7. ROS + Machine Learning Course
7.1 Machine Learning Basics
7.1.1 Introduction to Machine Learning
7.1.1.1 Overview
Artificial Intelligence (AI) is a new technological science focused on the theories, methods, technologies, and applications used to simulate, extend, and augment human intelligence.
AI encompasses various fields such as machine learning, computer vision, natural language processing, and deep learning. Among them, machine learning is a subfield of AI, and deep learning is a specific type of machine learning.
Since its inception, AI has seen rapid development in both theory and technology, with expanding application areas, gradually evolving into an independent discipline.
7.1.1.2 What Is Machine Learning
Machine Learning is the core of AI and the fundamental approach to enabling machine intelligence. It is an interdisciplinary field involving probability theory, statistics, approximation theory, convex analysis, algorithmic complexity, and more.
The essence of machine learning lies in enabling computers to simulate or implement human learning behaviors in order to acquire new knowledge or skills, and reorganize existing knowledge structures to continuously improve performance. From a practical perspective, machine learning involves training models using data and making predictions with those models.
Take AlphaGo as an example—it was the first AI program to defeat a professional human Go player and later a world champion. AlphaGo operates based on deep learning, which involves learning the underlying patterns and hierarchical representations from sample data to gain insights.
7.1.1.3 Types of Machine Learning
Machine learning is generally classified into supervised learning and unsupervised learning, with the key distinction being whether the dataset’s categories or patterns are known.
Supervised Learning
Supervised learning provides a dataset along with correct labels or answers. The algorithm learns to map inputs to outputs based on this labeled data. This is the most common type of machine learning.
Labeled Data: Supervised learning uses training data that includes both input features and corresponding labels or outputs. Features describe the attributes of the data, while labels represent the target variable the model is expected to predict or classify. For instance, in image recognition, a large number of images of dogs can be labeled as “dog.” The machine learns to recognize dogs in new images through this data.
Model Selection: Choosing the appropriate model to represent the relationship in the data is crucial. Common models include linear regression, logistic regression, decision trees, support vector machines (SVM), and deep neural networks. The choice depends on the data characteristics and the specific problem.
Feature Engineering: This involves preprocessing and transforming raw data to extract meaningful features. It includes data cleaning, handling missing values, normalization or standardization, feature selection, and feature transformation. Good feature engineering enhances model performance and generalization.
Training and Optimization: Using labeled training data, the model is trained to fit the underlying relationships. This typically involves defining a loss function, selecting an appropriate optimization algorithm, and iteratively adjusting model parameters to minimize the loss. Common optimization methods include gradient descent and stochastic gradient descent.
Model Evaluation: After training, the model is evaluated to assess its performance on new data. Common metrics include accuracy, precision, recall, F1-score, and ROC curves. Evaluating the model ensures it is suitable for real-world applications.
In summary, supervised learning involves using labeled training data to build a model that can classify or predict unseen data. Key steps include model selection, feature engineering, model training and optimization, and performance evaluation. Together, these steps form the foundation of supervised learning.
Unsupervised Learning
Unsupervised learning involves providing the algorithm with data without labels or known answers. All data is treated equally, and the machine is expected to uncover hidden structures or patterns.
For example, in image classification, if you provide a set of images containing cats and dogs without any labels. The algorithm will analyze the data and automatically group the images into two categories—cat images and dog images—based on similarities.
7.1.2 Introduction to Machine Learning Libraries
7.1.2.1 Common Machine Learning Frameworks
There are many machine learning frameworks available. The most commonly used include PyTorch, TensorFlow, PaddlePaddle, and MXNet.
7.1.2.2 PyTorch
Torch is an open-source machine learning framework under the BSD License, widely used for its powerful multi-dimensional array operations. PyTorch is a machine learning library based on Torch but offers greater flexibility, supports dynamic computation graphs, and provides a Python interface.
Unlike TensorFlow’s static computation graphs, PyTorch uses dynamic computation graphs, which can be modified in real-time according to the needs of the computation. PyTorch allows developers to accelerate tensor operations using GPUs, build dynamic graphs, and perform automatic differentiation.
7.1.2.3 Tensorflow
TensorFlow is an open-source machine learning framework designed to simplify the process of building, training, evaluating, and saving neural networks. It enables the implementation of machine learning and deep learning concepts in the simplest way. With its foundation in computational algebra and optimization techniques,
TensorFlow allows for efficient mathematical computations. It can run on a wide range of hardware—from supercomputers to embedded systems—making it highly versatile. TensorFlow supports CPU, GPU, or both simultaneously. Compared to other frameworks, TensorFlow is best suited for industrial deployment, making it highly appropriate for use in production environments.
7.1.2.4 PaddlePaddle
PaddlePaddle, developed by Baidu, is China’s first open-source, industrial-grade deep learning platform. It integrates a deep learning training and inference framework, a library of foundational models, end-to-end development tools, and a rich suite of supporting components. Built on years of Baidu’s R&D and real-world applications in deep learning, PaddlePaddle is powerful and versatile.
In recent years, deep learning has achieved outstanding performance across many fields such as image recognition, speech recognition, natural language processing, robotics, online advertising, medical diagnostics, and finance.
7.1.2.5 MXNet
MXNet is another high-performance deep learning framework that supports multiple programming languages, including Python, C++, Scala, and R. It offers data flow graphs similar to those in Theano and TensorFlow and supports multi-GPU configuration. It also includes high-level components for model building, comparable to those in Lasagne and Blocks, and can run on nearly any hardware platform—including mobile devices.
MXNet is designed to maximize efficiency and flexibility. As an accelerated library, it provides powerful tools for developers to take full advantage of GPUs and cloud computing. MXNet supports distributed deployment via a parameter server and can scale almost linearly across multiple CPUs and GPUs.
7.2 Machine Learning Application
7.2.1 GPU Acceleration
7.2.1.1 Introduction to GPU-Accelerated Computing
GPU stands for Graphics Processing Unit, which is also known as the display core, visual processor, or display chip. A GPU is a microprocessor designed to perform image rendering and image-related computation tasks on devices such as personal computers, workstations, game consoles, tablets, and smartphones.
GPU-accelerated computing refers to the use of both the GPU and CPU together to speed up the execution of scientific, analytical, engineering, consumer, and enterprise applications. This acceleration capability enables faster performance for applications running on various platforms, including cars, smartphones, tablets, drones, and robots.
7.2.1.2 Performance Comparison: GPU vs. CPU
The CPU is designed for general-purpose computing, which handles multitasking and system-level operations, but has limited computational throughput. In contrast, the GPU is designed for high-volume, repetitive calculations and excels at tasks involving massive parallelism, though it is less suited for complex logical operations.
Architecture Differences The CPU follows a serial architecture with a small number of powerful cores, making it ideal for executing single tasks quickly. The GPU adopts a parallel architecture with a large number of simpler cores, making it highly efficient at executing many tasks simultaneously.
In terms of hardware structure, the CPU is equipped with multiple functional modules, allowing it to handle complex computational environments. In contrast, the GPU has a relatively simpler architecture, with the majority of its transistors dedicated to stream processors and memory controllers.
In a CPU, most transistors are used to build control circuits and cache, with only a small portion allocated to actual computation. This design enhances the CPU’s versatility, enabling it to process a wide range of data types and perform complex logical operations, but it also limits its computational performance.
In a GPU, however, most transistors are devoted to specialized circuits and pipelines. This configuration significantly boosts the GPU’s processing speed and greatly enhances its floating-point computational power.
7.2.1.3 Advantages of GPU
GPUs have a large number of cores and are suitable for large-scale parallel data processing, making them particularly advantageous for repetitive tasks in multimedia processing.
Take deep learning as an example—the neural network systems it relies on are designed to analyze massive amounts of data at high speed, and such analysis is exactly what GPUs excel at.
Moreover, the GPU architecture does not include dedicated image processing algorithms; instead, it is optimized based on CPU architecture. Therefore, in addition to image processing, GPUs are also widely used in fields such as scientific computing, cryptographic cracking, numerical analysis, big data processing, and financial analysis, where parallel computing is required.
7.2.2 TensorRT Acceleration
7.2.2.1 Introduction to TensorRT
TensorRT is a high-performance deep learning inference SDK developed by NVIDIA. It includes a deep learning inference optimizer and runtime that enables low-latency and high-throughput deployment of inference applications.
TensorRT now supports deep learning frameworks such as TensorFlow, Caffe, MXNet, and PyTorch. By integrating TensorRT with NVIDIA GPUs, fast and efficient inference deployment can be achieved across most frameworks.
There are many optimization methods for deep learning models, such as weight quantization, weight sparsity, and channel pruning, which are typically performed during the training phase. In contrast, TensorRT optimizes already-trained models by improving the efficiency of the computational graph.
7.2.2.2 Optimization Methods
TensorRT employs the following optimization strategies:
Precision Calibration
Layer & Tensor Fusion
Kernel Auto-Tuning
Dynamic Tenser Memory
Multi-Stream Execution
Precision Calibration for Weights and Activations
Most deep learning frameworks use 32-bit floating-point (FP32) precision for network tensors during training. After training, because inference does not require backpropagation, data precision can be reduced to formats like FP16 or INT8. Lowering data precision reduces memory usage and latency and shrinks the model size.
The following table shows the dynamic ranges for different precisions:
| Precision | Dynamic Range |
| FP32 | −3.4×1038 ~ +3.4×1038 |
| FP16 | −65504 ~- +65504 |
| INT8 | −128 ~ +127 |
INT8 has only 256 distinct values. Using INT8 to represent FP32 values may result in information loss and degraded performance. However, TensorRT provides a fully automated calibration process to optimally convert FP32 data to INT8 with minimal performance loss.
Layer and Tensor Fusion
Although CUDA cores compute tensors quickly, significant time can still be spent on kernel launches and input/output tensor read-write operations per layer, which wastes GPU resources and creates memory bandwidth bottlenecks.
TensorRT optimizes model structure by horizontally or vertically merging layers to reduce the total number of layers and the CUDA cores they occupy.
Horizontal fusion combines convolution, bias, and activation into a CBR structure, which occupies only one CUDA core. Vertical fusion merges layers with the same structure but different weights into a wider layer, also using only one CUDA core.
Additionally, for multi-branch merges, TensorRT can direct outputs to the correct memory address without copying, eliminating the concat layer and reducing memory access operations.
Kernel Auto-Tuning
During inference, the network model performs calculations using CUDA kernels on the GPU. TensorRT automatically tunes CUDA kernels based on different algorithms, network models, and GPU platforms to ensure optimal performance on a given platform.
Dynamic Tensor Memory
TensorRT assigns memory to each tensor only during its usage period to avoid redundant memory allocation. This reduces memory usage and improves memory reuse efficiency.
By utilizing CUDA streams, TensorRT enables parallel computation across multiple branches of the same input, maximizing parallel operation.
7.2.3 YOLO26 Model
7.2.3.1 Overview of the YOLO Models
YOLO Series
YOLO26
YOLO26 is the next-generation real-time object detection model introduced by Ultralytics. Built upon the foundation of previous YOLO versions, it features significant optimizations that deliver substantial improvements in both detection speed and accuracy.
Core Features of YOLO26
1. Simplified Architecture: Removes Distribution Focal Loss (DFL) to streamline bounding box regression and enhance export compatibility.
2. End-to-End Inference: Utilizes an NMS-free (Non-Maximum Suppression) design to directly output detection results, significantly reducing latency and deployment complexity.
3. Training Enhancements: Introduces Progressive Loss Balancing (ProgLoss) and Small Target-Aware Label Assignment (STAL) to improve the stability of small object detection.
4. Optimizer Innovations: Utilizes the MuSGD optimizer, which combines the strengths of SGD and Muon to accelerate model convergence.
5. Multi-Task Support: Features a unified framework that supports object detection, instance segmentation, pose estimation, oriented object detection, and image classification.
6. Edge Optimization: Supports FP16/INT8 quantization, enabling low-latency, real-time inference on edge devices such as the NVIDIA Jetson.
7. Performance: Achieves high precision on benchmarks such as COCO, delivering up to a 43% increase in CPU inference speed compared to previous generations.
7.2.3.2 YOLOv26 Model Structure
Components
Convolutional Layer: Feature Extraction
In YOLOv26, the data to be processed are images, which are two-dimensional in computer vision. Accordingly, the convolution is a two-dimensional convolution. The purpose of 2D convolution is to extract features from images. To perform a 2D convolution, it is necessary to understand the convolution kernel.
The convolution kernel is the unit region over which the convolution calculation is performed each time. The unit is pixels, and the convolution sums the pixel values within the region. Typically, convolution is done by sliding the kernel across the image, and the kernel size is manually set.
When performing convolution, depending on the desired effect, the image borders may be padded with zeros or extended by a certain number of pixels, and then the convolution results are placed back into the corresponding positions in the image. For example, a 6×6 image is first expanded to 7×7, then convolved with the kernel, and finally, the results are filled back into a blank 6×6 image.
Pooling Layer: Feature Amplification
The pooling layer, also called the downsampling layer, is usually used together with convolution layers. After convolution, pooling performs further sampling on the extracted features. Pooling includes various types, such as global pooling, average pooling, max pooling, etc., each producing different effects.
Upsampling Layer: Restoring Image Size
Upsampling can be understood as “reverse pooling.” After pooling, the image size shrinks, and upsampling restores the image to its original size. However, only the size is restored, the pooled features are also modified accordingly.
Batch Normalization Layer: Data Regularization
ReLU Layer: Activation Function
ADD Layer: Tensor Addition
Concat Layer: Tensor Concatenation
Composite Elements
Convolutional Block
Strided Sampling and Concatenation Unit(Focus)
By taking the small patches at position 1 from each large region and concatenating them, a 3×3 image can be formed. The patches at other positions are concatenated in the same way.
Ultimately, the original 6×6 image is decomposed into four 3×3 images.
Residual Block
Composite Convolutional Block
In YOLOv26, a key feature of the composite convolutional block is its customizable design, allowing convolutional blocks to be configured as needed. This structure also uses two paths whose outputs are merged.
Composite Residual Convolutional Block
The composite residual convolutional block modifies the composite convolutional block by replacing the 2𝑥 convolutional blocks with
𝑥 residual blocks. In YOLOv26, this block is also customizable, allowing residual blocks to be tailored according to specific requirements.
Composite Pooling Block
7.2.4 YOLOv26 Workflow
This section explains the model’s processing flow using the concepts of prior boxes, prediction boxes, and anchor boxes involved in YOLOv26.
7.2.4.1 Prior Box
7.2.4.2 Prediction Box
Prediction boxes are generated by the model as output and do not require manual input. When the first batch of training data is fed into the model, the prediction boxes are automatically created. The center points of prediction boxes tend to be located in areas where similar objects frequently appear.
7.2.4.3 Anchor Box
7.2.4.4 Project Process
7.2.5 Image Collection and Annotation
Training the YOLOv11 model requires a large amount of data, so data collection and annotation must be performed first to prepare for model training.
In this example, the demonstration uses traffic signs as target objects.
7.2.5.1 Image Collection
Power on the robot and connect it via the NoMachine remote control software.
Click the terminal icon
in the system desktop to open a command-line window.Stop the app auto-start service by entering the following command:
Start the depth camera service with the command.
Open a new command-line terminal and enter the command to create a directory for storing your dataset. For example, create a directory named my_data.
mkdir -p ~/my_data
Then, launch the tool by entering the following command.
The save number in the top-left corner of the tool interface shows the ID of the saved image. The existing shows how many images have already been saved.
Click
Selectto change the save path to the my_data folder created before.
After selecting the target directory, click
Choose.Place the target in front of the camera’s view, click the
Save(Space)button, or press thespacekey to save the current camera frame.
A JPEGImages folder will be automatically created under the directory /home/ubuntu/my_data to store the images.
To improve model reliability, capture the target object from various distances, angles, and tilts.
To ensure recognition stability, model training requires a substantial number of images. Collecting approximately 100 images per category is recommended.
After collecting images, click the
Quitbutton to close the tool.
Then press Ctrl + C in all open terminal windows to exit—this completes the image collection process.
7.2.5.2 Image Annotation
After acquiring images, image annotation is required. Annotation is essential for functional datasets because it informs the training model about the categories of important image sections, enabling the model to accurately recognize these categories in new, unseen images later.
Click the desktop icon
to open the terminal, and enter the command to launch the image annotation software.
python3 ~/software/roLabelImg/roLabelImg.py
After opening the software, click File in the top left corner, select Open Dir, navigate to the directory containing the acquired images, and click the Open button.
Click File in the top left corner and select Change default saved Annotation dir to modify the save path. Select the Annotations directory within the
my_datafolder, and then click the Open button.
Click View in the top left corner and select Advanced Mode to enable the rotational annotation feature.
Keyboard shortcuts are utilized as follows: e annotates a rotated target, d moves to the next image, a moves to the previous image, c applies a slight clockwise rotation, x applies a slight counterclockwise rotation, v applies a large clockwise rotation, and z applies a large counterclockwise rotation. After annotating each image, press Ctrl + S or click the Save icon on the left to save the progress.
Be sure to use the ‘C’ and ‘X’ keys to rotate and align the bounding box with the object’s edges. Misalignment will negatively affect subsequent recognition.
In the pop-up window, assign a category name to the target content. Here, it is named left. After naming, click the OK button or press Enter to save this category.
Use the shortcut Ctrl + S to save the annotation data for the current image.
Press the D key to proceed to the next image for annotation. Repeat steps 5-7 until all images are successfully annotated, and then click the close button in the top right corner of the software to exit.
7.2.6 Data Format Conversion
to open a terminal, and enter the command.
vim ~/my_data/classes.names
Press the i key to write the annotated category left into the text file. If there are multiple different categories, insert line breaks for each entry.
Once complete, press the ESC key, enter the following command, and press Enter to save and exit.
The class names added here must exactly match the names used within the image annotation software.
Return to the terminal, enter the command to convert the data format, and press Enter.
python3 ~/third_party/yolo/xml2yolo_obb.py --data ~/my_data --yaml ~/my_data/data.yaml
7.2.7 Training the Model
Enter the command to start training and press Enter.
python3 ~/third_party/yolo/train.py --img 640 --weights yolo26n.pt --data /home/ubuntu/my_data/data.yaml --batch 16 --epochs 300
In the command, img specifies the image size, batch dictates the number of images per input batch, and epochs represents the number of training iterations. These parameters can be modified based on actual requirements. To improve model reliability, the number of epochs can be increased. However, this will correspondingly increase the overall training time.
The appearance of the content shown in the figure below indicates that training is currently in progress.
Once model training is complete, the terminal will print the path to the generated files, indicating that the training results have been successfully saved to this directory.
7.2.8 Exporting and Using the engine Model
Using the previously generated training result path as an example, enter the command and press Enter to navigate to the directory.
cd ~/third_party/yolo/runs/obb/train3/weights
Enter the command to move the trained model file to the corresponding path.
cp best.pt ~/third_party/yolo
Enter the command and press Enter to begin exporting the engine file, which takes some time to complete.
python3 export.py --weights best.pt --include engine --imgsz 640 --device 0
Following the conversion, the
.enginefile will be generated.
Copy the generated
.enginefile to the folderros2_ws/src/example/example/yolo_detect/models. Ensure the specific path matches the local environment setup.
cp ~/third_party/yolo/best.engine ~/ros2_ws/src/example/example/yolo_detect/models
Enter the command to open the launch file.
gedit ~/ros2_ws/src/example/example/yolo_detect/yolo_detect.launch.py
Change model_engine= 'yolo26n.engine' to model_engine= 'best.engine', then save and exit.
Enter the command and press Enter to verify the model’s recognition performance.
ros2 launch example yolo_detect.launch.launch.py model_name:=best
7.2.9 Waste Classification
7.2.9.1 Experiment Overview
First, the program subscribes to the real-time video feed data published by the camera node and converts it into numpy format. Next, the image is input into the YOLO network, where operations such as scaling, transposition, and array expansion are performed to obtain the processing results.
Subsequently, the acquired waste card image coordinates are converted back to the original image coordinates. Based on the recognized waste names, they are categorized according to predefined rules to retrieve the corresponding waste category names. Finally, the targets are enclosed in bounding boxes, displaying the waste names along with their recognition confidence scores.
7.2.9.2 Operation Steps
Start the robot and connect to the desktop remotely via NoMachine.
to open a terminal.Enter the command and press Enter to stop the auto-start service.
Enter the command and press Enter to start the application.
ros2 launch example garbage_classification.launch.py
To close the application, press Ctrl + C in the terminal interface. If it fails to close, retry repeatedly.
7.2.9.3 Program Outcome
After starting the feature, place a waste card in front of the camera. Once the camera recognizes the waste card, the corresponding name will be displayed on the video feed, and the robotic arm will grab the waste block and place it in a designated location according to its category.
| Garbage Category | Cards |
| hazardous_waste (Hazardous Waste) | Storage Battery, Marker, Oral Liquid Bottle |
| recyclable_waste (Recyclable Waste) | Plastic Bottle, Umbrella, Toothbrush |
| food_waste (Food Waste) | Banana Peel, Ketchup, Broken Bones |
| residual_waste (Residual Waste) | Cigarette End, Plate, Disposable Chopsticks |
7.3 MediaPipe Human-Robot Interaction
7.3.1 MediaPipe Introduction and Quick Start
7.3.1.1 Introduction to MediaPipe
MediaPipe is an open-source multimedia machine learning model application framework. It operates cross-platform on mobile devices, workstations, and servers, and supports mobile GPU acceleration. It also supports the TensorFlow and TF Lite inference engines, allowing any TensorFlow and TF Lite models to be utilized on MediaPipe. Additionally, on mobile and embedded platforms, MediaPipe supports device-native GPU acceleration.
7.3.1.2 MediaPipe Pros and Cons
Advantages of MediaPipe
Supports various platforms and languages, such as iOS, Android, C++, Python, JavaScript, Coral, etc.
Fast processing speed. Models can generally achieve real-time execution.
High reusability for both models and code.
Disadvantages of MediaPipe
Slightly heavy for mobile platforms, requiring at least 10MB of storage space.
Deeply dependent on TensorFlow. Switching to other machine learning frameworks requires significant code modifications.
Utilizes static graphs, which helps improve efficiency but makes debugging more difficult.
7.3.1.3 MediaPipe Workflow
The following figure illustrates the MediaPipe workflow. The solid line section requires manual coding, while the dashed line section does not. AI-related models are already integrated internally within MediaPipe, allowing developers to utilize MediaPipe to quickly deduce the framework needed to implement a specific function.
Dependencies
MediaPipe relies on OpenCV to process video and FFMPEG to process audio data. It has other dependencies as well, such as OpenGL/Metal, TensorFlow, Eigen, etc. It is recommended to have a basic understanding of OpenCV before starting with MediaPipe. Refer to 1. Tutorials\2. Basics Course\3. OpenCV Computer Vision Course for related information.
MediaPipe Solutions
Solutions are open-source, pre-built examples based on specific pre-trained TensorFlow or TFLite models. MediaPipe Solutions are built on top of the framework. Currently, 16 Solutions are provided. These include Face Detection, Face Mesh, Iris, Hands, Pose, Holistic, and more.
7.3.1.4 MediaPipe Learning Resources
MediaPipe Official Website: https://developers.google.com/mediapipe
MediaPipe Wiki: http://i.bnu.edu.cn/wiki/index.php?title=Mediapipe
MediaPipe GitHub: https://github.com/google/mediapipe
dlib Official Website: http://dlib.net/
dlib GitHub: https://github.com/davisking/dlib
7.3.2 Fingertip Trajectory Recognition
By using the MediaPipe hand detection model to identify palm joints, the robot begins to lock onto the fingertip within the frame after recognizing a specific gesture, tracking the fingertip, and drawing its movement trajectory.
7.3.2.1 Experiment Introduction
First, a hand recognizer is instantiated to obtain hand keypoint information and connect the keypoints.
Next, the keypoints are normalized to calculate the finger angles and the current gesture.
Finally, under a specific gesture, the system begins tracking and recording the movement trajectory points of the finger, returning the recognized trajectory image.
This section utilizes two technologies. One is the computer vision library OpenCV, used to acquire the incoming image and perform color space conversion, outputting the recognized hand feature model points. The recognition method employs MediaPipe, a cross-platform, open-source framework developed by Google for building real-time, machine-learning-based applications.
It provides a series of computer vision and machine learning algorithms and tools, including object detection, face detection, keypoint detection, hand tracking, semantic segmentation, etc. These algorithms are pre-trained, can run on mobile devices, desktops, and servers, achieve real-time processing, and finally display the recognized gesture features on the screen.
7.3.2.2 Operation Steps
Power on ROSpider and remotely connect to the system desktop via NoMachine. For instructions on connecting to the remote desktop, refer to 1. ROSpider User Manual \ 1.4 Development Environment Setup.
to open the command line terminal.Enter the command and press Enter to stop auto-start services.
Enter the command to start the feature and press Enter.
ros2 launch example finger_trajectory.launch.py
To stop the feature, press Ctrl + C in the terminal interface. If the feature does not close immediately, try pressing Ctrl + C a few more times.
7.3.2.3 Program Outcome
After starting the feature, place a hand within the camera’s recognition range. Once the robot detects the hand, the hand keypoints will be connected. When a single extended index finger is detected, the buzzer will emit a beep, entering the fingertip trajectory recognition mode, and the fingertip’s trajectory will be drawn on the screen.
When the gesture changes to an open palm with five fingers spreading, trajectory recognition will stop, and a recognized trajectory image window will be returned.
7.3.2.4 Program Analysis
Launch File Analysis
This launch file is located at: ros2_ws/src/example/example/mediapipe_example/finger_trajectory.launch.py
Start other launch files, such as the file used to start the depth camera.
Start the node used for fingertip trajectory recognition.
finger_trajectory_node = Node(
package='example',
executable='finger_trajectory',
Python File Analysis
The program source code is located at: ros2_ws/src/example/example/mediapipe_example/include/finger_trajectory.py
Finger Type Classification
def hand_angle(landmarks):
angle_list = []
# thumb
angle_list.append(angle_)
# index
# middle
# ring
# pink
return angle_list
After extracting the hand feature points, logical processing is required. By determining the angle relationships between feature points, the specific finger type can be identified. Pass the feature point collection landmarks(results), then use the vector_2d_angle function to calculate the angles between corresponding feature points.
Gesture Feature Detection
def h_gesture(angle_list):
thr_angle, thr_angle_thumb, thr_angle_s = 65.0, 53.0, 49.0
if (angle_list[0] < thr_angle_s) and (angle_list[1] < thr_angle_s) and (angle_list[2] < thr_angle_s) and (
gesture_str = "five"
gesture_str = "one"
gesture_str = "none"
return gesture_str
Determines the current gesture based on finger bending angles.
draw_pointsFunction
def draw_points(img, points, tickness=4, color=(255, 0, 0)):
points = np.array(points).astype(dtype=np.int32)
if len(points) > 2:
if i + 1 >= len(points):
cv2.line(img, p, points[i + 1], color, tickness)
Connects the recorded trajectory points point by point and draws them on the image.
get_track_imgFunction
def get_track_img(points):
x_min, y_min = np.min(points, axis=0).tolist()
x_max, y_max = np.max(points, axis=0).tolist()
track_img = np.full([y_max - y_min + 100, x_max - x_min + 100, 1], 0, dtype=np.uint8)
points = points - [x_min, y_min]
points = points + [50, 50]
draw_points(track_img, points, 1, (255, 255, 255))
return track_img
Generates a trajectory image with a black background and white lines using the recorded trajectory points.
Class Initialization
self.timer = time.time()
static_image_mode=False,
max_num_hands=1,
min_tracking_confidence=0.05,
min_detection_confidence=0.6
self.bridge = CvBridge() # For conversion between ROS Image messages and OpenCV images
self.state = State.NULL
self.points = []
self.start_count = 0
self.no_finger_timestamp = time.time()
self.image_sub = self.create_subscription(Image, '/depth_cam/rgb/image_raw', self.image_callback, 1) # Subscribe to the camera
self.joints_pub = self.create_publisher(ServosPosition, '/servo_controller', 1) # Servo control
self.get_logger().info('\033[1;32m%s\033[0m' % 'Press the Spacebar to clear the recorded trajectory.')
Initializes the node, creating image subscriptions and servo control publishing.
Image Callback
# Convert the screen to OpenCV format
Converts ROS image messages to OpenCV format and caches them.
Main Loop
bgr_image = self.image_queue.get()
bgr_image = cv2.flip(bgr_image, 1) # Mirrored image
result_image = np.copy(bgr_image) # Make a copy for result display to prevent modification of the image during processing
if self.timer <= time.time() and self.state == State.RUNNING:
results = self.hand_detector.process(bgr_image) if self.state != State.RUNNING else None
if results is not None and results.multi_hand_landmarks:
gesture = "none"
index_finger_tip = [0, 0]
self.no_finger_timestamp = time.time() # Note the current time for timeout handling
self.drawing.draw_landmarks(
result_image,
hand_landmarks,
mp.solutions.hands.HAND_CONNECTIONS)
landmarks = get_hand_landmarks(bgr_image, hand_landmarks.landmark)
angle_list = (hand_angle(landmarks))
gesture = (h_gesture(angle_list))
index_finger_tip = landmarks[8].tolist()
if self.state == State.NULL:
if gesture == "one": # Detect the index finger extended while the other fingers are clenched into a fist
self.start_count += 1
if self.start_count > 20:
self.state = State.TRACKING
self.points = []
elif self.state == State.TRACKING:
if gesture == "five": # Finish drawing when all five fingers are spread out
# Generate a black and white trajectory image
track_img = get_track_img(self.points)
contours = cv2.findContours(track_img, cv2.RETR_EXTERNAL, cv2.CHAIN_APPROX_NONE)[-2]
contour, area = get_area_max_contour(contours, 300)
# Identify the drawn shape based on the trajectory image
track_img = cv2.fillPoly(track_img, [contour, ], (255, 255, 255))
for _ in range(3):
track_img = cv2.erode(track_img, cv2.getStructuringElement(cv2.MORPH_RECT, (5, 5)))
track_img = cv2.dilate(track_img, cv2.getStructuringElement(cv2.MORPH_RECT, (5, 5)))
h, w = track_img.shape[:2]
track_img = np.full([h, w, 3], 0, dtype=np.uint8)
track_img = cv2.drawContours(track_img, [contour, ], -1, (0, 255, 0), 2)
approx = cv2.approxPolyDP(contour, 0.026 * cv2.arcLength(contour, True), True)
track_img = cv2.drawContours(track_img, [approx, ], -1, (0, 0, 255), 2)
print(len(approx))
# Determine the shape based on the number of vertices in the contour envelope
if len(approx) == 3:
cv2.putText(track_img, 'Triangle', (10, 40),cv2.FONT_HERSHEY_SIMPLEX, 1.2, (255, 255, 0), 2)
if len(approx) == 4 or len(approx) == 5:
cv2.putText(track_img, 'Square', (10, 40),cv2.FONT_HERSHEY_SIMPLEX, 1.2, (255, 255, 0), 2)
if 5 < len(approx) < 10:
cv2.putText(track_img, 'Circle', (10, 40),cv2.FONT_HERSHEY_SIMPLEX, 1.2, (255, 255, 0), 2)
if len(approx) == 10:
cv2.putText(track_img, 'Star', (10, 40),cv2.FONT_HERSHEY_SIMPLEX, 1.2, (255, 255, 0), 2)
cv2.imshow('track', track_img)
if len(self.points) > 0:
if distance(self.points[-1], index_finger_tip) > 5:
self.points.append(index_finger_tip)
draw_points(result_image, self.points)
if time.time() - self.no_finger_timestamp > 2:
self.points = []
cv2.imshow('image', result_image)
if key == ord(' '): # Press the spacebar to clear the recorded trajectory
self.points = []
Detects hand keypoints using MediaPipe and draws the keypoint connections. Detecting the one gesture with the index finger extended clears the historical trajectory. Detecting the five gesture with five fingers extended ends the trajectory, generates the trajectory image, and recognizes the shape. Listens for keyboard events, pressing the spacebar to clear the trajectory.
7.3.3 Gesture Recognition
Through the gesture recognition program, the recognized gesture information is printed on the image and the terminal.
7.3.3.1 Experiment Introduction
First, a hand recognition model needs to be set up, and the RGB image is obtained by subscribing to the topic messages published by the camera node.
Subsequently, the image undergoes processing such as flipping, and the hand information within the image is detected.
Finally, the recognition results are fed back in the command line terminal and the returned video frame.
7.3.3.2 Operation Steps
Enter the command and press Enter to start the feature.
ros2 launch example hand_detect.launch.py
7.3.3.3 Program Outcome
After starting the feature, perform specific gestures within the camera’s field of view. When the robot recognizes a gesture, hand keypoints will be identified in the returned video frame.
7.3.3.4 Program Analysis
This launch file is located at: ros2_ws/src/example/example/mediapipe_example/hand_detect.launch.py
Start the node used for gesture recognition.
hand_detect_node = Node(
package='example',
executable='hand_detect',
The program source code is located at: ros2_ws/src/example/example/mediapipe_example/include/hand_detect.py
model_path = os.path.join(os.path.abspath(os.path.split(os.path.realpath(__file__))[0]), 'model/hand_landmarker.task')
base_options = python.BaseOptions(model_asset_path=model_path)
options = vision.HandLandmarkerOptions(base_options=base_options, num_hands=2)
self.detector = vision.HandLandmarker.create_from_options(options)
Initializes the node, creating image subscriptions and a data queue.
Image Callback
# If the queue is full, remove the oldest image
Receives ROS image messages, converts the format, and caches them in the queue.
Main Loop
image = cv2.flip(image, 1)
detection_result = self.detector.detect(mp_image)
annotated_image = draw_hand_landmarks_on_image(image, detection_result)
result_image = cv2.cvtColor(annotated_image, cv2.COLOR_RGB2BGR)
cv2.imshow('hand_detect', result_image)
if key == ord('q') or key == 27: # Press Q or Esc to quit
Continuously fetches images from the queue, executes hand keypoint detection, performs visualization drawing, and handles the exit logic.
7.3.4 Gesture Control
Utilizing MediaPipe’s hand detection model and the logical calculation of feature points, the robot is controlled to perform corresponding actions after recognizing specific gestures, such as a finger heart, fist, etc.
7.3.4.1 Experiment Introduction
First, a MediaPipe hand detection model must be set up, and the image is obtained by subscribing to topic messages published by the camera node.
Then, the image undergoes processing such as flipping, and the hand information within the image is detected.
Next, based on the connections of hand keypoints, the finger angles are calculated to complete gesture determination.
Finally, the robot is commanded to execute the feedback action for the gesture, the gesture name is printed in the returned video frame, and the hand keypoints and connections are identified.
This section utilizes the computer vision library OpenCV to acquire incoming images and perform color space conversion, outputting the recognized hand feature model points. The recognition method uses MediaPipe, a cross-platform, open-source framework developed by Google for building real-time, machine-learning-based applications. It provides a series of computer vision and machine learning algorithms and tools, including object detection, face detection, keypoint detection, hand tracking, semantic segmentation, etc. These pre-trained algorithms can run on mobile devices, desktops, and servers, achieving real-time processing and displaying the recognized gesture features on the screen.
7.3.4.2 Operation Steps
ros2 launch example hand_gesture.launch.py
7.3.4.3 Program Outcome
After starting the feature, perform specific gestures within the camera’s field of view. When a gesture is recognized, the robot will execute the corresponding feedback action. In addition, the gesture name will be printed, and hand keypoints will be marked in the returned video frame.
The following table explains the recognizable gestures:
| Gesture Name | Gesture Description | Example | Feedback Action |
| gun | Finger gun | ![]() |
Attack (attack) |
| hand_heart | Finger heart | ![]() |
Twist body (twist_l) |
| OK | OK | ![]() |
Wave left front leg to greet (wave) |
| fist | Fist | ![]() |
Lunge forward (forward_flutter) |
7.3.4.4 Program Analysis
This launch file is located at: ros2_ws/src/example/example/mediapipe_example/hand_gesture.launch.py
Start other launch files, such as the files used to start the depth camera and servo control.
Start the node used for gesture control.
hand_gesture_node = Node(
package='example',
executable='hand_gesture',
The program source code is located at: ros2_ws/src/example/example/mediapipe_example/include/hand_gesture.py
angle_list = []
# thumb
# index
# middle
# ring
# pink
return angle_list
After extracting the hand feature points, logical processing is required to calculate the angles between corresponding feature points using the vector_2d_angle function, thus identifying the specific finger type from the passed feature point collection landmarks(results).
gesture_str = "fist"
gesture_str = "gun"
gesture_str = "hand_heart"
gesture_str = "one"
gesture_str = "two"
gesture_str = "three"
gesture_str = "OK"
gesture_str = "four"
gesture_str = "six"
return gesture_str
max_num_hands=1,
min_tracking_confidence=0.4,
min_detection_confidence=0.4
self.lock = threading.RLock()
self.fps = fps.FPS() # FPS calculator
self.draw = True
self.points = [[0, 0], ]
self.one_count = 0
self.direction = ""
self.last_gesture = "none"
self.gesture = None
self.controller = step_controller.StepController()
self.gesture_list = ('gun', 'hand_heart', 'OK', 'fist')
self.buzzer_pub = self.create_publisher(BuzzerState, '/ros_robot_controller/set_buzzer', 1) # Buzzer control
self.agc_controller = ActionGroupController(self.create_publisher(ServosPosition, 'servo_controller', 1), '/home/ubuntu/software/actionset_editor/ActionGroups')
self.timer = self.create_timer(0.0, self.init_process, callback_group=self.timer_cb_group)
Initializes the node, creating image subscriptions, and servo and buzzer control publishing.
init_processMethod
self.init_action()
threading.Thread(target=self.do_act, daemon=True).start()
Node initialization workflow, starting core threads and services.
init_actionMethod
def init_action(self):
self.controller.set_build_in_pose('DEFAULT_POSE', 1)
joint_angle = [500, 750, 200, 150, 500, 600]
set_servo_position(self.joints_pub, 1, ((19, joint_angle[0]), (20, joint_angle[1]), (21, joint_angle[2]), (22, joint_angle[3]), (23, joint_angle[4]), (24, joint_angle[5])))
Initialization action upon node startup, putting the robot into the initial pose.
do_actMethod
def do_act(self):
ACTION = { 'gun' : 'attack',
'hand_heart' : 'twist_l',
'OK' : 'wave',
'fist' : 'forward_flutter'}
LOCK_SERVOS={'19':500, '20':750, '21':200, '22':150, '23':500, '24':600}
with self.lock:
if self.gesture is not None and self.gesture in ACTION:
self.set_buzzer(0.2, 0.01, 1)
self.agc_controller.run_action(ACTION[self.gesture],lock_servos=LOCK_SERVOS)
self.draw = True
self.gesture = None
Gesture action mapping execution thread, converting valid detected gestures into robot actions.
Buzzer
def set_buzzer(self, on_time, off_time, repeat):
# Set buzzer
msg.freq = 1900
msg.on_time = on_time
msg.off_time = off_time
msg.repeat = repeat
Controls the buzzer sound, providing feedback for successful gesture recognition.
Image Callback
Converts ROS image messages to OpenCV format and caches them in the queue.
Main Loop
self.direction = ""
if self.direction != "":
cv2.putText(result_image, self.direction, (10, 100), cv2.FONT_HERSHEY_SIMPLEX, 1, (255, 0, 0), 2)
results = self.hand_detector.process(bgr_image) # Hand and key points recognition
if results.multi_hand_landmarks and self.draw :
gesture = "none"
result_image,
hand_landmarks,
h, w = bgr_image.shape[:2]
landmarks = get_hand_landmarks((w, h), hand_landmarks.landmark)
angle_list = hand_angle(landmarks)
gesture = h_gesture(angle_list) # Judge gesture based on key points position
cv2.putText(result_image, gesture.upper(), (10, 100), cv2.FONT_HERSHEY_SIMPLEX, 1.2, (0, 0, 0), 5)
cv2.putText(result_image, gesture.upper(), (10, 100), cv2.FONT_HERSHEY_SIMPLEX, 1.2, (255, 255, 0), 2)
draw_points(result_image, self.points[1:])
if self.state != State.RUNNING :
if gesture in self.gesture_list :
if gesture == self.last_gesture :
if self.count > 20:
self.state = State.RUNNING
self.draw = False
self.gesture = gesture
self.last_gesture = gesture
if self.state != State.NULL:
self.one_count = 0
self.points = [[0, 0],]
if result_image is not None :
self.init_action()
Fetches the image from the queue, detects hand keypoints via MediaPipe, calculates finger angles to obtain the gesture type, draws the gesture name on the image, and displays the processed image using cv2.imshow.
7.3.5 Face Detection and Tracking
Using MediaPipe’s face detection model, ROSpider adjusts the pan-tilt servo angles based on the face’s position, enabling real-time face tracking.
7.3.5.1 Experiment Introduction
First, a face detection model is established, and the RGB image is acquired by subscribing to the topic messages published by the camera node.
Subsequently, face information within the image is detected and processed to determine the tracking target.
Finally, ROSpider is controlled to track the face based on the distance between the target face center and the center of the frame.
7.3.5.2 Operation Steps
Enter the command to start the feature program and press Enter.
ros2 launch example face_track.launch.py
7.3.5.3 Program Outcome
After starting the feature, when a face is recognized in the camera’s field of view, the robot will adjust the rotation angle of the pan-tilt servos based on the face’s location to track. Additionally, the target face and facial keypoints will be marked in the returned video frame.
7.3.5.4 Program Analysis
This launch file is located at: ros2_ws/src/example/example/mediapipe_example/face_track.launch.py
Start other launch files, such as those for the depth camera and servo control.
Start the node used for face tracking.
face_track_node = Node(
package='example',
executable='face_track',
The program source code is located at: ros2_ws/src/example/example/mediapipe_example/include/face_track.py
self.face_detector = mp.solutions.face_detection.FaceDetection(
min_detection_confidence=0.3,
self.z_dis = 0.28
self.y_dis = 500
self.x_init = 0.18
self.pid_z = pid.PID(0.00006, 0.0, 0.0)
self.pid_y = pid.PID(0.055, 0.0, 0.0)
self.detected_face = 0
self.result_publisher = self.create_publisher(Image, '~/image_result', 1) # Publish the image processing result
self.create_service(Trigger, '~/start', self.start_srv_callback) # Enter application mode
self.create_service(Trigger, '~/stop', self.stop_srv_callback, callback_group=timer_cb_group) # Exit application mode
self.client = self.create_client(Trigger, '/arm_kinematics/init_finish')
self.kinematics_client = self.create_client(SetRobotPose, '/arm_kinematics/set_pose_target')
Initializes the node, creating image subscriptions, servo control publishing, and creating services.
init_processMethod
self.init_action()
init_actionMethod
msg = set_pose_target([self.x_init, 0.0, self.z_dis], 0.0, [-90.0, 90.0], 1.0)
if res.pulse:
servo_data = res.pulse
set_servo_position(self.joints_pub, 1.5, ((24, 500), (23, 500), (22, servo_data[3]), (21, servo_data[2]), (20, servo_data[1]), (19, servo_data[0])))
time.sleep(1.8)
Main Loop
results = self.face_detector.process(bgr_image)
boxes, keypoints = mp_face_location(results, bgr_image)
o_h, o_w = bgr_image.shape[:2]
if len(boxes) > 0:
self.detected_face += 1
self.detected_face = min(self.detected_face, 20) # Ensure that the count is never greater than 20
# Start tracking if a face is detected in five consecutive frames to avoid false positives
if self.detected_face >= 5:
center = [box_center(box) for box in boxes] # Calculate the center coordinate of all human faces
dist = [distance(c, (o_w / 2, o_h / 2)) for c in center] # Calculate the distance from the center of each detected face to the center of the screen
face = min(zip(boxes, center, dist), key=lambda k: k[2]) # Identify the face with the minimum distance to the center of the screen
center_x, center_y = face[1]
t1 = time.time()
self.pid_y.SetPoint = result_image.shape[1]/2
self.pid_y.update(center_x)
if self.y_dis < 200:
self.y_dis = 200
if self.y_dis > 800:
self.y_dis = 800
self.pid_z.SetPoint = result_image.shape[0]/2
self.pid_z.update(center_y)
if self.z_dis > 0.30:
self.z_dis = 0.30
if self.z_dis < 0.23:
self.z_dis = 0.23
t2 = time.time()
t = t2 - t1
if t < 0.02:
time.sleep(0.02 - t)
if res.pulse:
set_servo_position(self.joints_pub, 0.02, ((24, 500), (23, 500), (22, servo_data[3]), (21, servo_data[2]), (20, servo_data[1]), (19, int(self.y_dis))))
set_servo_position(self.joints_pub, 0.02, ((19, int(self.y_dis)), ))
result_image = show_faces( result_image, bgr_image, boxes, keypoints) # Display the detected faces and facial key points on the screen
else: # Here is the processing for when no face is detected
if self.detected_face > 0:
self.detected_face -= 1
self.pid_z.clear()
self.pid_y.clear()
self.result_publisher.publish(self.bridge.cv2_to_imgmsg(result_image, "bgr8"))
self.fps.show_fps(result_image)
cv2.imshow("result", result_image)
cv2.waitKey(1)
self.init_action()
Fetches the image from the queue, calls MediaPipe to detect and process the image, extracts bounding boxes and keypoints, calculates the distance from the center of all detected faces to the screen center, selects the closest face as the tracking target, draws bounding boxes and keypoints on the image, publishes the processed image, and displays it via cv2.imshow.
7.3.6 Body Motion Control
By utilizing MediaPipe for real-time deep-learning-based body feature matching, followed by logical calculation of feature points, the robot is controlled to perform corresponding actions.
7.3.6.1 Experiment Introduction
First, a human pose estimator is instantiated to obtain body keypoint information and connect the keypoints.
Then, after processing the points, the arm motion is determined using manual 2D geometric features.
Finally, when both arms are raised high, the system prepares to enter imitation mode. Once the arms are spread horizontally, the motion imitation begins.
7.3.6.2 Operation Steps
ros2 launch example pose_control.launch.py
7.3.6.3 Program Outcome
After starting the feature, the robot will switch to a ready pose for imitation. Standing in front of the camera allows body keypoints to be detected and visualized with connecting lines on the display.
When a pose with both arms raised high is recognized, the buzzer will emit a beep, preparing to enter imitation mode. When both arms are then spread horizontally, the robot will begin imitating the motion, and the front legs will move accordingly.
When the system recognizes both arms raised and crossed, it will exit imitation mode.
7.3.6.4 Program Analysis
This launch file is located at: ros2_ws/src/example/example/mediapipe_example/pose_control.launch.py
Start the node used for somatosensory control.
pose_control_node = Node(
package='example',
executable='pose_control',
The program source code is located at: ros2_ws/src/example/example/mediapipe_example/include/pose_control.py
get_angleFunction
def get_angle(p1, p2, p3):
angle = vector_2d_angle(p2 - p1, p3 - p2)
return angle
Calculates the angle formed by three points, with p2 as the vertex.
is_pentagonFunction
def is_pentagon(landmarks):
shoulder_width = distance(landmarks[12], landmarks[11]) # Shoulder width
hand_dist = distance(landmarks[16], landmarks[15]) # The distance between the two wrists
if hand_dist > shoulder_width: # The hand distance is smaller than the shoulder width
return False
for p in landmarks[:7]: # Both wrists are above the head, higher than the eyes and nose
if landmarks[15][1] > p[1] or landmarks[16][1] > p[1]:
return False
if get_angle(landmarks[11], landmarks[12], landmarks[14]) < 40:
return False # The left upper arms are raised more than 40 degrees above the shoulder
if get_angle(landmarks[13], landmarks[11], landmarks[12]) < 40:
return False # The right upper arms are raised more than 40 degrees above the shoulder
return True
Determines the “both hands raised above the head, arms forming a pentagon with the shoulders” action, which is the trigger condition to start imitation.
is_levelFunction
def is_level(landmarks, angle_threshold=15):
p0 = landmarks[12].copy()
p0[0] = 0
if abs(get_angle(p0, landmarks[12], landmarks[11])) > angle_threshold:
return False
return True
Determines whether the shoulders are level with the frame.
is_flatFunction
def is_flat(landmarks, angle_threshold):
arm_marks = [15, 13, 11, 12, 14, 16]
for i in range(3):
angle = get_angle(landmarks[arm_marks[i]], landmarks[arm_marks[i + 1]], landmarks[arm_marks[i + 2]])
if abs(angle) > angle_threshold:
return False
return is_level(landmarks, angle_threshold)
Determines whether both arms are spread out.
is_crossFunction
def is_cross(landmarks):
if landmarks[16][0] <= landmarks[15][0]:
return False
return is_pentagon(landmarks)
Determines whether both arms are raised high and crossed.
mp_pose_landmarksFunction
def mp_pose_landmarks(results, img_rgb, draw=True):
lm_list = []
if results and results.pose_landmarks:
h, w, = img_rgb.shape[:2]
for idx, lm in enumerate(results.pose_landmarks.landmark):
cx, cy = int(lm.x * w), int(lm.y * h)
lm_list.append([cx, cy])
if draw:
cv2.circle(img_rgb, (cx, cy), 5, (255, 0, 0), cv2.FILLED)
cv2.circle(img_rgb, lm_list[11], 5, (255, 255, 0), cv2.FILLED)
cv2.circle(img_rgb, lm_list[12], 5, (0, 255, 255), cv2.FILLED)
cv2.circle(img_rgb, lm_list[14], 5, (0, 255, 0), cv2.FILLED)
if len(lm_list) > 0:
return np.array(lm_list)
return None
Extracts keypoint coordinates from pose detection results and visualizes them.
def __init__(self):
super().__init__('pose_control_node')
# Initialize MediaPipe pose detection
self.pose = mp.solutions.pose.Pose(
model_complexity=1,
min_detection_confidence=0.6,
min_tracking_confidence=0.7
# State initialization
self.timestamp = 0
self.r_x_dist = 0
self.l_x_dist = 0
Initializes the node, creating image subscriptions, servo control, and buzzer control.
reset_servosMethod
def reset_servos(self):
self.get_logger().info("Resetting servos...")
set_servo_position(self.joints_pub, 1, ((5, RIGHT_SERVO_I_DEFAULT), (3, RIGHT_SERVO_M_DEFAULT), (1, RIGHT_SERVO_O_DEFAULT), (6, LEFT_SERVO_I_DEFAULT), (4, LEFT_SERVO_M_DEFAULT), (2, LEFT_SERVO_O_DEFAULT)))
time.sleep(1.2)
Resets the positions of the 6 servos on both legs.
stop_imitationMethod
def stop_imitation(self):
self.reset_servos()
self.get_logger().info("Imitation mode exited")
Exits imitation mode and restores the initial state.
process_landmarksMethod
def process_landmarks(self, landmarks):
if time.time() - self.timestamp > 5:
if is_pentagon(landmarks):
self.enter_imitation_mode()
elif self.state == State.INTO_IMITATION_1:
self.handle_imitation_transition(landmarks)
self.handle_imitation(landmarks)
Parses human pose based on the node state to achieve state transitions.
handle_imitationMethod
def handle_imitation(self, landmarks):
self.timestamp = time.time()
if not is_cross(landmarks):
self.adjust_servos(landmarks)
self.stop_imitation()
Processes real-time movements during imitation mode.
adjust_servosMethod
def adjust_servos(self, landmarks):
left_angle_2 = get_angle(landmarks[11], landmarks[12], landmarks[14])
left_angle_3 = get_angle(landmarks[12], landmarks[14], landmarks[16])
right_angle_2 = get_angle(landmarks[12], landmarks[11], landmarks[13])
right_angle_3 = get_angle(landmarks[11], landmarks[13], landmarks[15])
raw_right_servo_2 = int(RIGHT_SERVO_M_DEFAULT + PULSE_PER_DEGREE * right_angle_2)
raw_right_servo_3 = int(RIGHT_SERVO_O_DEFAULT + PULSE_PER_DEGREE * right_angle_3)
raw_left_servo_2 = int(LEFT_SERVO_M_DEFAULT + PULSE_PER_DEGREE * left_angle_2)
raw_left_servo_3 = int(LEFT_SERVO_O_DEFAULT + PULSE_PER_DEGREE * left_angle_3)
r_x_dist = distance(landmarks[13], landmarks[11])
l_x_dist = distance(landmarks[12], landmarks[14])
left_angle_1 = self.clamp(90.0 - l_x_dist / self.l_x_dist * 90.0, 0, 120)
right_angle_1 = self.clamp(90.0 - r_x_dist / self.r_x_dist * 90.0, 0, 120)
raw_left_servo_1 = int(LEFT_SERVO_I_DEFAULT - PULSE_PER_DEGREE * left_angle_1)
raw_right_servo_1 = int(RIGHT_SERVO_I_DEFAULT + PULSE_PER_DEGREE * right_angle_1)
current_servo_values = {
"right_servo_1": raw_right_servo_1,
"right_servo_2": raw_right_servo_2,
"right_servo_3": raw_right_servo_3,
"left_servo_1": raw_left_servo_1,
"left_servo_2": raw_left_servo_2,
"left_servo_3": raw_left_servo_3,
servo_positions_list = []
for servo_name, limits in SERVO_LIMITS.items():
current_value = current_servo_values.get(servo_name)
servo_id = SERVO_IDS.get(servo_name)
if current_value is not None and servo_id is not None:
min_val, max_val = limits
clamped_value = self.clamp(current_value, min_val, max_val)
servo_positions_list.append((servo_id, clamped_value))
print(f"Warning: Missing value or ID for servo '{servo_name}'")
servo_positions = tuple(servo_positions_list)
set_servo_position(self.joints_pub, 0.02, servo_positions)
time.sleep(0.02)
Calculates and controls the servo pulse values based on the human upper limb angles.
update_displayMethod
def update_display(self, image):
cv2.imshow("image", cv2.resize(image, (display_size[0], display_size[1])))
cv2.waitKey(1)
Scales the image according to display_size and displays the window using cv2.imshow.
