.6
jetson_orin 3.10
rpi5 3.11
rpi5_docker 3.8
cd jetson_orin/
cp -r speech.so ..
cd ../..
pip3 install .
pip3 install openai -U
(3) Key Configuration
cd ~/large_models
vim config.py
③ Once the file is open, configure the OpenAI and OpenRouter keys by filling in the llm_api_key and vllm_api_key parameters, respectively (you can obtain these keys from the ‘19.1.1 Large Language Model Courses -> Large Language Model Deployment’ course).
(4) Running the Demo Program
python3 openai_llm_demo.py
Before starting this section, make sure you have completed the API key configuration outlined in the file 19.1.1 Large Language Model Courses -> Large Language Model Accessing.
cd large_models/
To proceed with this section, ensure that you have completed the API key configuration as described in the file 19.1.1 Language Model Courses -> Large Language Model Accessing.
cd large_models/
python3 openai_llm_er_demo.py
19.1.2 Large Speech Model Courses
Their advantages include:
① Processing Methods
② Model Complexity
③ Recognition Capability
④Training Data Requirements
② Text-to-Speech (TTS)
(1) Device Overview
① 6-Microphone Circular Array
Introduction:
Features and Specifications:
② Recording Test
arecord -l
③ Playback Test
aplay test.wav
  • Voice Wake-Up
(1) WonderEcho Pro Wake-Up
Device Check:
To proceed, we need to identify the USB device name assigned to the connected WonderEcho Pro or Circular Microphone Array (hereafter referred to as the voice device). Please follow the steps below carefully.
ll /dev | grep USB
ll /dev | grep USB
Wake-Up Test:
vim wakeup_demo.py
Device Check:
Wake-Up Test:
② Press i to enter edit mode.
③ Update the port to match the device port number you previously identified. Comment out the WonderEcho Pro configuration (add # at the beginning of the corresponding line), and uncomment the line using the circular microphone array on line 11 as the input device (see red box in the referenced image).
(3) Brief Program Overview
Importing Required Modules
from speech import awake
port = '/dev/ttyUSB0'
try:  # If a fan is present, it's recommended to turn it off before detection to reduce interference(如果有风扇,检测前推荐关掉减少干扰)
except:
Main Wake Word Detection Loop
print('start...')
Main Program Logic
            print('hello hiwonder')
        time.sleep(0.02)
        except:
(4) Extended Functionality
vim wakeup_demo.py
i
python3 wakeup_demo.py
  • Speech Recognition
(2) How It Works
Before proceeding, refer to the course “19.1.2 Large Speech Model Courses -> Large Language Models Deployment” to obtain your API key, and make sure to add it into the configuration file (config).
(4) Experiment Steps
cd large_models/
vim config.py
python3 openai_asr_demo.py
(5) Function Realization
(6) Brief Program Analysis
① Module Import
from speech import speech
② Define ASR Class
(7) Function Extension
vim openai_asr_demo.py
i
  • Speech Synthesis
(1) What is Speech Synthesis?
(2) How It Works
Refer to the course “19.1 Large Models Basic Courses ->19.1.1Large Language Models Courses -> Large Language Models Deployment” to obtain your API key, and update the configuration file accordingly.
cd large_models/
vim config.py
python3 openai_tts_demo.py
① Module Import
from config import *
② Definition for TTS Class
③ Function Extension
vim openai_tts_demo.py
i
  • Voice Interaction
(2) How It Works
(3) Experiment Steps
① Power on the device and connect to it via MobaXterm (refer to Appendix “5.1 Remote Connection Tools and Instructions” for connection guidance).
ll /dev | grep USB
cd large_models/
vim config.py
⑥ Run the program:
(4) Function Realization
(5) Brief Program Analysis
(1) Module Import
(3) Main Functional Logic
    kws.start()
                if asr_result:
                    tts.tts(response)
            time.sleep(0.02)
            kws.exit()
            except:
        except BaseException as e:
            print(e)
19.1.3 Vision Language Model Courses
(1) Basic Concept
(2) Features
(3) How It Works
① Image Captioning
② Visual Question Answering
③ Image Retrieval
④ Augmented Reality (AR)
⑥ Social Media Interaction
⑦ Medical Imaging Analysis
  • This section requires the configuration of the API key in “19.1.3 Vision Language Model Accessing -> Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
(1) Experiment Steps
cd large_models/
Run the program:
(2) Function Realization
  • This section requires the configuration of the API key in “19.1.3 Vision Language Module Courses -> Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
cd large_models/
② Run the program:
(3) Function Expansion
Change Pictures:
② Then, input the command:
i
cd large_models/
② Run the program:
④ Run the program:
  • This section requires the configuration of the API key in “1.3.2 Vision Language Model Accessing” before proceeding. Additionally, ensure that the images to be used in this section are imported.
cd large_models/
② Run the program:
python3 openai_vllm_ocr.py
Change Pictures:
i
⑤ Run the program:
19.1.4 Multimodal Model Basic Courses
(1) Basic Concept
(2) Features
(3) How It Works
① Education
② Healthcare
③ Entertainment
④ Advertising and Marketing
ll /dev | grep USB
cd large_models/
vim config.py
vim openai_agent_demo.py
⑤ Run the program:
python3 openai_agent_demo.py
19.2 Multimodal Model Courses
19.2.1 Multimodal Model: Voice Control
The large model used in this lesson is an online model, requiring the main control device to maintain a stable network connection (it is recommended to use a wired network connection).
  • Brief Game Instructions
Once the program starts running, the AI voice interaction box/6-microphone array (collectively referred to as the voice device) will announce “Ready”.
Afterward, say the designated wake-up phrase “hello hi wonder” to activate the voice device, which will respond with “I am here”. You can then control JetArm with your voice. For example, to rotate servo 1 on the robot, say “Number one rudder rotates 90 degrees”. The terminal will display the recognized voice command, and the voice device will announce the generated response after processing, then execute the corresponding action.
(1) Version Confirmation
Before running the functionality, it is essential to confirm that your microphone version configuration is correct within the system.
① After remotely logging into the machine using NoMachine, click on the desktop icon .
② Select the appropriate microphone version configuration based on the hardware you are using. For example, choose the robot type as “JetArm Advance”, camera type as “Gemini”, and ASR language as “English”.
For the “Six-Microphone Array”, choose “xf” as the microphone type.
③ Then click “Apply & Save”.
④ Restart the command terminal or enter the following command in the existing terminal to refresh the environment variables:
source ~/.zshrc
(2) Large Model API-KEY Configuration
Open a new terminal and enter the following command to open the configuration file:
vim /home/ubuntu/ros2_ws/src/large_models/large_models/large_models/config.py
Refer to the “19.1 Large Model Basic Courses->19.1.1 Large Language Model Courses-> Large Language Model Deployment” to obtain the API-KEY for the large model. After acquiring the visual large model API-KEY (from the Openrouter website), fill it into the vllm_api_key parameter. Similarly, obtain the API-KEY for the large language model (from the OpenAI website) and fill it into the llm_api_key parameter, as indicated by the red box in the image below.
(3) Starting and Stopping the Game
  • The input commands must strictly observe case sensitivity and spacing.
  • The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet.
① Double-click to launch the command bar. Enter the command and press Enter to disable the auto-start service.
② Execute the following command to disable the app auto-start service.
③ Enter the following command and press Enter to initiate voice-controlled game:
ros2 launch large_models_examples llm_control_servo.launch.py
Once the command line outputs the message below and the device announces “I am ready”, it indicates that the voice device has been initialized. You can now say the wake word, “hello hi wonder”.
④ When the command line shows the output below and the device announces “I am here”, it means the voice device has been successfully activated. At this point, the system will begin recording the user’s command. You can then say the command, “Servo No. 1 move to 90 degrees,” and wait for the large model to process the recognition.
Similarly, you can refer to the textual input prompts provided in the program and issue voice commands to the robotic arm.
⑤ When the command line shows the output below, it indicates that the cloud-based voice large model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under “publish_asr_result”.
⑥ When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (”response”), as well as designed an action that aligns with the user’s command meaning.
The response is automatically generated by the large model, ensuring the accuracy of the meaning, though the wording and structure of the reply may vary.
⑦ When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step 4) to reactivate the voice device using the wake-up word and begin a new round of interaction.
⑧To exit this feature, simply press “Ctrl+C” in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
  • How It Works
Once the feature is activated, we can freely organize commands, for example: “Servo No. 1 move to 90 degrees”, to control the rotation of JetArm’s servo No. 1 by 90°.
  • Brief Program Analysis
(1) Analysis of launch File
The program is saved at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_control_servo.launch.py
① Library Files Import
os: Used for handling file paths and operating system-related functionalities.
ament_index_python.packages.get_package_share_directory: Used to obtain the shared directory path of a ROS2 package.
launch_ros.actions.Node: Used to define a ROS2 node
launch.substitutions.LaunchConfiguration: Used to retrieve parameter configurations from a Launch file.
LaunchDescription, LaunchService: Used to define and launch a Launch file.
launch_description_sources PythonLaunchDescriptionSource: Used to include other Launch files.
launch.actions.IncludeLaunchDescription, DeclareLaunchArgument, OpaqueFunction: Used to define actions and parameters within a Launch file.
② Define launch_setup Function
    mode = LaunchConfiguration('mode', default=1)
    mode_arg = DeclareLaunchArgument('mode', default_value=mode)
    large_models_package_path = get_package_share_directory('large_models')
            os.path.join(sdk_package_path, 'launch/jetarm_sdk.launch.py')),
    llm_control_servo_node = Node(
        package='large_models_examples',
        executable='llm_control_servo',
    return [mode_arg,
            sdk_launch,
            large_models_launch,
            llm_control_servo_node,
This function is used to configure and initiate actions in the Launch file.
mode = LaunchConfiguration('mode', default=1): Defines a Launch parameter named mode, with a default value of 1.
mode_arg = DeclareLaunchArgument('mode', default_value=mode): Declares the mode parameter and adds it to the Launch description.
sdk_package_path and large_models_package_path: These are used to retrieve the shared directory paths for the sdk and large_models packages, respectively.
sdk_launch: Uses IncludeLaunchDescription to include the jetarm_sdk.launch.py Launch file from the sdk package.
large_models_launch: Uses IncludeLaunchDescription to include the start.launch.py Launch file from the large_models package, passing the mode parameter.
llm_control_servo_node: Defines a ROS2 node from the large_models package that executes the llm_control_servo executable, and prints its output to the screen.
Finally, the function returns a list containing all the Launch actions.
③ Define generate_launch_description function:
    return LaunchDescription([
This function is used to generate a Launch description.
Use OpaqueFunction to add the launch_setup function to the Launch description.
④ Main program entry:
    # Create a LaunchDescription object. 创建一个LaunchDescription对象
    ls = LaunchService()
    ls.run()
ld = generate_launch_description(): Generates a Launch description object.
ls = LaunchService(): Creates a Launch service object.
ls.include_launch_description(ld): Adds the Launch description to the Launch service.
ls.run(): Starts the Launch service, executing all the defined Launch actions.
(2) Analysis of Python Files
The program is saved at : /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_control_servo.py
① Defining the Prompt Template (PROMPT)
    PROMPT = '''
#Role
You are an intelligent robot arm, and you need to generate corresponding instructions based on the input content.
##Requirements and Restrictions
1. According to the input action content, find the corresponding instructions in the action function library and output the corresponding instructions.
2. Weave a concise (10 to 30 words), humorous and continuous feedback information for each action sequence to make the communication process interesting.
3. The top is the positive z-axis, the left is the negative y-axis, and the front is the positive x-axis, in meters
4. The servo numbers are 1, 2, 3, 4, 5, 10, and the rotation range is [-120, 120] degrees. If the range is exceeded, the action returns []
5. The initial position is [0, 48, -72, -96, 0, -30]
6. Output the json result directly, do not analyze, and do not output redundant content.
7. Format: {"action": ["xx", "xx"], "response": "xx"}
##Structural requirements:
- The "action" key stores an array of function names in order. When the corresponding action function cannot be found, action outputs [].
- The "response" key is accompanied by a brief response, which perfectly meets the above word count and style requirements, the language type of the user is consistent.
- **Special processing**: If the servo running time is not specified, it is fixed to 1 second. If there is no delay or stop between two actions, they are combined
##Action function library
- Control the servo to move to the specified position at the specified time: set_position(1, ((1, -120), (2, 90)))
- Control the robot to move the specified distance in the specified direction: move(x, y, z)
- Delay for a specified time: time.sleep(1)
##Example
Input: Servo No. 1 and Servo No. 2 move to -90 degrees and 90 degrees respectively within 2 seconds
Output: {"action": ["set_position(2, [[1, -90], [2, 90]])"], "response": "Received, execute immediately"}
Input: Servo No. 1 rotates 45 degrees within 1 second
Output: {"action": ["set_position(1, [[1, 45]])"], "response": "OK"}
Input: Servo No. 6 turns 15 degrees
Output: {"action": ["set_position(1, [[6, 15]])"], "response": "OK, Servo No. 6 turns to 15 degrees"}
Input: Servo No. 3 turns to 11 degrees, Servo No. 4 turns to 0 degrees, stop for 2 seconds
Output: {"action": ["set_position(1, [[3, 11], [4, 0]])", "time.sleep(2)"], "response": "OK"}
Input: Servo No. 1 turns 20 degrees, Servo No. 3 turns 45 degrees, stop for 1 second, Servo No. 1 turns 50 degrees, Servo No. 2 turns 0 degrees
Output: {"action":["set_position(1, [[1, 20], [3, 45]])", "time.sleep(1)", "set_position(1, [[2, 0]])"], "response": "OK"}
Input: Move down 2cm, stop for 1s, Servo 4 turns to 30 degrees, stop for 1s, move forward 3cm
Output: {"action":["move(0, 0, -0.02)", "time.sleep(1)", "set_position(1, [[4, 30]])", "time.sleep(1)", "move(0.03, 0, 0)"], "response": "No problem"}
② Initializing Variables
	    self.action = []
        self.interrupt = False
        self.llm_result = ''
        self.action_finish = False
        # self.llm_result = '{\"action\": [\"set_position(1, [[10, -20]])\"], \"response\": \"好嘞\"}'
	        # self.llm_result = '{\"action\": [\"move(0, 0, -0.05)\"], \"response\": \"坐稳了,准备下移5cm!\"}'
        self.id_dict = {'1': 0, '2': 1, '3': 2, '4': 3, '5': 4, '10': 5}
        self.current_pulse = [500, 700, 115, 100, 500, 575]
        self.current_position = [0.1, 0, 0.226]
self.action: This variable stores the action list that the LLM generates based on the instructions it receives.
self.interrupt: A flag used to manage the interrupt process.
self.llm_result: This variable holds the parsed results from the LLM.
self.running: A flag that controls whether the robot should continue running or stop.
self.id_dict: A dictionary that maps each servo’s ID to its index, facilitating quick lookups when adjusting the robot’s components.
self.current_pulse: The pulse value corresponding to the current position of the servo. This is used to control the exact movement of the robot’s components.
self.current_position: A variable that tracks the current position of the robotic arm in a 3D coordinate system.
③ Create a Publisher
A publisher is created to send messages of type String to the tts_node/tts_text topic. This topic is used to transmit text content that will be converted to speech for feedback (Text-to-Speech, TTS).
④ Create a Subscriber
⑤ Create a Publisher
	        self.joints_pub = self.create_publisher(ServosPosition, 'servo_controller', 1) # Servo control 舵机控制
A publisher is created to send messages of type ServosPosition to the servo_controller topic. This topic is used to control the positions of the servos, allowing for precise adjustments and movements of the robot’s parts based on the input provided.
⑥ Create a Timer
⑦ Set up the LLM Model
	    msg = SetModel.Request()
        msg.model = llm_model
        msg.model_type = 'llm'
        msg.api_key = api_key
        msg.base_url = base_url
⑧ Initialize the Robot Arm’s Starting Position
	        self.set_position(1.5, [[1, 0], [2, 48], [3, -72], [4, -96], [5, 0], [10, -30]])
⑨ Initialize the Robot Arm’s Starting Position
	    msg = set_joint_value_target(self.current_pulse[:-1])
        endpoint = self.send_request(self.set_joint_value_target_client, msg)
        pose_t, pose_r = endpoint.pose.position, endpoint.pose.orientation
        mat = common.xyz_quat_to_mat([pose_t.x, pose_t.y, pose_t.z], [pose_r.w, pose_r.x, pose_r.y, pose_r.z])
        position, rpy = common.mat_to_xyz_euler(mat)
        self.current_position = [position, rpy]
Call the set_joint_value_target function to generate a message (msg) for setting the joint target values.
Invoke the send_request method to send a request to the kinematics/set_joint_value_target service and retrieve the robot arm’s end position.
Extract the end position (pose_t) and orientation (pose_r) from the service’s response.
Use common.xyz_quat_to_mat to convert the position and orientation into a matrix, and then use common.mat_to_xyz_euler to convert the matrix back into position and Euler angles.
Store the current position and orientation of the robot arm in self.current_position.
⑩ set_position Method
	    def set_position(self, duration, positions):
        msg = ServosPosition()
        msg.duration = float(duration)
        position_list = []
        for i in positions:
            position = ServoPosition()
            position.id = i[0]
            position.position = float(i[1])
            position_list.append(position)
            if i[0] != 10:
                self.current_pulse[self.id_dict[str(i[0])]] = 500 + float(i[1])/240*1000
                self.current_pulse[self.id_dict[str(i[0])]] = 700 + float(i[1])/240*1000
        msg.position = position_list
        msg.position_unit = "deg"
        self.joints_pub.publish(msg)
This function controls the robotic arm’s servos to move to specified positions within a given time and updates the current state of the arm.
It iterates through the positions list to set target positions for each servo:
position.id: represents the servo ID
position.position: indicates the target position (in degrees).
The current pulse value (self.current_pulse) for each servo is updated based on the ID:
If the servo ID is not 10, the pulse is calculated as: 500 + (angle / 240) * 1000.
If the servo ID is not 10, the pulse is calculated as: 700 + (angle / 240) * 1000.
The list of servo positions is then assigned to msg.position, with the unit specified as “deg” (degrees).
Finally, the command is published through self.joints_pub.publish(msg) to control the servo movements.
⑪ Update Robotic Arm Status
        # self.get_logger().info(f'{self.current_pulse}')
        # self.get_logger().info(f'{self.current_position}')
⑫ Move Method
	    def move(self, x, y, z):
        self.current_position[0][0] += x
        self.current_position[0][1] += y
        self.current_position[0][2] += z
        msg = set_pose_target(self.current_position[0], self.current_position[1][1], [-180.0, 180.0], 1.0)
        res = self.send_request(self.set_pose_target_client, msg)
        if res.pulse:
            servo_data = res.pulse
            set_servo_position(self.joints_pub, 1, ((4, servo_data[3]), (3, servo_data[2]), (2, servo_data[1]), (1, servo_data[0])))
            self.current_pulse[:-1] = servo_data
This function controls the robotic arm to move a certain distance in a specified direction and updates its current state accordingly.
Update robotic arm status:
self.current_position[0][0] += x: Update the position along the X-axis
self.current_position[0][1] += y: Update the position along the Y-axis
self.current_position[0][2] += z: Update the position along the Z-axis
Call the set_pose_target function to generate a message (msg) for setting the target pose.
Self.current_position[0]: target position
self.current_position[1][1]: target pose
[-180.0, 180.0]: joint motion range
1.0: Motion time (1 second)
Invoke the send_request method to send a request to the kinematics/set_pose_target service and retrieve the pulse value of the servo.
If the returned pulse values from the service (res.pulse) are valid, the set_servo_position method is called to control the servo movement and update self.current_pulse.
⑬ Play_audio_finish_callback Method:
Handles the callback triggered after audio playback finishes, re-enabling the voice wake-up function.
⑭ process Method
	    def process(self):
            if self.llm_result:
                msg = String()
                if 'action' in self.llm_result:  # If a corresponding action is returned, extract it and proceed with processing. 如果有对应的行为返回那么就提取处理
                    # self.get_logger().info(str(result))
                    action_list = []
                    if 'action' in result:
                    if 'response' in result:
                        response = result['response']
                    msg.data = response
                    for i in action_list:
                        if self.interrupt:
                        if 'set_position' in i:
                            eval('self.' + i)
                        elif 'move' in i:
                            eval('self.' + i)
                            eval(i)
                else:  # No corresponding action, just respond. 没有对应的行为,只回答
                    response = self.llm_result
                    msg.data = response
                self.action_finish = True
            if self.play_audio_finish and self.action_finish:
                msg = SetBool.Request()
                msg.data = True
Acts as the main loop, processing commands received from the LLM, parsing them, and executing the corresponding actions. Supports both action execution and voice feedback.
⑮ Main Function
    node = LLMControlServo('llm_control_servo')
Creates and initializes the ROS2 node.
Starts a multithreaded executor to handle the node’s callback functions.
Destroys the node and releases resources upon program termination.
19.2.2 Multimodal Model: Color Sorting
Once the program starts running, the AI voice interaction box/6-microphone array (collectively referred to as the voice device) will announce “Ready”. Afterward, say the designated wake-up phrase “hello hi wonder” to activate the voice device, which will respond with “I am here”. You can then control JetArm with your voice. For example, to rotate servo 1 on the robot, say “Take away the red block”. The terminal will display the recognized voice command, and the voice device will announce the generated response after processing, then execute the corresponding action.
② Select the appropriate microphone version configuration based on the hardware you are using. For example, choose the robot type as “JetArm Advance”, camera type as “Gemini,” and ASR language as “English”.
① Then click “Apply & Save”.
② Restart the command terminal or enter the following command in the existing terminal to refresh the environment variables:
source ~/.zshrc
  • Starting and Stopping the Game
(1) Double-click to launch the command bar. Enter the command and press Enter to disable the auto-start service.
(2) Execute the following command to disable the app auto-start service.
(3) Enter the following command and press Enter to initiate color sorting game:
ros2 launch large_models_examples llm_3d_object_sorting.launch.py
(4) Once the command line outputs the message below and the device announces “I am ready”, it indicates that the voice device has been initialized. You can now say the wake word, “hello hi wonder”.
(5) When the command line shows the output below and the device announces “I am here”, it means the voice device has been successfully activated. At this point, the system will begin recording the user’s command.
You can then say the command, “Take away the red block.,” and wait for the large model to process the recognition.
(6) When the command line shows the output below, it indicates that the cloud-based voice large model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under “publish_asr_result”.
(7) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (“response”), as well as designed an action that aligns with the user’s command meaning.
(8) When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step 4) to reactivate the voice device using the wake-up word and begin a new round of interaction.
(9) To exit this feature, simply press “Ctrl+C” in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
  • How It Works
Once the game mode is activated, you can freely structure commands, such as: “Take away the red block,” to control JetArm to automatically grab the red block within its line of sight and place it on the left side of the robotic arm.
The program is saved at:/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_object_sorting.launch.py
    large_models_examples_package_path = get_package_share_directory('large_models_examples')
    object_sorting_launch = IncludeLaunchDescription(
            os.path.join(large_models_examples_package_path, 'large_models_examples', 'object_sorting_node.launch.py')),
    llm_object_sorting_node = Node(
        executable='llm_object_sorting',
    return [mode_arg,
            object_sorting_launch,
            llm_object_sorting_node,
objet_sorting_launch: Uses IncludeLaunchDescription to include the object_sorting_node.launch.py Launch file from the large_models package, passing the mode parameter.
llm_control_servo_node: Defines a ROS2 node from the large_models package that executes the llm_object_sorting executable, and prints its output to the screen.
    ls.run()
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_object_sorting.py
import re
import json
from std_msgs.msg import String, Bool
from std_srvs.srv import Trigger, SetBool, Empty
from large_models.config import *
from large_models_msgs.srv import SetModel, SetString
from interfaces.srv import SetStringBool
② Defining the Prompt Template (PROMPT)
	#Role
You are an intelligent robot arm that needs to generate corresponding instructions based on the input content.
2. Weave a concise (10 to 30 words), humorous and ever-changing feedback information for the action sequence to make the communication process interesting.
3. Directly output the json result, do not analyze, and do not output redundant content.
4. You can sort three colors of objects: red, green and blue
4. Format: {"action": "xx", "response": "xx"}
##Structural Requirements:
- The "action" key carries a function name string array. When the corresponding action function cannot be found, action outputs "".
- The "response" key is accompanied by a carefully conceived short reply, which perfectly meets the above word count and style requirements.
##Implementation principles
- Before the final output, implement comprehensive verification to ensure that the response is not only formatted and interesting, but also has no omissions from the above specifications.
- Pick up objects of different colors: color_sorting('red')
##Example
Input: Take away the green block
Output: {"action": "color_sorting('green')", "response": "Okay, start sorting green"}
Input: Take away the blue block
Output: {"action": "color_sorting('blue')", "response": "The blue block goes with you"}
Input: Only keep the red, take the others
Output: {"action": "color_sorting('blue','green')", "response": "Okay, execute now"}
Input: Sorting color blocks
Output: {"action": "color_sorting('red', 'blue','green')", "response": "No problem"}
③ Initializing Variables
	    self.action = []
	        # self.llm_result = '{"action": "color_sorting(\'blue\', \'red\', \'green\', \'tag_1\')", "response": "ok!"}'
④ Create a Publisher
⑤ Create a Subscriber
⑥ Create a Server
        self.enter_client = self.create_client(Trigger, 'object_sorting/enter')
        self.enter_client.wait_for_service()
        self.start_client = self.create_client(SetBool, 'object_sorting/enable_sorting')
⑧ Enter Color Sorting Mode
	        self.send_request(self.enter_client, Trigger.Request())
⑨ Play the Startup Audio
⑩ process Method
	    def process(self):
            if self.llm_result:
                msg = String()
                    # result = json.loads(self.llm_result)
                        text = result['action']
                        # Use regular expressions to extract all strings inside. 使用正则表达式提取括号中的所有字符串
                        pattern = r"color_sorting\((['\"][^'\"]+['\"](?:\s*,\s*['\"][^'\"]+['\"])*)\)"
                        #  Use re.search to find the matching result. 使用re.search找到匹配的结果
                        match = re.search(pattern, text)
                        # Extract the result. 提取结果
                        if match:
                            # Retrieve all argument parts (the content inside the parentheses). 获取所有的参数部分(括号内的内容)
                            params = match.group(1)
                            # Use regular expressions to split the string arguments. 使用正则拆分出各个字符串参数
                            colors = re.findall(r"['\"]([^'\"]+)['\"]", params)
                            self.get_logger().info(str(colors))
                            color_msg = SetStringBool.Request()
                            for i in ['red', 'green', 'blue', 'tag_1', 'tag_2', 'tag_3']:
                                color_msg.data_str = i
                                if i in colors:
                                    color_msg.data_bool = True
                                    color_msg.data_bool = False
                                self.send_request(self.set_target_client, color_msg)
                            # Enable sorting. 开启分拣
                            start_msg = SetBool.Request()
                            start_msg.data = True
                            self.send_request(self.start_client, start_msg)
                        msg.data = result['response']
                    msg.data = self.llm_result
                msg.data = True
Handling new commands:
A String message is created for sending speech feedback.
If the command includes an action (‘action’),
the system first uses eval to parse the command’s JSON data.
It then uses regular expressions to extract parameters for the color_sorting function, which includes colors and labels.
The system iterates over a predefined list of colors and tags ([‘red’, ‘green’, ‘blue’, ‘tag_1’, ‘tag_2’, ‘tag_3’]), setting the sorting target for objects accordingly.
If the color or label is present in the command, it sets data_bool to True;
Otherwise, it sets it to False.
After that, the system sends a request to the object_sorting/set_target service, defining the sorting target.
After that, the system sends a request to the object_sorting/enable_sorting service to enable sorting functionality.
  • If the command includes a response (‘response’), speech feedback is sent.
  • If no action is specified in the command, only the speech feedback is triggered.
  • After processing the command, self.llm_result is cleared, preparing for the next command.
If there are no new commands, the system waits for 10 milliseconds before checking again.
When self.running becomes False, the system exits the loop and shuts down the ROS2 node.
  • Main Function
    node = LLMColorSorting('llm_color_sorting')
19.2.3 Multimodal Model: Waste Classification
Afterward, say the designated wake-up phrase “hello hi wonder” to activate the voice device, which will respond with “I am here”. You can then control JetArm with your voice. For example, to rotate servo 1 on the robot, say “Take away the banana peel”. The terminal will display the recognized voice command, and the voice device will announce the generated response after processing, then execute the corresponding action.
② Select the appropriate microphone version configuration based on the hardware you are using. For example, choose the robot type as “JetArm Advance,” camera type as “Gemini,” and ASR language as “English”.
source ~/.zshrc
Refer to the “19.1 Large Model Basic Courses -> 19.1.1 Large Language Model Courses->Large Language Model Deployment” to obtain the API-KEY for the large model. After acquiring the visual large model API-KEY (from the Openrouter website), fill it into the vllm_api_key parameter. Similarly, obtain the API-KEY for the large language model (from the OpenAI website) and fill it into the llm_api_key parameter, as indicated by the red box in the image below.
(3) Enter the following command and press Enter to initiate waste sorting game:
ros2 launch large_models_examples llm_waste_classification.launch.py
You can then say the command, “Take away the red block.” and wait for the large model to process the recognition.
  • How It Works
Once the game mode is activated, you can freely structure commands, such as: “Take away the banana peel,” to control JetArm to automatically grab the banana peel waste card within its line of sight and place it on the right side of the robotic arm.
The program is saved at: ros2_ws/src/large_models_examples/large_models_examples/llm_waste_classification.launch.py
    start = LaunchConfiguration('start', default='false')
    start_arg = DeclareLaunchArgument('start', default_value=start)
    display = LaunchConfiguration('display', default='true')
    display_arg = DeclareLaunchArgument('display', default_value=display)
    yolov8_node = Node(
        package='example',
        executable='yolov8_node',
        parameters=[{'classes': ['BananaPeel','BrokenBones','CigaretteEnd','DisposableChopsticks','Ketchup','Marker','OralLiquidBottle','PlasticBottle','Plate','StorageBattery','Toothbrush', 'Umbrella']},
                    { 'engine': 'garbage_classification_640s.engine', 'lib': 'libmyplugins.so', 'conf': 0.8},]
    waste_classification_node = Node(
        package='app',
        executable='waste_classification',
        parameters=[{'start': start, 'display': display, 'app': False}],
    return [start_arg,
            display_arg,
            depth_camera_launch,
            sdk_launch,
            yolov8_node,
            waste_classification_node,
large_models_package_path: This is used to retrieve the shared directory paths for the large_models packages
waste_classification_launch: Uses IncludeLaunchDescription to include the waste_classification_launch Launch file.
llm_control_servo_node: Defines a ROS2 node from the large_models package that executes the llm_waste_classification executable, and prints its output to the screen.
    ls.run()
The program is saved at: ros2_ws/src/jetarm_large_models_examples/large_models_examples/llm_waste_classification.py
import re
import json
from interfaces.srv import SetStringList
	#Role
3. Garbage is divided into four categories: food waste (food_waste), hazardous waste (hazardous_waste), recyclable waste (recyclable_waste), and other waste (residual_waste).
4. Directly output the json result, do not analyze it, and do not output redundant content.
5. Format: {"action": "xx", "response": "xx"}
##Implementation Principles
- Before final output, implement comprehensive verification to ensure that the response is not only formatted in compliance, but also interesting and without missing any of the above specifications.
- Sort different garbage: garbage_classification('food_waste')
- Stop: garbage_classification('')
##Example
Input: Take away the food waste
Output: {"action": "garbage_classification('food_waste')", "response": "Got it, I'll clean it up right away"}
Input: Take away the banana peel
Output: {"action": "garbage_classification('food_waste')", "response": "Okay, banana peels belong to food waste"}
Input: Clean up hazardous waste
Output: {"action": "garbage_classification('hazardous_waste')", "response": "Hazardous waste must be removed"}
Input: Find recyclable waste
Output: {"action": "garbage_classification('recyclable_waste')", "response": "This is not a problem for me"}
Input: Sort other garbage
Output: {"action": "garbage_classification('residual_waste')", "response": "Received, received"}
Input: Take away the food waste first, then clean up the hazardous waste
Output: {"action": "garbage_classification('food_waste','hazardous_waste')", "response": "Garbage cleanup, execute immediately"}
Input: Only recyclable garbage is left, take away everything else
Output: {"action": "garbage_classification('food_waste','hazardous_waste',"residual_waste')", "response": "No problem"}
	    self.action = []
        # self.llm_result = '{"action": "garbage_classification(\'food_waste\', \'hazardous_waste\', \'residual_waste\', \'recyclable_waste\')", "response": "收到,我马上收拾"}'
⑥ Create a Server
        self.enter_client = self.create_client(Trigger, 'waste_classification/enter')
        self.start_client = self.create_client(SetBool, 'waste_classification/enable_transport')
⑧ Enter Waste Sorting Mode
⑩ Process the LLM command and create a voice feedback message.
	                msg = String()
⑪ Check whether the command includes an action.
⑫ Parse the command.
⑬ Extract the waste classification action.
                        self.get_logger().info(result['action'])
                        pattern = r"garbage_classification\((['\"][^'\"]+['\"](?:\s*,\s*['\"][^'\"]+['\"])*)\)"
⑭ Extract the type of waste classification.
	                        if match:
                            objects = re.findall(r"['\"]([^'\"]+)['\"]", params)
⑮ Set the waste classification target.
	                        msgs = SetStringList.Request()
                            msgs.data = objects
                            res = self.send_request(self.set_target_client, msgs)
                            if res.success:
                                self.get_logger().info('\033[1;32m%s\033[0m' % 'set object success')
                                self.get_logger().info('\033[1;32m%s\033[0m' % 'set object fail')
Create a SetStringList.Request message to define the waste classification target. Use the send_request method to send a request to the waste_classification/set_target service, setting the waste classification target.
⑯ Initiate waste classification transport.
Create a SetBool.Request message to define the waste classification transport functionality. After that, use the send_request method to send a request to the waste_classification/enable_transport service, starting the waste classification transport process.
⑰ Main Function
    node = LLMWasteClassification('llm_waste_classification')
19.2.4 Multimodal Model: Object Sorting
Afterward, say the designated wake-up phrase “hello hi wonder” to activate the voice device, which will respond with “I am here”. You can then control JetArm with your voice. For example, to rotate servo 1 on the robot, say “Take the cylinder away”. The terminal will display the recognized voice command, and the voice device will announce the generated response after processing, then execute the corresponding action.
② Select the appropriate microphone version configuration based on the hardware you are using. For example, choose the robot type as “JetArm Advance”, camera type as “Gemini****”, and ASR language as “English”.
For the “Six-Microphone Array,” choose “xf” as the microphone type.
source ~/.zshrc
(3) Enter the following command and press Enter to initiate object sorting game:
(4) Once the command line outputs the message below and the device announces “I am ready,” it indicates that the voice device has been initialized. You can now say the wake word, “hello hi wonder”.
(5) When the command line shows the output below and the device announces “I am here,” it means the voice device has been successfully activated. At this point, the system will begin recording the user’s command.
(6) At this point, begin recording the user’s command. Then, say the phrase ‘Take the cylinder away’ and wait for the large model’s recognition. Similarly, you can refer to the text prompts in the program to issue voice commands to the robotic arm.
(7) When the command line shows the output below, it indicates that the cloud-based voice large model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under “publish_asr_result”.
(8) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (“response”), as well as designed an action that aligns with the user’s command meaning.
  • How It Works
After the feature is activated, we can freely organize commands, such as “Take the cylinder away”. We place the cylinder in front of the camera beforehand, and the JetArm will automatically grab the cylinder within its line of sight and place it to the left side of the robotic arm.
The program is saved at:/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_3d_object_sorting.launch.py
    # Obtain the path of package 获取包路径
            os.path.join(large_models_examples_package_path, 'large_models_examples', '3d_object_sorting.launch.py')),
    llm_3d_object_sorting_node = Node(
        executable='llm_3d_object_sorting',
    return [mode_arg,
            llm_3d_object_sorting_node,
objet_sorting_launch: Uses IncludeLaunchDescription to include the 3d_object_sorting.launch.py file from the large_models package, passing the mode parameter.
    ls.run()
The program is saved at:/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_3d_object_sorting.py
import re
import json
    PROMPT = '''
#Role
3. Objects are divided into three categories: cylinder, sphere, and cuboid.
- Sorting objects: object_sorting('cylinder')
##Example
Input: Sorting cylinders
Output: {"action": "object_sorting('cylinder')", "response": "OK, start sorting cylinders"}
Input: Take the cuboid away
Output: {"action": "object_sorting('cuboid')", "response": "The cuboid is gone"}
Input: Only keep the sphere and take the others away
Output: {"action": "object_sorting('cylinder','cuboid')", "response": "OK, execute now"}
Input: Sorting objects
Output: {"action": "object_sorting('cylinder', 'cuboid','sphere')", "response": "No problem"}
	    self.action = []
        # self.llm_result = '{"action": "object_sorting(\'cylinder\', \'cuboid\', \'sphere\')", "response": "收到,我马上收拾"}'
⑥ Create a Server
        self.enter_client = self.create_client(Trigger, 'shape_recognition/enter')
        self.start_client = self.create_client(SetBool, 'shape_recognition/set_running')
	                msg = String()
	                msg = String()
	                if 'action' in self.llm_result:  # If there is a corresponding action returned, extract and handle it. 如果有对应的行为返回那么就提取处理
⑬ Extract the object sorting action
                        pattern = r"object_sorting\((['\"][^'\"]+['\"](?:\s*,\s*['\"][^'\"]+['\"])*)\)"
Use regular expressions to extract the parameters (object types) of the object_sorting function. The regular expression pattern is used to match the relevant part of the object_sorting function’s parameters.
⑭ Extract the object type.
                        if match:
⑮ Set the object sorting target
	                        # Enable recognition. 开启识别
                            msgs.data = objects
                            if res.success:
Create a SetStringList.Request message to define the object sorting target. After that, the system sends a request to the object_sorting/set_target service, defining the sorting target.
⑯ Initiate object sorting
Create a SetBool.Request message to define the object sorting functionality. After that, the system sends a request to the object_sorting/enable_sorting service to enable sorting functionality.
⑰ Main Function
    node = LLMObjectSorting('llm_object_sorting')
19.3 Embodied AI Applications
19.3.1 Overview of Multimodal Information Fusion
Multimodal data fusion involves effectively combining information from various modalities, such as text, images, and speech, to create a more comprehensive and accurate representation of data. This process is crucial in artificial intelligence, as real-world information is typically multimodal, and relying on a single modality often fails to provide sufficient context or detail. By integrating multiple sources of data, multimodal fusion aims to enhance the performance and robustness of models.
The approaches to multimodal data fusion can be broadly categorized as follows:
Early Fusion: This approach combines data from different modalities at the early stages of data processing. Typically, this occurs at the input layer, where data alignment and transformation techniques are used to map raw data into a common space, creating a richer and more expressive form of data. For example, in image and speech fusion, data from both modalities can be directly concatenated as the input to a neural network.
Late Fusion: This method merges data from different modalities at the middle or output layers of the model. It allows each modality to be processed with specific algorithms, making it easier to add or swap modalities in the future. For example, the results of image recognition and text analysis can be combined to reach a final decision.
Hybrid Fusion: This approach combines the advantages of both early and late fusion, conducting multiple fusions at different stages of processing. It leverages the complementary nature of different modalities to enhance the performance and robustness of the model.
Feature-Level Fusion: In this approach, features extracted from multiple modalities are transformed into a single feature vector, which is then input into a classification model to generate the final decision. This fusion occurs during the feature extraction stage, combining different types of data early on.
Decision-Level Fusion: This approach combines the decisions made based on different modalities to arrive at the final decision. It is known for its robustness against interference, requiring relatively low sensor performance and variety, though it may result in some information loss.
Deep Fusion: Occurring at the feature extraction stage, this method mixes multimodal data within the feature space to obtain fused features. It compensates for missing features from other modalities and applies these fused features during the prediction stage for classification or regression tasks.
Multimodal information fusion holds significant theoretical importance and demonstrates tremendous potential in practical applications. For example, in fields such as autonomous driving, medical image analysis, and human-computer interaction, multimodal fusion technologies have been widely applied, significantly improving system performance and reliability.
19.3.2 Embodied AI Applications in Real-Time Detection
Once the program starts running, the 6-microphone array (collectively referred to as the voice device) will announce “Ready”.
Afterward, say the designated wake-up phrase “hello hi wonder” to activate the voice device, which will respond with “I am here”. Once activated, you can control the JetArm using voice commands. For example, you can simply say, “What do you see?” to issue a command. Once the command is given, the terminal will display the recognized image content, and the “voice device” will announce the response generated from the analysis.
② Select the appropriate microphone version configuration based on your hardware. For example: choose the robot type: JetArm Advance, camera type: Gemini, and language: English.
source ~/.zshrc
Refer to the “19.1.1 Large Language Model Courses -> Large Language Model Deployment” to obtain the API-KEY for the large model. After acquiring the visual large model API-KEY (from the Openrouter website), fill it into the vllm_api_key parameter. Similarly, obtain the API-KEY for the large language model (from the OpenAI website) and fill it into the llm_api_key parameter, as indicated by the red box in the image below.
(3) Enter the following command and press Enter to initiate real-time detection game:
ros2 launch large_models_examples vllm_with_camera.launch.py
You can then say the command, “What do you see.,” and wait for the large model to process the recognition.
(7) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (”response”), as well as designed an action that aligns with the user’s command meaning.
  • How It Works
Once the feature is activated, you can freely phrase your commands, such as saying, “What do you see?” JetArm will automatically recognize the scene within its field of view and provide a detailed description of the current surroundings.
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_with_camera.launch.py
    vllm_with_camera_node = Node(
    return [depth_camera_launch,
            sdk_launch,
            vllm_with_camera_node,
depth_camera_launch: Use IncludeLaunchDescription to include the depth_camera.launch.py launch file from the large_models package and pass the mode parameter.
sdk_launch:Uses IncludeLaunchDescription to include the object_sorting_node.launch.py Launch file from the large_models package, passing the mode parameter.
vllm_with_camera_node:Defines a ROS2 node from the large_models package that executes the vllm_with_camera executable, and prints its output to the screen.
③ Main program entry:
    ls.run()
The source code is located at:
/home/ubuntu/ros2_ws/src/jetarm_large_models/large_models/large_models/vllm_with_camera.py
① Feature Package Import
import json
import queue
from large_models_msgs.srv import SetString, SetModel, SetInt32
from servo_controller_msgs.msg import ServosPosition, ServoPosition
cv2: Used for image processing and display with OpenCV.
time: Controls execution delays and time management.
queue: Manages image queues between threads.
rclpy: Facilitates ROS2 node creation and communication.
threading: Implements multi-threading for parallel task processing.
config: Configuration files.
numpy (np): Handles matrix and vector computations.
std_srvs.srv: ROS service types used for defining standard services.
std_msgs.msg: ROS message types.
sensor_msgs.msg.Image: Receives image messages from the camera.
servo_controller_msgs.msg.ServosPosition: Custom message type for controlling servos.
servo_controller.bus_servo_control.set_servo_position: Servo control function used to set servo angles.
rclpy.callback_groups.ReentrantCallbackGroup: Supports concurrent callback processing.
rclpy.executors.MultiThreadedExecutor: ROS2 multi-threaded executor used for handling multi-threaded tasks.
rclpy.node: Node class in ROS2.
speech: Modules related to large model voice interaction.
large_models_msgs.srv: Custom service type for large models.
large_models.config: Configuration file for large models.
② VLLMWithCamera Class
display_size = [int(640*6/4), int(480*6/4)]
class VLLMWithCamera(Node):
        self.vllm_result = ''
        self.set_above = False
        self.create_subscription(Image, 'depth_cam/rgb/image_raw', self.image_callback, 1)
        self.create_subscription(Bool, 'tts_node/play_finish', self.play_audio_callback, 1, callback_group=timer_cb_group)
display_size: Defines the size of the display window.
rclpy.init(): Initializes the ROS2 node.
super().init(name): Calls the parent class constructor to initialize the node name.
self.image_queue: Creates a queue to store image data with a maximum capacity of 2.
self.vllm_result: Stores the result received from the agent_process/result topic.
self.running: A flag variable used to control the program’s running state.
timer_cb_group: Creates a reentrant callback group to manage timer callbacks.
self.joints_pub: Creates a publisher to publish the robotic arm joint position information.
self.tts_text_pub: Creates a publisher to send text to the speech synthesis node.
self.create_subscription: Creates subscribers to receive image data, VLLM results, and speech playback completion signals.
self.awake_client and self.set_model_client: Create clients to call the wake-up and model setting services.
self.timer: Creates a timer to trigger the init_process function.
③ get_node_state Method
return response: Returns the response object.
④ init_process Method
59
        msg.model_type = 'vllm'
            msg.api_key = stepfun_api_key
            msg.model = vllm_model
            msg.api_key = vllm_api_key
            msg.base_url = vllm_base_url
        msg = SetString.Request()
        msg.data = PROMPT
        # set_servo_position(self.joints_pub, 1.0, ((1, 500), (2, 700), (3, 135), (4, 150), (5, 500), (10, 220)))  # Set the initial position of the robotic arm. 设置机械臂初始位置
        # set_servo_position(self.joints_pub, 1.0, ((1, 500), (2, 680), (3, 115), (4, 125), (5, 500), (10, 220)))  # Set the initial position of the robotic arm. 设置机械臂初始位置
        #500, 758, 3, 233, 504
        set_servo_position(self.joints_pub, 1.0, ((1, 500), (2, 758), (3, 3), (4, 233), (5, 500), (10, 300)))
self.timer.cancel(): Stops the timer.
SetModel.Request: Creates a request message to set the model.
self.send_request: Sends the request to the server.
set_servo_position: Sets the initial position of the robotic arm joints.
speech.play_audio: Plays audio.
threading.Thread: Creates a thread to run the process function.
self.create_service: Creates a service to notify that initialization is complete.
self.get_logger().info: Logs the information.
⑤ Send_request Method
client.call_async(msg): Asynchronously calls the service.
future.done() and future.result(): Checks if the service call is complete and returns the result.
⑥ Vllm_result_callback Method
    def vllm_result_callback(self, msg):
        self.vllm_result = msg.data
Receives results from the agent_process/result topic and stores them in self.vllm_result.
⑦ process Method
    def process(self):
        box = []
            if self.vllm_result:
                msg = String()
                msg.data = self.vllm_result
                # if self.vllm_result.startswith("```") and self.vllm_result.endswith("```"):
                    # self.vllm_result = self.vllm_result.strip("```").replace("json\n", "").strip()
                # self.vllm_result = json.loads(self.vllm_result)
                # box = self.vllm_result['xyxy']
                # if box:
                    # self.get_logger().info('box: %s' % str(box))
                    # box = [int(box[0] * 640), int(box[1] * 480), int(box[2] * 640), int(box[3] * 480)]
                    # box[0] = int(box[0] / 640 * display_size[0])
                    # box[1] = int(box[1] / 480 * display_size[1])
                    # box[2] = int(box[2] / 640 * display_size[0])
                    # box[3] = int(box[3] / 480 * display_size[1])
            # if box:
                # cv2.rectangle(image, (box[0], box[1]), (box[2], box[3]), (255, 0, 0), 2, 1)
            cv2.imshow('image', cv2.cvtColor(cv2.resize(image, (display_size[0], display_size[1])), cv2.COLOR_RGB2BGR))
            # cv2.imshow('image', cv2.cvtColor(image, cv2.COLOR_RGB2BGR))
            k = cv2.waitKey(1)
            if k != -1:
            if not self.set_above:
                self.set_above = True
cv2.namedWindow and cv2.moveWindow: Creates and moves the image display window.
self.image_queue.get: Retrieves image data from the queue.
self.vllm_result: If there is a VLLM result, it is published to the speech synthesis node.
cv2.imshow: Displays the image.
cv2.waitKey: Waits for a keyboard event.
cv2.destroyAllWindows: Closes all OpenCV windows.
⑧ Play_audio_finish_callback Method:
    def play_audio_callback(self, msg):
        if msg.data:
            msg.data = True
When the speech playback is complete, sends a request to enable the wake-up function.
⑨ image_callback Method
Converts the received ROS image message to a NumPy array and stores it in the queue.
⑩ Main Function
    node = VLLMWithCamera('vllm_with_camera')
Creates an instance of the VLLMWithCamera node.
Uses a multi-threaded executor to handle node tasks.
Calls executor.spin() to start processing ROS events.
Destroys the node when finished by calling node.destroy_node().
19.3.3 Embodied AI Applications in Vision Tracking
Once the program starts running, the 6-microphone array (collectively referred to as the voice device) will announce “Ready****”.
Afterward, say the designated wake-up phrase “hello hi wonder” to activate the voice device, which will respond with “I am here”. You can then control JetArm with your voice. For example, say “Follow the purple bull.” The terminal will display the recognized voice command, and the voice device will announce the generated response after processing, then execute the corresponding action.
source ~/.zshrc
(1) The input commands must strictly observe case sensitivity and spacing.
(2) The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet.
(3) Double-click to launch the command bar. Enter the command and press Enter to disable the auto-start service.
(4) Execute the following command to disable the app auto-start service.
(5) Enter the following command and press Enter to initiate voice-controlled game:
ros2 launch large_models_examples vllm_track.launch.py
(6) Once the command line outputs the message below and the device announces “I am ready”, it indicates that the voice device has been initialized. You can now say the wake word, “hello hi wonder”.
(8) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (”response”), as well as designed an action that aligns with the user’s command meaning.
(9) When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step 4) to reactivate the voice device using the wake-up word and begin a new round of interaction.
(10) To exit this feature, simply press “Ctrl+C” in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
  • How It Works
Once the feature is activated, we can freely organize our commands, for example: “Follow the purple ball”. This will control the JetArm robotic arm to automatically track the purple ball within its field of view, highlight the ball in the frame, and stop tracking when the ball is positioned at the center of the screen.
(1) Analysis of Launch Files
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_track.launch.py
    vllm_track_node = Node(
        executable='vllm_track',
    # rqt
    calibrate_rqt_reconfigure_node = Node(
        package='rqt_reconfigure',
        executable='rqt_reconfigure',
        name='calibrate_rqt_reconfigure'
    return [mode_arg,
            sdk_launch,
            vllm_track_node,
            # calibrate_rqt_reconfigure_node,
sdk_launch: Use IncludeLaunchDescription to include the jetarm_sdk.launch.py Launch launch file from the large_models package and pass the mode parameter.
vllm_track_node:Defines a ROS2 node from the large_models package that executes the vllm_track executable, and prints its output to the screen.
calibrate_rqt_reconfigure_node: Defines a ROS2 node that originates from the rqt_reconfigure package and executes the rqt_reconfigure executable file.
    ls.run()
/home/ubuntu/ros2_ws/src/jetarm_large_models/large_models/large_models/vllm_track.py
import json
import queue
import PIL.Image
import sdk.fps as fps
from sdk import common
import pycuda.driver as cuda
from std_msgs.msg import String, Float32, Bool
from rcl_interfaces.msg import SetParametersResult
from large_models_examples.tracker import Tracker
from kinematics_msgs.srv import SetRobotPose, SetJointValue
from large_models_examples.track_anything import ObjectTracker
from kinematics.kinematics_control import set_pose_target, set_joint_value_target
json: Used for handling JSON-formatted data.
PIL.Image: A part of the Pillow library, used for processing image files.
.sdk.fps as fps: Used to calculate and display the frame rate (FPS).
import sdk.common as common: Imports some common utility functions or constants.
from kinematics_msgs.srv import SetRobotPose: Imports the service type used to set the robot’s pose.
from kinematics.kinematics_control import set_pose_target: Imports the function used to set the pose target.
rcl_interfaces.msg.SetParametersResult: Used to handle the result of setting ROS parameters.
large_models.track_anything: A class used for object tracking.
② PROMPT Character String
A prompt string (PROMPT) is defined to guide the processing of user commands and image data, specifying the rules and output format for the recognition task.
③ VLLMTrack Class
class VLLMTrack(Node):
        self.box = []
        self.fps = fps.FPS() # frame rate counter 帧率统计器
        # self.vllm_result = '''json{"object":"红色方块", "xyxy":[521, 508, 637, 683]}'''
        self.data = []
        self.start_track = False
        self.language = os.environ["ASR_LANGUAGE"]
        self.track = ObjectTracker(use_mouse=True, automatic=True, log=self.get_logger())
        self.ik_client = self.create_client(SetRobotPose, 'kinematics/set_pose_target')
        self.ik_client.wait_for_service()
        self.fk_client = self.create_client(SetJointValue, 'kinematics/set_joint_value_target')
        self.fk_client.wait_for_service()
        # Define PID parameters. 定义 PID 参数
        # 0.07, 0, 0.001
        self.pid_params = {
            'kp1': 0.065, 'ki1': 0.0, 'kd1': 0.001,
            'kp2': 0.00004, 'ki2': 0.0, 'kd2': 0.0,
            'kp3': 0.05, 'ki3': 0.0, 'kd3': 0.0
        # Dynamically declare parameters. 动态声明参数
        for param_name, default_value in self.pid_params.items():
            self.declare_parameter(param_name, default_value)
            self.pid_params[param_name] = self.get_parameter(param_name).value
                      [self.pid_params['kp2'], self.pid_params['ki2'], self.pid_params['kd2']],
                      [self.pid_params['kp3'], self.pid_params['ki3'], self.pid_params['kd3']])
        # Callback function for dynamic updates. 动态更新时的回调函数
        self.add_on_set_parameters_callback(self.on_parameter_update)
rclpy.init(): Initializes the ROS2 system.
super().__init__(name) calls the initialization method of the parent class (Node), creating a ROS 2 node.
fps.FPS() creates an instance of the frame rate statistic tracker.
queue.Queue(maxsize=2) creates a queue with a maximum capacity of 2.
self.vllm_result is used to store the processed results.
self.running: A boolean variable used to control the program’s running state.
self.data: An empty list used to store data.
self.start_track: A boolean variable used to control the start or stop of object tracking.
self.track = ObjectTracker(): Instantiates an object tracker.
timer_cb_group: Creates a reentrant callback group.
speech.OpenAIAPI(): Instantiates a speech interaction client.
self.joints_pub: Creates a publisher for publishing the servo motor position information.
self.tts_text_pub: Creates a publisher for publishing text to the text-to-speech synthesis node.
self.create_subscription: Subscribes to image data, speech playback completion signals, and image recognition results.
self.create_client: Creates clients for invoking various services, such as wake-up service, model settings, motion control, etc.
Iterates over self.pid_params, declaring each PID parameter as a ROS 2 dynamic parameter and setting default values.
Uses self.get_parameter to fetch the current parameter values and updates self.pid_params.
self.track.update_pid(): Passes the updated PID parameters to the object tracker (self.track) to adjust the tracker’s PID controller.
self.pid_params: PID controller parameters used in the control logic of the object tracker.
self.add_on_set_parameters_callback: Adds a callback function for parameter updates.
④ On_parameter_update Method
    def on_parameter_update(self, params):
        """Parameter update callback 参数更新回调"""
        for param in params:
            if param.name in self.pid_params.keys():
                self.pid_params[param.name] = param.value
        # self.get_logger().info(f'PID parameters updated: {self.pid_params}')
        # Update PID parameters. 更新 PID 参数
        return SetParametersResult(successful=True)
self.pid_params: A dictionary used to store PID parameters.
self.track.update_pid: Updates the PID parameters for the target tracking module.
⑤ create_update_callback Method
    def create_update_callback(self, param_name):
        """Generate dynamic update callback 生成动态更新回调"""
        def update_param(msg):
            new_value = msg.data
            self.pid_params[param_name] = new_value
            self.set_parameters([Parameter(param_name, Parameter.Type.DOUBLE, new_value)])
            self.get_logger().info(f'Updated {param_name}: {new_value}')
Generates a dynamic update callback function for each PID parameter.
⑥ get_node_state Method
⑦ init_process Method
        msg.data = PROMPT
        z = 0.15
        msg = set_pose_target([0.137, 0.0, z], 30, [-90.0, 90.0], 1.0)
        res = self.send_request(self.ik_client, msg)
        if res.pulse:
            # self.get_logger().info(str(servo_data))
            set_servo_position(self.joints_pub, 1.5, ((10, 300), (5, 500), (4, servo_data[3]), (3, servo_data[2]), (2, servo_data[1]), (1, servo_data[0])))
            time.sleep(1.8)
            self.track.set_init_param(servo_data[3], servo_data[0], z)
        threading.Thread(target=self.track_thread, daemon=True).start()
        self.get_logger().info('\033[1;32m%s\033[0m' % PROMPT)
self.timer.cancel():Cancel timer
set_pose_target: Sets the robot’s initial pose.
self.send_request: Sends a service request.
set_servo_position: Sets the joint positions.
speech.play_audio: Plays an audio clip.
threading.Thread: Starts a new thread for image processing and tracking.
self.create_service: Creates a service for signaling that initialization is complete.
Self.get_logger().info: Prints log information.
⑧ Send_request Method
Client.call_async(msg): Asynchronously calls a service.
future.done() and future.result(): Check if the service call has completed and retrieve the result.
⑨ vllm_result_callback method:
⑩ play_audio_finish_callback method
Sends a wake-up signal once audio playback is completed.
⑪ Process Method
    def process(self):
        box = ''
                    if box:
                            box = self.client.data_process(box, 640, 480)
                        self.box = box
                    speech.play_audio(start_track_audio_path, block=False)
                except (ValueError, TypeError):
                    self.box = []
                    msg = String()
                time.sleep(0.02)
            if self.action_finish:
                msg.data = True
cv2.namedWindow and cv2.moveWindow: Create and position an OpenCV image display window.
Self.vllm_result: Stores results received from a subscriber (likely detection or recognition results).
Json.loads: Parses the image recognition results from JSON format.
Self.client.data_process: Processes the parsed recognition results.
Self.track.set_track_target: Sets the tracking target.
Self.track.track: Performs the target tracking.
speech.play_audio(start_track_audio_path, block=False): Plays an audio file to indicate that target tracking has started.
self.send_request(self.awake_client, msg): Sends a service request via awake_client to enable voice wake-up functionality.
Cv2.imshow: Displays the image.
cv2.waitKey: Waits for a key event.
⑫ track_thread
282
284
285
286
287
288
289
290
291
292
294
295
296
297
298
299
300
301
302
303
305
306
307
308
309
310
311
312
313
314
315
    def track_thread(self):
        # Create a new CUDA context in the current thread. 在当前线程创建一个新的 CUDA 上下文
        dev = cuda.Device(0)
        ctx = dev.make_context()
            model_path = os.path.split(os.path.realpath(__file__))[0]
            back_exam_engine_path = os.path.join(model_path, "resources/models/nanotrack_backbone_exam.engine")
            back_temp_engine_path = os.path.join(model_path, "resources/models/nanotrack_backbone_temp.engine")
            head_engine_path = os.path.join(model_path, "resources/models/nanotrack_head.engine")
            tracker = Tracker(back_exam_engine_path, back_temp_engine_path, head_engine_path)
                image = cv2.resize(image, tuple(display_size))
                if self.box:
                    self.track.set_track_target(tracker, self.box, image)
                    self.start_track = True
                    self.box = []
                if self.start_track:
                    self.data = self.track.track(tracker, image)
                    image = self.data[-1]
                    y, z, joint4 = self.data[0], self.data[1], self.data[2]
                    if z > 0.23 or joint4 >= 391:
                        msg = set_pose_target([0.18, 0.0, z], 0.0, [-180.0, 180.0], 1.0)
                        if res.pulse:
                            set_servo_position(self.joints_pub, 0.0, (
                            (10, 500), (5, 500), (4, servo_data[3]), (3, servo_data[2]), (2, servo_data[1]),
                            (1, int(y))))
                            set_servo_position(self.joints_pub, 0.02, ((1, int(y)),))
                        set_servo_position(self.joints_pub, 0.0, ((1, y), (4, joint4)))
                self.data = []
                self.fps.show_fps(image)
                cv2.imshow('image', image)
                if key == ord('q') or key == 27:  # Press 'q' or 'Esc' to exit. 按q或者esc退出
Self.running: A boolean variable controlling the running state of the thread.
if self.data: Checks if there is new tracking data available.
if z > 0.23 or joint4 >= 391: Determines whether the robot’s pose needs adjustment based on conditions.
Set_pose_target: Sets the target pose.
Self.send_request: Sends a service request.
if res.pulse: If res.pulse exists, it assigns it to servo_data by extracting pulse data from the response. Set_servo_position: Calls a function to set the servo motor positions.
⑬ image_callback method
Converts received ROS image messages into NumPy arrays and stores them in the queue.
⑭ Main Method
332
333
334
335
336
337
    node = VLLMTrack('vllm_track')
Creates an instance of the VLLMTrack node.
Uses a multithreaded executor to handle node tasks.
19.3.4 Embodied AI Applications in Intelligent Transport
The large model used in this lesson is an online model, requiring the main control device to maintain a stable network connection (it is recommended to use a wired network connection).
  • Brief Game Instructions
Afterward, say the designated wake-up phrase “hello hi wonder” to activate the voice device, which will respond with “I am here”. Once activated, you can control the JetArm using voice commands. For example, you can simply say, “Please put the blue square on the right side of the red square” to issue a command. Once the command is given, the terminal will display the recognized voice content, and the “voice device” will announce the response generated from the analysis.
(1) Version Confirmation
Before running the functionality, it is essential to confirm that your microphone version configuration is correct within the system.
① After remotely logging into the machine using NoMachine, click on the desktop icon .
source ~/.zshrc
(2) Large Model API-KEY Configuration
Open a new terminal and enter the following command to open the configuration file:
vim /home/ubuntu/ros2_ws/src/large_models/large_models/large_models/config.py
Refer to the “19.1.1 Large Language Model Courses-> Large Language Model Deployment” to obtain the API-KEY for the large model. After acquiring the visual large model API-KEY (from the Openrouter website), fill it into the vllm_api_key parameter. Similarly, obtain the API-KEY for the large language model (from the OpenAI website) and fill it into the llm_api_key parameter, as indicated by the red box in the image below.
  • The input commands must strictly observe case sensitivity and spacing.
  • The robot must be connected to the internet, either in STA (local network) mode or AP (direct connection) mode via Ethernet.
(3) Enter the following command and press Enter to initiate voice-controlled game:
ros2 launch large_models_examples vllm_object_transport.launch.py
(4) When the command line shows the output as shown in the image and announces “I am ready”, it means that the “voice device” has completed initialization, and the YOLOv8 model will also be initialized. At this point, you can say the wake-up phrase, “hello hi wonder”.
You can then say the command, “place the red block to the right of the green ball.”, and wait for the large model to process the recognition.
Similarly, you can refer to the textual input prompts provided in the program and issue voice commands to the robotic arm.
The response is automatically generated by the large model, ensuring the accuracy of the meaning, though the wording and structure of the reply may vary.
  • How It Works
Once the mode is activated, we can freely structure our commands, such as: “Please put the blue square on the right side of the red square”. The JetArm robotic arm will automatically detect the color blocks within its field of view, highlight them on the screen, and place them in the specified position according to our instructions.
  • Brief Program Analysis
(1) Analysis of launch File
The program is saved at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_object_transport.launch.py
① Library Files Import
os: Used for handling file paths and operating system-related functionalities.
ament_index_python.packages.get_package_share_directory: Used to obtain the shared directory path of a ROS2 package.
launch_ros.actions.Node: Used to define a ROS2 node
launch.substitutions.LaunchConfiguration: Used to retrieve parameter configurations from a Launch file.
LaunchDescription, LaunchService: Used to define and launch a Launch file.
launch_description_sources PythonLaunchDescriptionSource: Used to include other Launch files.
launch.actions.IncludeLaunchDescription, DeclareLaunchArgument, OpaqueFunction: Used to define actions and parameters within a Launch file.
② Define launch_setup Function
    mode = LaunchConfiguration('mode', default=1)
    mode_arg = DeclareLaunchArgument('mode', default_value=mode)
    large_models_package_path = get_package_share_directory('large_models')
            os.path.join(sdk_package_path, 'launch/jetarm_sdk.launch.py')),
    object_transport_node = Node(
        package='large_models_examples',
        executable='object_transport',
    vllm_object_transport_node = Node(
        executable='vllm_object_transport',
    return [mode_arg,
            sdk_launch,
            large_models_launch,
            object_transport_node,
            vllm_object_transport_node,
This function is used to configure and initiate actions in the Launch file.
mode = LaunchConfiguration('mode', default=1): Defines a Launch parameter named mode, with a default value of 1.
mode_arg = DeclareLaunchArgument('mode', default_value=mode): Declares the mode parameter and adds it to the Launch description.
peripherals_package_pathsdk_package_pathlarge_models_package_path: These are used to retrieve the shared directory paths for the peripherals, sdk and large_models packages, respectively.
depth_camera_launchsdk_launch: Uses IncludeLaunchDescription to include the depth_camera.launch.py and jetarm_sdk.launch.py file from the sdk package.
large_models_launch: Uses IncludeLaunchDescription to include the start.launch.py Launch file from the large_models package, passing the mode parameter.
object_transport_node: Defines a ROS2 node from the large_models package that executes the object_transport executable, and prints its output to the screen.
vllm_object_transport_node: Defines a ROS2 node from the large_models package that executes the vllm_object_transport executable, and prints its output to the screen.
Finally, the function returns a list containing all the Launch actions.
③ Define generate_launch_description function:
    return LaunchDescription([
This function is used to generate a Launch description.
Use OpaqueFunction to add the launch_setup function to the Launch description.
④ Main program entry:
59
    # Create a LaunchDescription object. 创建一个LaunchDescription对象
    ls = LaunchService()
    ls.run()
ld = generate_launch_description(): Generates a Launch description object.
ls = LaunchService(): Creates a Launch service object.
ls.include_launch_description(ld): Adds the Launch description to the Launch service.
ls.run(): Starts the Launch service, executing all the defined Launch actions.
(2) Analysis of Python Files
The program is saved at:/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_object_transport.py
import json
import queue
from speech import speech
from large_models_msgs.srv import SetString, SetModel, SetBox, SetContent
math: Provide support for mathematical calculations.**
Three prompt strings (PROMPT) are defined to guide how user commands and image data are processed, specifying the rules for recognition tasks and the output format.
③ VLLMObjectTransport Class
	class VLLMObjectTransport(Node):
        self.llm_result = ''
        # self.vllm_result = '''json{"object":"香蕉","xyxy":[243, 441, 842, 552], "response": "香蕉"}'''
        self.transport_finished = True
        self.lock = threading.RLock()
        self.asr_pub = self.create_publisher(String, '/vocal_detect/asr_result', 1)
        self.create_subscription(Bool, 'object_transport/transport_finished', self.transport_finished_callback, 1)
        self.record_chat_client = self.create_client(SetBool, 'agent_process/record_chat')
        self.record_chat_client.wait_for_service()
        self.get_chat_client = self.create_client(Trigger, 'agent_process/get_chat')
        self.get_chat_client.wait_for_service()
        self.clear_chat_client = self.create_client(Empty, 'agent_process/clear_chat')
        self.clear_chat_client.wait_for_service()
        self.enter_client = self.create_client(Trigger, 'object_transport/enter')
        self.start_client = self.create_client(SetBool, 'object_transport/enable_transport')
        self.set_pick_client = self.create_client(SetBox, 'object_transport/set_pick_position')
        self.set_pick_client.wait_for_service()
        self.set_place_client = self.create_client(SetBox, 'object_transport/set_place_position')
        self.set_place_client.wait_for_service()
        self.record_position_client = self.create_client(SetBox, 'object_transport/record_position')
        self.record_position_client.wait_for_service()
self.llm_result: Stores the results returned by the LLM (Large Language Model).
self.running: control the running status of the program
self.transport_finished: Marks whether the transportation task has been completed.
self.lock: A thread lock used for thread synchronization in multithreading.
self.client: The voice API client, used for interacting with voice services.
self.tts_text_pub: ROS topic publisher for sending Text-to-Speech (TTS) text.
self.tts_text_pub: ROS topic publisher for sending Automatic Speech Recognition (ASR) results.
self.create_subscription: Subscribes to LLM results and transportation completion status.
self.create_client: Creates multiple service clients for calling different functionalities.
④ get_node_state Method
⑤ init_process Method
282
284
285
286
        msg = SetModel.Request()
        msg.model_type = 'llm'
        msg.model = llm_model
        msg.api_key = api_key
        msg.base_url = base_url
        msg.data = LLM_PROMPT
        msg = Empty.Request()
        self.send_request(self.clear_chat_client, msg)
        init_finish = self.create_client(Empty, 'object_transport/init_finish')
        self.get_logger().info('\033[1;32m%s\033[0m' % LLM_PROMPT)
SetModel.Request: Creates a request message to set the LLM model.
SetModel.Request(): Creates a service request for the SetModel service.
msg.model_type = 'llm': Specifies the model type as llm.
self.send_request(self.set_model_client, msg): Sends a request through the set_model_client to set the model.
SetString.Request: Defines the request message for setting the prompt string.
self.send_request(self.set_prompt_client, msg): Sends a request through the set_prompt_client to set the prompt information.
Empty.Request: Defines the request message to clear the chat history.
self.send_request(self.clear_chat_client, msg): Sends a request through the clear_chat_client to clear the chat history.
self.create_client(Empty, 'object_transport/init_finish'): Creates a client for calling the object_transport/init_finish service.
init_finish.wait_for_service(): Waits until the service is available.
self.send_request(self.enter_client, Trigger.Request()): Sends a Trigger request through the enter_client.
threading.Thread: Starts the main logic thread.
Self.get_logger().info: Logs the information.
⑥ Send_request Method
288
289
290
291
292
⑦ vllm_result_callback method:
294
295
	    def llm_result_callback(self, msg):
        self.llm_result = msg.data
⑧ remember_position Method
297
298
299
300
301
302
303
305
306
307
308
309
310
311
312
313
314
315
316
317
318
319
320
321
322
323
324
325
326
327
328
329
330
331
	    def remember_position(self):
        msg = SetContent.Request()
        msg.prompt = VLLM_PROMPT2
        vllm_result = self.send_request(self.set_vllm_content_client, msg)
        self.get_logger().info(f'vllm_result: {vllm_result}')
        message = vllm_result.message
        if message.startswith("```") and message.endswith("```"):
            message = message.strip("```").replace("json\n", "").strip()
        initial_position = json.loads(message)
        # self.get_logger().info(f'initial_position: {initial_position}')
        for i in initial_position:
            msg = SetBox.Request()
            msg.label = i
            xyxy = initial_position[i]
                msg.box = self.client.data_process(xyxy, 640, 480)
                msg.box = [int(xyxy[0] * 640), int(xyxy[1] * 480), int(xyxy[2] * 640), int(xyxy[3] * 480)]
            self.send_request(self.record_position_client, msg)
        msg.data = True
        self.send_request(self.start_client, msg)
        msg.data = True
        self.send_request(self.record_chat_client, msg)
SetContent.Request: This is a service request message used to set the content of the LLM (Large Language Model).
msg.prompt = VLLM_PROMPT2: This sets the prompt for the LLM, specifically to VLLM_PROMPT2
self.get_logger().info(f'vllm_result: {vllm_result}'):print Log information
vllm_result.message: Extract the message content from the response.
if message.startswith("") and message.endswith(""): Check whether the message is returned in a code block format (enclosed by triple backticks).
message.strip("```").replace("jsonn", "").strip(): Remove the code block markers and extra text to extract the pure JSON content.
json.loads(message): Parse the extracted JSON string into a Python dictionary.
for i in initial_position: Iterate through each entry in initial_position.
self.client.data_process: Process the coordinates returned by the LLM.
self.client.data_process:Processes the parsed recognition results.
SetBox.Request: Request message for recording the object’s position.
self.record_position_client: Service client for recording positions.
⑨ recovery Method
333
334
335
336
337
338
339
340
341
342
343
344
345
346
347
348
349
350
	    def recovery(self, text):
        if not text:
            msg = Trigger.Request()
            res = self.send_request(self.get_chat_client, msg)
            # self.get_logger().info(str(res.message))
            text = res.message.rsplit(",", 1)[0] if "," in res.message else res.message
            msg.data = False
        msg = String()
            msg.data = '{}, 只需要放回去的步骤'.format(text)
            msg.data = '{}, only the steps for putting it back'.format(text)
        self.get_logger().info('\033[1;32m%s\033[0m' % msg.data)
        self.asr_pub.publish(msg)
Trigger.Request: Request message for retrieving the conversation records.
res = self.send_request(self.get_chat_client, msg): Send a request through the self.get_chat_client client and receive the response (res).
text = res.message.rsplit(",", 1)[0] if "," in res.message else res.message: Extract and process res.message from the response. The processed string is assigned to text.
SetBool.Request: Request message for stopping the recording of the conversation.
self.send_request(self.record_chat_client, msg): Send a request through the self.record_chat_client client.
self.send_request(self.clear_chat_client, msg): Send a request through the self.clear_chat_client client.
self.asr_pub: ROS publisher used to broadcast voice command instructions.
⑩ Object_restore Method
352
353
354
355
356
357
358
359
360
361
362
363
364
365
366
367
368
369
370
371
372
373
374
375
376
377
378
379
380
381
382
383
384
385
386
387
388
389
390
391
392
393
394
395
	    def object_restore(self, query):
        msg.prompt = VLLM_PROMPT1
        msg.query = query
        msg.label = position['pick']['object']
        xyxy = position['pick']['xyxy']
        self.send_request(self.set_pick_client, msg)
        self.send_request(self.set_place_client, msg)
        # self.get_logger().info(f'msg: {msg}')
        msg.data = True
        self.transport_finished = False
        msg = String()
        msg.data = position['response']
msg.prompt = VLLM_PROMPT1: Set the first prompt message.
self.send_request(self.set_vllm_content_client, msg): Send a request through the set_vllm_content_client client and receive the response (vllm_result).
message.strip("```").replace("json\n", "").strip(): Remove the code block markers and extra text to extract the pure JSON content.
position['pick']['object']: Extract the name of the target object from the parsed position data.
position['pick']['xyxy']: Extract the bounding box information of the target object.
self.client.data_process(position['pick']['xyxy'], 640, 480): Call the data_process method to process the bounding box.
SetBox.Request: Request message for setting the pick-and-place positions.
self.send_request(self.start_client, msg): Send a request through the start_client client to initiate the sorting task.
self.tts_text_pub.publish(msg): Publish a message.
⑪ get_object_position Method
397
398
399
400
401
402
403
404
405
406
407
408
409
410
411
412
413
414
415
416
417
418
419
420
421
422
423
424
425
426
427
428
429
430
431
432
433
434
435
436
437
438
439
440
441
442
443
444
445
446
447
448
449
	    def get_object_position(self, query, offset=None):
        msg.query = query
        # self.get_logger().info(f'position: {position}')
        # msg.label = label
        # self.get_logger().info(f'pick xyxy: {xyxy}')
        if xyxy:
            # msg.box = position['pick']['xyxy']
        xyxy = position['place']['xyxy']
        # self.get_logger().info(f'place xyxy: {xyxy}')
        if xyxy:
            # msg.label = label
            # msg.box = position['place']['xyxy']
            msg.offset = offset
        msg.data = True
        msg = String()
query: Query request.
offset: Offset for the placement position.
position['place']['xyxy']: Extract the bounding box information for the placement position of the target object from the parsed position data.
⑫ transport_finished_callback method
451
452
	    def transport_finished_callback(self, msg):
        self.transport_finished = msg.data
Receive updates regarding the transportation completion status.
⑬ process Method
454
455
456
457
458
459
460
461
462
463
464
465
466
467
468
469
470
471
472
473
474
475
476
477
478
479
480
481
482
483
484
485
486
487
488
489
490
491
492
493
494
495
496
497
498
499
500
	    def process(self):
        action_list = []
        action_finish = False
            if self.llm_result:
                    self.get_logger().info(f'llm_result: {self.llm_result}')
                    if 'action' in self.llm_result: # 如果有对应的行为返回那么就提取处理
                        if self.llm_result.startswith("```") and self.llm_result.endswith("```"):
                            self.llm_result = self.llm_result.strip("```").replace("json\n", "").strip()
                        action_list = json.loads(self.llm_result)['action']
                        action_finish = True
                except BaseException as e:
                    print(e)
                if action_list:
                    # self.get_logger().info(f'{self.transport_finished}')
                    if self.transport_finished:
                        action = action_list[0]
                        if 'remember' in action:
                            self.remember_position()
                        elif 'recovery' in action:
                            self.recovery(action[0])
                        elif 'pick' in action:
                            self.get_object_position(action[0])
                        elif 'place' in action:
                            self.get_object_position(action[0], action[-1])
                        elif 'pick_and_place' in action:
                        elif 'restore' in action:
                            self.object_restore(action[0])
                        del action_list[0]
                        if not action_list:
                    time.sleep(0.02)
            if action_finish:
                msg.data = True
while self.running: A loop that continuously runs as long as self.running evaluates to True.
if self.vllm_result: Check if self.vllm_result has a value. self.vllm_result is the result returned from the VLLM model.
if self.vllm_result.startswith("") and self.vllm_result.endswith(""): Check if self.vllm_result starts and ends with triple backticks (``````).
self.vllm_result = json.loads(self.vllm_result): Parse self.vllm_result from a JSON string into a Python dictionary.
box = self.vllm_result['xyxy']: Extract the value of the xyxy field from the parsed dictionary.
box = self.client.data_process(box, 640, 480): Call the self.client.data_process method to process the box. 640 and 480 are likely the image’s width and height, used to normalize or transform the bounding box.
label = self.vllm_result['object']: Extract the value of the object field from the dictionary, representing the label of the detected object (e.g., “cat”, “dog”, etc.).
response = self.vllm_result['response']: Extract the value of the response field from the dictionary, which might be the model’s generated text response.
self.get_logger().info(f'label: {label} box: {box}'): Use the ROS 2 logging system to print log information, displaying the detected label and bounding box.
self.send_request(self.set_target_client, msg): Sends a service request to the set_target_client using the send_request method. self.set_target_client: A ROS 2 service client used to set the target object.
self.send_request(self.start_client, msg): Send a service request to self.start_client, possibly to initiate a task (such as a sorting task).
⑭ Main Method
502
503
504
505
506
507
    node = VLLMObjectTransport('vllm_object_transport')
Create an instance of the VLLMObjectTransport ROS 2 node.
19.3.5 Embodied AI Applications in Smart Home Assistant
Afterward, say the designated wake-up phrase “hello hi wonder” to activate the voice device, which will respond with “I am here”. Once activated, you can control the JetArm using voice commands. For example, you can simply say, “Please bring me the ketchup” to issue a command. Once the command is given, the terminal will display the recognized voice content, and the “voice device” will announce the response generated from the analysis.
① Then click “Apply & Save”.
② Restart the command terminal or enter the following command in the existing terminal to refresh the environment variables:
source ~/.zshrc
  • Starting and Stopping the Game
(1) Double-click to launch the command bar. Enter the command and press Enter to disable the auto-start service.
(2) Execute the following command to disable the app auto-start service.
ros2 launch large_models_examples vllm_dietitianl.launch.py
(4) When the command line shows the output as shown in the image and announces “I am ready,” it means that the “voice device” has completed initialization, and the YOLOv8 model will also be initialized. At this point, you can say the wake-up phrase, “hello hi wonder”.
(5) When the command line shows the output below and the device announces “I am here”, it means the voice device has been successfully activated. At this point, the system will begin recording the user’s command.
(6) When the command line shows the output below, it indicates that the cloud-based voice large model’s speech recognition service has successfully processed the user’s command audio. The recognition result will be displayed under “publish_asr_result”.
(7) When the command line shows the output below, it indicates that the cloud-based large language model has successfully processed the user’s command, thought through the instruction, and provided a verbal response (“response”), as well as designed an action that aligns with the user’s command meaning.
(8) When the command line shows the output below, it indicates that one round of interaction has been completed. You can refer to Step 4) to reactivate the voice device using the wake-up word and begin a new round of interaction.
(9) To exit this feature, simply press “Ctrl+C” in the terminal. If it doesn’t close on the first attempt, you may need to press it multiple times.
  • How It Works
Once the mode is activated, we can freely issue commands, such as: “Please bring me the ketchup”.
The JetArm robotic arm will automatically recognize objects within its field of view, highlight the ketchup on the screen, and place it at the designated location as instructed.
The program is saved at:/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_dietitianl.launch.py
    intelligent_grasp_node = Node(
        executable='intelligent_grasp',
    vllm_dietitianl_node = Node(
        executable='vllm_dietitianl',
    return [mode_arg,
            sdk_launch,
            intelligent_grasp_node,
intelligent_grasp_node: Defines a ROS2 node from the large_models package that executes the intelligent_grasp executable, and prints its output to the screen.
vllm_dietitianl_node: Defines a ROS2 node from the large_models package that executes the vllm_dietitianl executable, and prints its output to the screen.
59
    ls.run()
The program is saved at: /home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/vllm_dietitianl.py
import json
import queue
from std_srvs.srv import Trigger, SetBool, Empty
from large_models.config import *
cv2: Uses OpenCV for image processing and display.
math: Provides mathematical operations such as trigonometric functions and logarithms.
json:Handles JSON-formatted data, such as parsing configuration files or network-transmitted data.
time: Offers time-related functions for controlling delays, measuring durations, or generating timestamps.
queue: Implements thread-safe queue structures to manage communication between threads (e.g., for passing image data).
rclpy:The Python client library for ROS2, used to build robotic applications.
threading: Supports multithreading, enabling concurrent task execution.
numpy:Handles high-performance numerical computations and multidimensional array operations, commonly used in image processing.
Node: The base class for all nodes in ROS2, used to create publishers, subscribers, and services.
String, Float32, Bool: Standard ROS2 message types used for communication between nodes.
Trigger, SetBool, Empty: Standard ROS2 service types for request-response communication.
MultiThreadedExecutor: A ROS2 executor that supports multithreaded execution, enhancing concurrent processing capabilities.
ReentrantCallbackGroup: A ROS2 callback group that allows concurrent execution of callback functions.
SetString, SetModel, SetBox, SetContent: Custom service types designed for operations related to large models.
**Role:
You are an intelligent housekeeper robot that can detect and grab objects based on user instructions and images. Your goal is to identify and locate a single object and respond in a friendly, human-like manner.
**Task:
1. Instruction Understanding
You will receive a sentence from the user.
→ Extract the object name based on the user's intent.
→ The object name must be in English.
→ You can only handle one object at a time.
→ Do not include any unmentioned objects.
2. Image Analysis
You will receive an image.
→ Find the bounding box (top-left and bottom-right pixel coordinates) for the object mentioned.
→ Coordinates should be normalized to [0, 1].
→ Focus on accurate detection and orientation.
**Output Format (output only this JSON structure — no explanation or extra text):
  "object": "object_name_in_English",
  "xyxy": [xmin, ymin, xmax, ymax],
  "response": "Concise, friendly human-like reply"
**Output Example:
  "object": "apple",
  "xyxy": [0.25, 0.32, 0.48, 0.60],
  "response": "Got it! I found the apple."
class VLLMDietitianl(Node):
        self.action_finish = False
        self.enter_client = self.create_client(Trigger, 'intelligent_grasp/enter')
        self.enter_client.wait_for_service()
        self.start_client = self.create_client(SetBool, 'intelligent_grasp/enable_transport')
        self.set_target_client = self.create_client(SetBox, 'intelligent_grasp/set_target')
super().init(name): Call the initializer of the parent class (Node) to create a ROS 2 node.
⑤ process Method
    def process(self):
                    msg.label = label
                    msg.box = box
                    # Enable sorting. 开启分拣
                    msg = SetBool.Request()
                    msg.data = True
                    msg = String()
                    msg.data = response
                    msg = String()
                    self.get_logger().info(f'error: {e}')
                self.action_finish = True
            if self.play_audio_finish and self.action_finish:
                msg.data = True
if self.vllm_result.startswith("") and self.vllm_result.endswith(""): Check if the returned result is enclosed within a Markdown code block (using triple backticks ```).
self.vllm_result = self.vllm_result.strip("").replace("json\n", "").strip():Remove the leading and trailing and any “json\n” markers to clean the string.
self.vllm_result = json.loads(self.vllm_result**):** Parse the cleaned string into a JSON-formatted Python dictionary.
box = self.vllm_result['xyxy']: Extract the coordinates of the detected bounding box in xyxy format.
box = self.client.data_process(box, 640, 480): Process the bounding box coordinates according to the image size (640x480).
label = self.vllm_result['object']: Extract the detected object’s class label.
response = self.vllm_result['response']: Extract the natural language response generated by the language model.
msg = SetBox.Request(): Create a SetBox service request to send the bounding box and label information.
msg.label = label; msg.box = box: Set the label and bounding box coordinates in the request message.
self.send_request(self.set_target_client, msg): Send the target setting information via the set_target_client service client.
msg = SetBool.Request(); msg.data = True: Create a Boolean request indicating to start the sorting process.
self.send_request(self.start_client, msg): Send the “start sorting” request via the start_client service client.
msg = String(); msg.data = response: Create a string message and set the language model’s response text.
self.tts_text_pub.publish(msg):Publish the response text via tts_text_pub for speech synthesis or display.
except BaseException as e:Catch exceptions for error handling.
msg.data = self.vllm_result:In case of an error, publish the original string as the message.
self.action_finish = True; self.vllm_result = '':Mark the action as finished and clear vllm_result.
if self.play_audio_finish and self.action_finish:When both audio playback and action execution are complete, trigger the wake-up procedure.
msg = SetBool.Request(); msg.data = True:Create a Boolean request to wake up the system for the next step.
self.send_request(self.awake_client, msg):Send the wake-up request through the awake_client service client.
⑥ Main Method
    node = VLLMDietitianl('vllm_dietitianl')
19.4 Offline Large Model Applications
  • The features covered in this chapter are only supported on kits purchased on or after January 1, 2026.
19.4.1 Voice Device Setting
Before running any feature, confirm that the microphone version is configured correctly in the system.
  1. After logging in to the robot remotely through NoMachine, click the desktop icon .
  2. Set the system environment based on the hardware configuration. For example, set Robot Type to JetArm Advanced, Camera Type to Gemini, and ASR Language to English.
  3. When using the AI Voice Interaction Box, set Microphone Type to wonderechopro as shown below.
    When using the 6-Microphone Array, set Microphone Type to xf as shown below.
  4. Set ASR Mode to offline.
  5. Then click Apply & Save.
  • Restart Service is used to restart the app service. It is not related to this lesson, so there is no need to cl
19.4.2 Offline Large Model Application: Voice Control
19.4.2.1 Program Introduction
After the program starts, the voice device announces I’m ready.
Say the wake word Hello Hiwonder to activate the voice device. Once activated, the device responds with I’m here. Voice commands can then be used to control JetArm. For example, saying Servo No. 1 move to 90 degrees makes the terminal display the recognized speech. The voice device then announces the generated response after processing and executes the corresponding action.
19.4.2.2 Preparation
Refer to 19.4.1 Voice Device Setting.
19.4.2.3 Operation Steps
  1. Click to open the command line window. Enter the command and press Enter to disable the auto-start service.
  1. Enter the following command to disable the mobile app auto-start service.
  1. Enter the following command and press Enter to run the voice control feature.
ros2 launch large_models_examples llm_control_servo.launch.py
  1. When the command line shows the output below, and the device announces I’m ready, initialization of the voice device is complete. Then, say the wake word Hello Hiwonder to awaken the robot.
  2. When the command line shows the output below, and the voice device announces I’m here, the voice device has been successfully awakened and activated. Voice command recording starts at this point.
  3. Commands can be spoken by following the Input prompt shown in the program’s Task Example section.
  4. When the command line shows the output below, the speech recognition service of the voice model has been called successfully to process the command audio. The parsing result is displayed in publish_asr_result.
  5. When the command line shows the output below, the large language model has been called successfully to interpret the command, generate the text reply in response, and plan an action that matches the command intent.
  • Responses are generated automatically by the large model. Semantic accuracy is ensured, but the wording and sentence structure may vary.
  1. When the command line shows the output below, one round of voice interaction has been completed. Refer to Step 4 to wake the voice device again with the wake word and start a new round of interaction.
  2. To exit this feature, press Ctrl + C in the terminal. If the program does not close successfully, press it multiple times.
19.4.2.4 Program Outcome
After the feature is enabled, the robot accepts conversational voice commands. For example, saying Servo No. 1 move to 90 degrees rotates Servo 1 of JetArm to the 90-degree position.
19.4.2.5 Program Analysis
Launch File Analysis
Program path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_control_servo.launch.py
  • Definition of the launch_setup Function
sdk_launch: Starts the low-level SDK of the robotic arm.
vocal_detect_launch: Starts voice detection.
agent_process_launch: Starts the large model-related functions.
tts_node_launch: Starts speech synthesis. The servo control node is selected based on the ASR mode.
  • Definition of the generate_launch_description Function
    This function generates the Launch description and adds the launch_setup function to it by using OpaqueFunction.
  • Main Program Entry
A LaunchDescription object is created, followed by a LaunchService object. The Launch description is then added to the Launch service. Finally, the Launch service starts and executes all defined Launch actions.
Python File Analysis
Program path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_control_servo_offline.py
  • Definition of the Prompt Template PROMPT
  • Initialization
The ROS node is initialized. A publisher is created for the tts_node/tts_text topic to send text for voice feedback through TTS. Another publisher is created for the servo_controller topic to control servo positions. A timer is initialized to trigger init_process and complete node startup initialization.
  • get_node_state Method
    Service callback used to query node status.
  • init_process Method
    The large model is configured, the prompt template is loaded, and output rules for the large model are constrained. The robotic arm returns to its initial pose, the startup audio is played, and the background action-processing thread is started.
  • send_request Method
    Service call utility that waits synchronously for the service response.
  • llm_result_callback Method
    Receives the LLM processing result and stores the result string in llm_result for later handling.
  • set_position Method
    Converts the set_position instruction generated by the large model into a servo control message. Publishes servo angle commands, updates the locally cached servo pulse values, synchronizes joint angles to the kinematics module, and calculates and updates the spatial position of the robotic arm end effector.
  • move Method
Converts the move instruction generated by the large model into spatial coordinate offsets. Calls the inverse kinematics service to solve the joint angles for the target position. If the inverse solution succeeds, servo control commands are published. If it fails, the position is rolled back to avoid accumulated error.
  • play_audio_finish_callback Method
    Handles the callback after audio playback is completed and re-enables the voice wake-up function.
  • process method
The main loop processes instructions from the LLM, parses commands, and executes the corresponding actions. Both action execution and voice feedback are supported.
19.4.3 Offline Large Model Application: Color Block Sorting
19.4.3.1 Program Introduction
After the program starts, the voice device announces I’m ready. Say the wake word Hello Hiwonder to activate the voice device. It then responds with I’m here. Voice commands can then be used to control JetArm. For example, saying Take away the red block makes the terminal display the recognized speech. The voice device then announces the generated response after processing and executes the corresponding action.
19.4.3.2 Preparation
19.4.3.3 Operation Steps
  2. Enter the following command and press Enter to run the color block sorting feature.
    ros2 launch large_models_examples llm_object_sorting.launch.py
  3. When the command line shows the output below, and the device announces I’m ready, initialization of the voice device is complete. Then, say the wake word Hello Hiwonder to awaken the robot.
  4. When the command line shows the output below, and the voice device announces I’m here, the voice device has been successfully awakened and activated. Voice command recording starts at this point.
  5. Commands can be spoken by following the Input prompt shown in the program’s Task Example section.
  6. For example, place a color block in front of the camera and say Take away the red block.
  7. When the command line shows the output below, the speech recognition service of the voice model has been called successfully to process the command audio. The parsing result is displayed in publish_asr_result.
  8. When the command line shows the output below, the large language model has been called successfully to interpret the command, generate the text reply in response, and plan an action that matches the command intent.
19.4.3.4 Program Outcome
After the feature is enabled, the robot accepts conversational voice commands. For example, saying Take away the red block makes JetArm automatically grasp the red block within the camera view and place it on the left side of the robotic arm.
19.4.3.5 Program Analysis
Program path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_object_sorting.launch.py
object_sorting_launch: Starts object sorting.
agent_process_launch: Starts the large model related functionsmodel-related.
tts_node_launch: Starts speech synthesis. The large model logic node for object sorting has also started.
Program path:
/home/ubuntu/ros2_ws/src/large_models_examples/large_models_examples/llm_object_sorting.py
  • Initialization
Initializes the ROS node and its basic attributes. Creates publishers for speech synthesis text on tts_node/tts_text. Creates subscribers to listen for large model inference results on agent_process/result, TTS playback completion status on tts_node/play_finish, and the voice wake-up signal on vocal_detect/wakeup. Creates service clients for large model configuration, including model and prompt setup, robotic arm sorting control, including entering sorting mode, enabling sorting, and setting the target color, and voice wake-up enable control. Creates a timer to trigger the initialization process through init_process.
    Completes large model parameter configuration, audio playback, and background thread startup.
  • process Method
Used as the main loop to process instructions from the LLM, parse commands, and execute the corresponding actions.
